#46
Re: Newton Discussion - Championship 2007
Team 340
Picture: Here Robot Class: 5' 110 scorer Drivetrain: 6 wheel, 2 speed AM's with 2 big cims, 2 little cims Ground Clearance: 2" Arm: 4 bar driven 2 cims, linear slides Extension: all heights Gripper: pneumatic actuated Pick up Method: Floor preferred Ramp: nope, but we can climb Results: FLR Finalists Strengths: Powerful, fast score, experienced drive team |
#47
Team 1676
Picture: http://www.chiefdelphi.com/media/img...6c45ee13_l.jpg Robot Class: 4' 120 hybrid Drivetrain: 6 wheel, 4 banebots 4 little cims Speed:11.5 fps Ground Clearance: 2.5" Arm: one pivot winch raised Extension: low and middle Gripper: suction cups Pick up Method: Floor Ramp: 1 low angle, we can climb Results: NJ semi-finalist/ Buckeye quarter finalist Strengths: Powerful, fast, new more reliable gripper |
#48
Team: 102
Picture: Scoring And Ramping Robot Class: 1 - 4" 120lbs Drivetrain: 4 wheel, 2 speed, 2 Cim motors per side Speed: 5fps in low, 13fps in high Ground Clearance: Less than 1/4" (yes it's pretty low haha) Arm: 90* tilt and boom Extension: Bottom and middle row (prefer bottom) Gripper: tilts parallel (or perpendicular) to ground. picks tube up from inside/outside by using the gripper to close tightly and then tilt and raise boom to prefered scoring level Pick up Method: Floor Ramp: We are the ramps; ramps are less than a 9* angle; robots drive up and we lift to 18 inches Results: Not so hott at NJ Regional haha, Better results at LI Regiona - didn't move on though (qualified by receiving Engineering Inspiration) Strengths: Lifting 1-2 robots 18 inches in under 5 seconds Last edited by Athleticgirl389 : 04-05-2007 at 04:08 PM. Reason: more details on gripper |
#49
Team 696
Picture: Scoring and Ramping Robot Class: 4" bot. 13" lifters, Scores on the rack. Drivetrain: 6 wheel, 4 cim. Speed: forgot... probably about 8fps or 9... Ground Clearance: dunno... Arm: 1 jointed arm Extension: scores all three rows Gripper: pneumatic grip Pick up Method: floor Ramp: 13" pneumatic lifters (1" ground clearance) Results: LA Finalists, SD Champions Strengths: rapid, consistent scorer (6-7 if left alone, 4-5 with defense), fast lifters (about 2-3 seconds for the lift), good defense (won SD with our defense against 368 to stop their spoiler) ... or I could be biased about our strengths since i'm the driver ![]() Last edited by hayakuneko : 04-05-2007 at 12:22 PM. |
#50
[quote=Tim Delles;612042]And here is the last divsion i have to do. Have fun with the info
39 - Regional Champ Team #39 was the Arizona Regional Champion and a Finalist at the Las Vegas Regional. Ken |
#51
Team 226
Picture: Coming Soon Robot Class: 4 Ft./120 lbs. Drivetrain: 2 Speed, 6 Traction Wheel 4 CIM Speed: 4-5 fps in low and 9-10 fps in high Ground Clearance: low, but can still climb ramps easily Arm: shoulder and wrist joint Extension: all three levels Gripper: electric screw grips tubes from inside Pick up Method: floor or opposing alliance wall Ramp: none, but climbs well Results: 13 of 59 at GLR and 16 of 54 at WMR Strengths: Drivers well practiced and skilled in both offense and defense, gripper picks up tubes quickly and doesn't require precision, robust robot |
#52
Team 668
Picture: Coming Soon Robot Class: 4 Ft / 120 lbs Drivetrain: 2 Speed, 6 Traction Wheel 2 CIM Speed: 6-8 fps in low and 14-16 fps in high Ground Clearance: Designed for greater than 30 degrees Arm: Shoulder and rotating wrist Extension: all three levels but prefer middle Gripper: Claw that rotates 90 degrees to pick off ground or human load Pick up Method: Anything but one of fastest human loads we've seen Ramp: Yes, 10-11 degrees hold 1 robot 13" perhaps a second at 12" (nobody tried) Results: Quarter Finalists at SVR and one of the top scorers there Strengths: Experienced, smart driver. Quick at hanging tubes and good defensive strategy if needed. Fast robot This should be fun. Good luck all. Last edited by burkechrs1 : 04-05-2007 at 07:26 PM. |
#53
. I remember a good scoring robot. |
#54
Team 75
