Go to Post The way things generally work in cases like this is simple: if you know something, you can't say it. So keep in mind that if someone does say something, it usually means they don't know. - Alan Anderson [more]
Go Back   Chief Delphi > Competition > Championship Event
View Poll Results: What does your robot do? (Read the post before voting)
Tube Scorer 26 20.47%
Ramp Bot 12 9.45%
Defensive 6 4.72%
Ramp Climber 1 0.79%
Hybrid: Tube Scorer + Ramp Bot 20 15.75%
Hybrid: Tube Scorer + Ramp Climber 45 35.43%
Hybrid: Other 17 13.39%
Voters: 127. You may not vote on this poll
Unread 05-04-2007, 10:08
cire's Avatar
cire cire is offline
Alumni, Mentor, and Coach
AKA: Eric Diehr
FRC #1716 (Redbird Robotics)
cire is just really nicecire is just really nicecire is just really nicecire is just really nice
Send a message via MSN to cire
Championship: Which type of robot are you?
In practice, what does your robot actualy do the majority of the time? Some teams designed theirs to be a tube scorer, but ended up playing defense most the time. Some designed it to be a hybrid ramp and tube scorer, but mostly scored tubes. Which does your team do in the majority of your matchs?
Tube Scorer - Robot scores tubes mostly.
Ramp bot - Robot lifts robots up mostly (I will assume you play defense while not lifting if your ramp only)
Defensive - Robot plays defense mostly.
Ramp climber - Robot climbs ramps mostly.
Hybrid: Tube scorer + Ramp bot - Robot that lifts other robots and score tubes mostly.
Hybrid: Tube scorer + Ramp climber - Robot that scores tubes and climbs on other robots (ramps or lifts).
Hybrid: Other - Other combinations of the 4 single categories as long as the robot does all of these in the majority of your matchs.
Please post your team number and your strengths and abilities.
Unread 05-04-2007, 10:11
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Championship: Which type of robot are you?
Ramp climber.
We have a 12' platform at 14.5"
We can climb any bot that supports wide bots (36")
Jacob
Unread 05-04-2007, 10:20
Sean Marks's Avatar
Sean Marks Sean Marks is offline
AutoCAD User
AKA: Sean Marks
FRC #2016 (Mu Mu Psi)
Team Role: Student
Sean Marks is a jewel in the roughSean Marks is a jewel in the roughSean Marks is a jewel in the rough
Send a message via AIM to Sean Marks
Team:2016
Hybrid:Tube Scorer + Ramp Climber
We can climb basically any ramp, and we can put 4 or 5 tubes on in a match. Plus we played some sick defense at NJ.
2008-NJ Semi-Finalist (Thanks 694 & 1279) / Chesapeake Winners (Thanks 1418 & 11) / Newton Finalists (Thanks 1574 & 141)
2007-NJ Rookie All-Star / Monty Madness Champs
Unread 05-04-2007, 10:47
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Team 47 Chief Delphi
Hybrid - Other
We can score tubes, be the ramp (holds 2 over 12"), climb other teams ramps easily, and play defense with the best of them.
No one can be/do everything at the same time, but if you are looking for a team that can truely do whatever is needed - keep us in mind.
Unread 05-04-2007, 10:59
cire's Avatar
AKA: Eric Diehr
Hybrid - Other
Just to clarify: Your robot was doing all of these things regularly? It seems lots of teams CAN do everything, I am asking for what they actualy decided to use the most when down on the field. By saying you do all 4 of those things, then im going to assume that you have a very flexible bot that HAS been doing all 4 things regularly. (There is no doubt that you can do it, but did you?)
Unread 05-04-2007, 11:02
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
You missed defensive / ramp bot.
1824 is a defensive / ramp bot.
We have a powerful drivetrain an a very easy to climb and plenty of parking space for 2 @ 13-1/2" (a bit of extra height )
See you all at the Championships. We're in Archimedes division
___________________
- Tennyson, Ulysses
Unread 05-04-2007, 11:11
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
Team 379 is a defensive/scoring hybrid. We average 4 to 5 rings a match and can play some very tough defense. We are also able to climb pretty much any ramp out there. See ya in Galileo!
