Go to Post Looks very well designed. Now where is the "export to reality" button in the CAD software? (I have been looking for it for weeks). - sanddrag [more]
Unread 03-04-2007, 19:31
Covey41 Covey41 is offline
Covey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of light
Calling all Hams--Amateur Radio Operators
If your going to Atlanta next week, don't forget your HTs!! The Atlanta Radio Club has invited all amateur's involved in FIRST to use their repeaters. They have both a 2m and a 70cm machines. (Both located downtown.) the 2m machine is on 146.82 w/negative offset, 70cm machine is on 444.825 w/positive offset, both use a PL146.2.
If anyone is interested, we could setup a simplex net each night at 2100hrs. Lets start Weds. night (11APR07) on 146.52.
73
WA1MOW
"One day you will come to a fork in the road. And you're going to have to make a decision about what direction you want to go." Boyd raised his hand and pointed. "If you go that way you can be somebody. You will have to make compromises and you will have to turn your back on your friends. But you will be a member of the club and you will get promoted and you will get good assignments." Then Boyd raised the other hand and pointed another direction. "Or you can go that way and you can do something for your country, your Air Force and for yourself. If you decide to do something, you may not get promoted and you may not get the good assignments and you certainly will not be a favorite of your superiors. But you won't have to compromise yourself. You will be true to your friends and to yourself. And your work might make a difference. To be somebody or to do something. In life there is often a roll call. That's when you will have to make a decision. To be or to do? Which way will you go?"
Unread 05-04-2007, 20:39
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: Calling all Hams--Amateur Radio Operators
If there's a specific time you're meeting on either repeater let me know and I'll dial up IRLP (They are connected to the IRLP net right?) and join you, it's as close as I can get to Atlanta this season.
KC2RGZ
Also, if anyone wants to call me up and send me updates, I'll be listening as often as I can on my 70cm HT on the local repeater, IRLP node 4747.
Matt Krass
Unread 05-04-2007, 21:57
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
If the Atlanta repeater is IRLP can I connect to that from my windows computer like i could with Echolink? If I could do that I would listen even if I didn't/couldn't talk.
Eric Haskins KC9JVH
Unread 05-04-2007, 23:32
Matt Krass's Avatar
AKA: Dark Ages
Most IRLP nodes support streaming web audio, check out the website for the club running the repeater. In order to talk you'll need to have your radio on a repeater that's equipped with IRLP, then each unit has its own special activation code, for ours we just dial the node number in on the radios keypad. Ours periodically plays an automated message explaining how to use the IRLP system.
Matt Krass
Unread 08-04-2007, 21:25
Mark Rozitis
Posts: n/a
If anyone from Ontario happens to know of a good ham radio course/club that actually teaches the course well feel free to let me know or post, I really should learn this and get my license but I found out the hard way once that you really have to know you're stuff, there are 100 questions on the exam out of a pool of 600 and as I found out once the hard way....you have no idea which questions you're going to get, so rather than just learn enough to barely pass the exam and get the license I wouldn't mind learning it properly if there was a reputable course being taught somewhere.
I am also in Canwarn which is our equivalent of skywarn so the license would be rather useful for severe weather suff.
thanks,
Mark
stormcentre@rogers.blackberry.net
http://tech.groups.yahoo.com/group/wxscan/
Unread 08-04-2007, 21:34
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
^^^!!!You have my avatar!!! (which I myself stole off somewhere)^^^
Hmmmm... no license... yet, but I think I just found myself an excuse to bring one of my shortwave radios along.
Unread 08-04-2007, 22:54
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
We will bring our hand held 2m, we have 15 hams on the team!
Faridodin "Fredi" Lajvardi KD7WKD
Unread 09-04-2007, 14:34
Matt Krass's Avatar
AKA: Dark Ages
Any chance of us FIRSTers meeting on a reflector before Atlanta? I want to get used to your voices/calls before it's party time.
Somebody know a good reflector?
Matt Krass
Unread 09-04-2007, 19:45
Mark Rozitis
Posts: n/a
Well you didn't steal it off me, I know that for a fact because I stole it off you
mark
Amateur Radio @ Nationals tinkergeek Championship Event 2 12-04-2004 00:07
Amateur Radio @ Nats FRANK(WGH) Championship Event 4 12-04-2003 01:13
Amateur Radio ckim Chit-Chat 1 02-01-2003 22:36
robotics and amateur radio FRANK(WGH) Championship Event 6 14-05-2002 16:03
Calling all Tigerbolt Chatters - And All Newcomers! Lora Knepper Chit-Chat 9 11-07-2001 18:09