Picture: http://www.chiefdelphi.com/media/photos/27595 Robot Class: 4 Ft / 120 lbs Drivetrain: 4wd Speed: 12 ft/s Ground Clearance: 1/4" Arm: 4 jointed arm on turret Extension: all three levels Gripper: Grabs tubes around outside, Pick up Method: over the wall prefered, can pick up off ground Ramp: none Results: Quarter Finalists at NJ, Chesapeake Champions Strengths: speed |
#55
Team 375
Picture: http://www.chiefdelphi.com/media/photos/27210 Robot Class: 5 Ft / 110 lbs Drivetrain: 2wd Speed: 10 ft/s Ground Clearance: enough to climb any ramp Arm: Double jointed arm Extension: all three levels Gripper: Grabs tubes by one side or through the middle Pick up Method: over the wall, off ground, off far wall, through shoot, ANYWHERE Ramp: none onboard, can climb Results: Semi Finalists at NJ, Semi Finalists at Pittsburgh, Finalists at NYC Strengths: speed, autonomous (Yea KEEPER!!) |
#56
Team 2016
Picture: http://www.mumupsi.com/galleries/NJR...os/photo8.html Robot Class: 4 Ft / 120 lbs Drivetrain: 4wd 2speed AM Shifter 4 Cim Speed: 7/14 ft/s Ground Clearance: 3" 26 degree climb capability Arm: Collapsable pulley and cable vertical lift. Extension: All three levels. Gripper: Grabs tubes with a vertical clamp style gripper. Pick up Method: off the ground or against the wall preferable, capable from anywhere. Ramp: none Results: Rookie All Star (New Jersey) Strengths: Power and Speed, Versatility |
#57
Team 1511
Picture: http://rollingthunder.smugmug.com/ga...137430412-L-LB Robot Class: 4 ft/ 120 lbs Drivetrain: 6 wd Speed: Not sure exactly but 3 gears: Normal, turbo, slow Ground Clearance: enough to climb any ramp Arm: Arm+Wrist Extension: all three levels Gripper: Grabs the whole tube Pick up Method: anywhere except over the wall Ramp: none but can climb Results: Fourth seed alliance at Boston Strengths: defense, accuracy |
#58
Team 573
Pictures: Scoring:http://i154.photobucket.com/albums/s...P3080219-1.jpg & On Ramphttp://i154.photobucket.com/albums/s...inningPlay.jpg Robot Class: 100 lbs/ 6 ft Drivetrain: 4 wheel, 2 speed, 4 cims Speed: 15ft per second Ground Clearance: Enough Arm: Two jointed arm w/ parallelogram design and pinching style gripper (about 6 to 7ft long, 4ft with limiters) Grapping Style: Off the ground Ramps: None Result: GLR #2 seed and Champion (along with 503 and 1015), BMR #7 seed and quarterfinalist. Strengths: Consisitent scoring and ability to evade defense via meccanums. |
#59
Team 1985
Picture: video of scoring and double lift Robot Class: 4' 120 hybrid Drivetrain: 4 wheel Extension: score consistently at all heights Gripper: grabs and holds sideways Pick up Method: Floor preferred Ramp: two ramps, both 12" very secure with side panels and a stop Results: STL quarterfinals, Rookie All Star Award Boilermaker semifinals, Delphi Driving Tomorrow's Technology Award Strengths: Powerful, flexible, very strong ramps |
#60
Team 1574
Picture: Final Game, scoring 7 tubes, photo Robot Class: 4' 120 lbs Drivetrain: 8 wheels (6 wheels configuration but with 2 attached in the middle) Speed: ~8fps Extension: Scores at all heights Ground Clearance: enough to climb all ramps... Arm: One joint for the arm, another joint for the gripper Gripper: "Claw" like, holds from the sides of the tube Pick up Method: Mainly Floor Ramp: Ramp for 2, 12" Results: Israeli Regional head of winning alliance, Motorola Quality award Strengths: Hang tubes very fast, picks tubes from the floor even faster... Highly maneuverable and has very experienced drivers. We even have autonomous mode... Last edited by Guy_E : 04-05-2007 at 06:19 PM. |
| 2007 Peachtree Regional - Discussion | dangerousdave | Regional Competitions | 48 | 04-04-2007 11:15 PM |
| 2007 Chesapeake Regional - Discussion | Sgraff_SRHS06 | Regional Competitions | 132 | 04-02-2007 01:47 PM |
| Championship 2007 Question | Eugenia Gabrielov | Championship Event | 19 | 09-15-2006 08:14 PM |
| Newton Discussion | AcesPease | Championship Event | 165 | 05-03-2006 08:52 PM |
| Extra Discussion for Picture Discussion | Ianworld | Robot Showcase | 1 | 01-31-2005 01:28 AM |
