Go to Post The only thing more tedious than following a super-long thread is following a super-long thread with the same observations on every page. - CrazyCarl461 [more]
Unread 06-04-2007, 07:20
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: 06-05 KOP Transmissions Legal?
Originally Posted by Rosiebotboss View Post
We are using the single speed AndyMarks.
The 'major' difference is the AM are slightly thinner than the 2006 KOP single speeds. And if teams are practicing GP, they will leave the AM stickers on them....and the AM's have provisions for a 3" CIM as well. One mounting hole is a lot larger than the other.
And even better.... the pinion gear for the big cim has a d-shaft hole cut into it and is the right tooth count to match its input rpm with that of a small cim.
whoo andy mark!
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Transmissions rob_szma1212 Kit & Additional Hardware 7 13-01-2007 17:54
Transmissions Nitroxextreme Technical Discussion 29 13-04-2006 23:37
Transmissions Starke Technical Discussion 16 19-04-2005 10:13
Transmissions Jedi Padawan Technical Discussion 3 18-01-2004 23:38
Drill transmissions camtunkpa Technical Discussion 3 12-05-2003 21:21
