Go to Post just watch out for the evil, robot devouring ghosts - Mr. Pockets [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 06-04-2007, 17:53
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Re: Curie 2007 Robot Pictures and Basic Data
97: RoboRuminants from Cambridge, Mass.
Boston Regional 20th Seed, Semi-Finalists with 2079 and 1403.
http://web.mit.edu/first/www/07media/Boston/video
highlights:
http://web.mit.edu/first/www/07media...ston07_768.wmv
4' 11" - 110 lbs.
Quick Summary: Simple (only four motors and two pistons) hybrid, stronger as a ramp bot, but can score a few ringers.
Drive
  • 2x CIM (1 per side) with BB 12:1 gearboxes.
  • Custom-manufactured hardened carriers (do not have short pin issues).
  • 6WD with 8" Skyway pneumatic wheels, 3" ground clearance, ~8fps
  • Can climb a 30-degree ramp.
Arm
  • Powered by FP + 256:1 BB gearbox (+ custom machined carrier) + 72:10 additional reduction.
  • 2-joint with simple stick-like end effector.
  • Relative effectiveness of scoring: middle, bottom, top.
  • Boston: scored 2-3 per match on middle/botton row when utilized.
Ramp
  • Narrow-orientation (28") with guide rail that can be lowered or taken off to accomodate side bumpers.
  • Ramp + Platform will fit 2 robots without bumpers, 1 or 1.5 (12" + 4") with bumpers.
  • Designed to passively elevate one robot (20-degree ramp) and actively elevate the second (ramp lifted by 2 pneumatic pistons). Can also actively lift a 2WD or low ground clearance robot that can't clear the top ramp edge.
  • Boston: mostly single passive lifts, a few single active lifts, and one double (passive + active) for 45 points.
At Boston, we were mainly used as a ramp bot, although occassionally we got to put the arm to good use and add on a few ringers. We can also play defense - won't win a pushing match but it's maneuverable enough to get in the way and hard to push through (especially sideways). Autonomous is defensive or setup. Good reliability (no major problems at Boston).
Good luck!!
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
CURIE Discussion - 2007 Championship ALIBI Championship Event 76 15-04-2007 21:59
2007 Galileo Robot Information and Pictures Jeff Rodriguez Championship Event 35 09-04-2007 15:42
Vex Display and Robot Pictures? team222badbrad FIRST Tech Challenge 8 24-05-2005 13:46
BASIC operator interface and robot controller John Gutmann Electrical 2 26-04-2005 21:45
