Go to Post It is not for any other team to say what is beyond a person's or a team's capabilities. That's why they have mentors :-) - preussrobotics [more]
Unread 07-04-2007, 12:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Programming 2004 RC
What do I need in order to program the 2004 Robot Controller and where do I get it?
Thanks.
Unread 07-04-2007, 12:30
Re: Programming 2004 RC
You can use the same compiler as the 2006/2007 RC. You can get the 2004 default code from here: http://www.ifirobotics.com/first-legacy.shtml or you can use this year's default code by following the instructions in Using_a_2005_FRC.txt included in the default code.
Unread 07-04-2007, 12:47
Thanks for the help, but are you sure? I found this on the bottom of this page: http://ifirobotics.com/rc.shtml
NOTE: To Compile 2004, 2005 or 2006 code, use MPLAB ver 7.20 and C18 Compiler ver 2.40 (newer versions can not be used)
Unread 07-04-2007, 12:52
Add 2007 to that list. They all can use the same v2.40 compiler, but nothing newer.
Unread 07-04-2007, 12:55
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Yes. The software that comes on the CD in the KoP has MPLAB 7.20 and C18 2.40. A newer version of MPLAB will work fine (I've been using 7.50), but it's really the C18 version that matters. If you're still not convinced, remember that the 2006 is the same as the 2007, so if IFI says that something that works for 2006 also works for 2004, you can apply the transitive property to see that this year's stuff works for the 2004. Just be sure to follow Joe's instructions for getting the older default code.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 08-04-2007, 17:53
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
ya man, the MPLAB that was goven out this year (i forget which version) will work fine. i'm practicing my programming on a 2005 RC and OI, and it's all the same as the newer stuff. just make sure you follow the instructions from that .txt file mentioned above...i really got burned for not following them.
Unread 08-04-2007, 23:07
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
if you want to compile for the 05 RC, make sure you select the 8520 from Configure->Select Device and use the 8520 lib and linker files
Programming Analog Input from 2004 Controller Danny Diaz Programming 8 30-01-2007 22:44
programming motors with programming kit BorisTheBlade FIRST Tech Challenge 4 01-11-2005 19:03
Mechanical Desktop 2004 DX/AutoCAD 2004 and AutoCAD 2005 coastertux Inventor 4 14-06-2005 09:27
White Paper Discuss: Official 2004 Introduction to Programming Guide CD47-Bot Extra Discussion 4 26-01-2004 20:59
2004 Programming Quick Reference Jeremy_Mc Programming 5 22-10-2003 17:01