Unread 05-04-2007, 11:14
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
Team 811 is a Hybrid:Other
We can score tubes,climb ramps,play defence and WE HAVE WORKING AUTONOMOUS!!!!
Dont beleve me:
http://www.youtube.com/watch?v=effg7ruko8s
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Unread 05-04-2007, 11:16
cire's Avatar
AKA: Eric Diehr
Sorry, I asumed but forgot to add that if you are a ramp bot only then you will play defense when not lifting. Its added into the description now
Unread 05-04-2007, 11:20
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
648 is a tube scoring ramp climber... however, I voted for tube scorer not realizing that that hybrid was just coined.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 05-04-2007, 11:25
fluffy's Avatar
fluffy fluffy is offline
What color was that wire again?
AKA: David
FRC #3663 (CPR)
fluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to behold
Send a message via MSN to fluffy
team 141
score tubes on all three levelse
climb ramps if needed
two platforms, one on each side of the robot, both have front(22 degree) and side (20 degree) ramps
and we can push people
i dont think ive missed anything
Unread 05-04-2007, 11:31
Jaime65's Avatar
Jaime65 Jaime65 is offline
AKA: Jaime
FRC #3398
Jaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud of
Team 65:
We are about to score tubes as well as climb ramps at the Great Lakes regional the maximum number of ringers scored by our team alone was 7 as far as climbing ramps as long as the ramp is 30 degrees or smaller and at least 28 inchs wide we can climb you
Unread 05-04-2007, 11:32
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
I almost put hybrid tube scorer/ramp climber, but I think tube scorer is more appropriate. We score well enough that we could likely score 1-2 tubes (or place/remove a spoiler) during the time it would take to climb a ramp. The majority of time the rack configuration is such that scoring an extra tube would give 32 or more points (out weighing the ramp bonus).
If it makes sense, we'll climb (we do it well) but we'd rather score.
As a secondary ability, we are very good at removing spoilers (and then finding a better place for them).
LV Regional - qualifying 9-0-0
LV Regional - overall 15-1-0
LV Regional Winning Alliance (with 254 and 1983; Cheesey Poofs and Skunk Works)
Unread 05-04-2007, 11:54
shakil07's Avatar
shakil07 shakil07 is offline
FRC #0123 (Team Cosmos)
Team Role: Driver
shakil07 is an unknown quantity at this point
Send a message via AIM to shakil07 Send a message via MSN to shakil07
Team 123 is hybrid tube scorer/ramp climber
climb ramps
able to play great defense
http://www.teamfordfirst.org/team123...007_robot1.JPG
2007 Detroit Regional Winner
2007 Pittsburgh Regional Winner
2007 Johnson & Johnson Sportsmanship Award
2006 GM Industrial Design Award At Buckeye Regional
2006 GM Industrial Design Award At Detroit Regional
2005 Detroit Regional Finalist
Unread 05-04-2007, 12:12
volunteer helper
FRC #6099 (Knights)
Yes, I understand your poll question.
Unfortunately what each team ACTUALLY did down on the field depended also on what their alliance partnerts could or couldn't do.
So, we ended up scoring in all of the matches when not getting beaten on by 2 or 3 at the same time, climbing up on other teams ramps when we needed to, we were the ramp when we had partners that weren't able to, and we played defense when we needed to.
What we actually did down on the field was dependent on the alliance strategy - which changed often to match the best attributes of each alliance we played with and against.
Hope this helps
Mike
Attention engineers...What type are you and why? Paul H Career 95 05-04-2007 14:38
Which Side are you On? George A. Chit-Chat 16 24-05-2005 21:46
What type of autonomous mode program are you using? SilverStar Programming 1 21-01-2004 18:48
different type of balancing, which one do you like better? archiver 2001 2 24-06-2002 02:33
Which teams are you looking forward to their robot? Ken Leung General Forum 17 14-02-2002 19:59
