Go to Post IRI: Where the Egos Go to Tie. :ahh: - Ian Curtis [more]
Unread 05-04-2007, 18:11
WillisRF's Avatar
WillisRF WillisRF is offline
FRC #1539 (Team Clover)
WillisRF will become famous soon enoughWillisRF will become famous soon enough
Re: Camera Stuck
Is there a separate reset in the tracking menu? If so, I'm not sure if we reset the tracking values.
We reset the camera settings which allowed the camera to follow the light if and only if it was already in vision. The camera did not run its search pattern.
Also, the min and max pan values are 30 and 220, respectively. The tilt min and max are 150 and 254. We will check and make sure that they are not backwards.
Also, we are using Kevin's 2007 code.
What confidence threshold would be suitable? I think that the default value is 40.
Any other ideas?
2007 Peachtree Regional Winner Thanks to 1127, 1369, and 1848.
2006 & 2007
RC Controller Stuck bhk88 Programming 1 31-01-2006 17:46
Stuck on Camera Mount busterblade16 Programming 2 14-02-2005 22:07
stuck in programming mode Shu Song Control System 2 29-04-2004 16:44
help! Am really stuck!!!! pagemauck Programming 8 29-01-2004 12:38
guy stuck in toilet! robot180 Chit-Chat 8 14-11-2003 22:27
