Go to Post Is it weird we think speed controllers are sexy? - vivek16 [more]
Go Back   Chief Delphi > Competition > Regional Competitions
  #151   Spotlight this post!
Unread 04-04-2007, 14:06
pakratt1991's Avatar
pakratt1991 pakratt1991 is offline
AKA: Tim L.
FRC #0997 (Spartan Robotics)
pakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nice
Send a message via AIM to pakratt1991 Send a message via MSN to pakratt1991 Send a message via Yahoo to pakratt1991
Re: 2007 Davis Sacramento Regional
SOAP 108 has the quarter and semi finals up there now, they are pretty good.
WE should have ours up by Friday? maybe Saturday... but those are higher quality than the ones on SOAP.
2010 Oregon Autodesk Regional Winner (997, 2130, 1515) (Event Volunteer)
2008 UC Davis Semi-Finalists
2007 Championship Semi-Finalist (494, 254, 997)
2007 Davis Sacramento regional Champs (100, 997, 1458)
2007 PNW regional, Champs (997, 272, 1087)
  #152   Spotlight this post!
Unread 04-04-2007, 14:19
Alpha 997 Alpha 997 is offline
AKA: Yi Li
FRC #0997 (Spartans)
Team Role: Operator
Alpha 997 will become famous soon enough
Originally Posted by ChrisH View Post
The bar at the bottom of the screen may or may not be for the same match as the Final Score. They are independent of each other. Once the scoring table figured this out we tried to make sure they stayed the same, but sometimes we goofed or we had to go ahead and change the lower bar to get set up for the next match.
The lower bar has a "tab" on the top that indicates the match number. The number on the right of the tab indicates how many seconds are left in that portion of the match. It starts at 15 for automode and counts down to zero, when telemode starts it goes to 120 and counts down from there.
The Final Score screen reflects what went into the database for that match. It also says what match the score is for. If the scores on the bar and the Final screen are different, then check the match numbers, they should be different as well. Be sure to include the effects of any penalties as these are not included in the scoring bar but are in the Final Score.
It makes perfect sense once you understand it all.
I'm not sure if we are talking about the same thing. But I was talking about the final-score screen's sum score. The screen listed ring scores and bonus scores then have 2 large number at the bottom to indicate the sum. The sum wasn't what the list add up to be.
Ohhh... The EXIT sign is green so that robots can get out during a fire.
2007-Archimedes semi-finalist
2007-Davis Sacramento Regional champion
2007-Pacific Northwest Regional champion
2005-Archimedes semi-finalist
2005-Archimedes second seed
  #153   Spotlight this post!
Unread 04-04-2007, 18:24
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
The two large numbers at the bottom with the array of dots in between are the part of the Final Score screen you should ignore. That is the "lower bar" and is used during a match to display the rack score real time. This score does not include bonuses or penalties. But it is the most visually prominent, so people often topok it to be the "real" score.
Also if the guy at the scoring table is not paying attention then it might not be displaying the rack score for the match that is being displayed at the top in the Final Score screen. It was easy to advance the lower bar to the next match or to have it up while trying to correct a score from a previous match (fumble fingered refs ). This would result in results from two different matches being displayed simultaneously. The imporant screen is the Final Match Score screen. That is the one that has the official score for the match.
There obviously needs to be some human engineering on this part of the scoring system. The bright side is that no matter what, we will need a new scoring display next year. The scoring and field management system were so much more reliable than last year that I will gladly put up with a few minor complaints this year. Next year when 4FX has more time to focus on "peripheral" issues things should be better yet.
Christopher H Husmann, PE
"Who is John Galt?"
  #154   Spotlight this post!
Unread 04-04-2007, 20:47
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
I put those up. I have more it just took me while to parse and just as long to upload them to SOAP. Some are being stubborn - but they'll get there. I have most of Saturday's matches parsed, but I'm stuck at school for Open House (it is my job afterall) and can't get back to it until tonight.
Hang in there, we'll get them up.
  #155   Spotlight this post!
Unread 04-04-2007, 20:50
AKA: Tim L.
I've never dealt with SOAP before,
would they mind if we put up matches that were not from the big screen?
Because our scouting team is almost done with the matches they video taped, and I personally like the field overview that they did more then the big screen...
it is easier to see everything that is going on
  #156   Spotlight this post!
Unread 04-04-2007, 21:33
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
We are now uploading our own movies on our website, found here. The finals are almost all up, and the quarter-finals are next. Also, we will add qualification matches 52, 55 and 60. Hope these videos are helpful, because I haven't seen the finals anywhere else!
  #157   Spotlight this post!
Unread 07-04-2007, 17:12
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
hey does anyone have the FIRST video they played during opening ceremonies friday and saturday?
if you do please email it to me
aandreww11@gmail.com
thanks
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
  #158   Spotlight this post!
Unread 01-05-2007, 20:06
Andrew Nabors
AKA: Andrew Nabors
LOST!
i was with team 1671 at the DAVIS regional and i had lost my camera [CASIO - 7.2MP]
if n e one has it, or knows what i could to to go about finding it, that would be great, thanks
[FF]: [FF] Sacramento/Davis '07 114Klutz Fantasy FIRST 10 01-04-2007 09:47
Davis/Sacramento Regional cfriedenbach Regional Competitions 5 03-08-2006 19:12
2006 Davis Sacramento Regional ScottWalls Regional Competitions 68 31-03-2006 18:52
Welcome to the UC Davis-Sacramento Regional codeoftherobot Regional Competitions 12 16-03-2006 23:42
2005 Sacramento/UC Davis Regional codeoftherobot Regional Competitions 45 02-03-2005 19:33
