Go to Post HAH! What else am I supposed to do on a weekend? Sleep? - Michael Hill [more]
Unread 07-04-2007, 21:30
Devo1098 Devo1098 is offline
FRC #1098
Devo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really nice
read only?
i saved the frc code to a disk so i can get it to my computer that dosent have internet, but has mplab
i try to open it and it says read only blah blah blah, i think i saved it to the disk wrong
im trying to save the code on a different disk
my computer that has internet dosent have win zip ,
does anyone have the basic code in a not zipped folder that i can some how get?
Thanks
Unread 07-04-2007, 21:39
BenThompson BenThompson is offline
FRC #0237 (Sie-H20-Bots (See-Hoe-Bots) [T.R.I.B.E.])
BenThompson is on a distinguished road
Send a message via AIM to BenThompson
Re: read only?
Windows comes with a basic ZIP program.
Unread 07-04-2007, 21:42
FRC #1098
Re: read only?
it opens up then says this is not a free software, then closes
Unread 07-04-2007, 22:15
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: read only?
do you need an old version of winzip?
http://public.www.planetmirror.com/pub/winzip/?fl=w
Unread 07-04-2007, 22:23
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: read only?
If you're talking about a floppy disk, check to make sure the little tab on the corner isn't closed. This is a read/write protector. When you can see through the little hole, then the disk is read-only.
If you're talking about a CD, CDs cannot be written to and so you should copy the code to your hard disk, then work on it.
Unread 07-04-2007, 22:55
FRC #1098
Re: read only?
i saved the cd rom files to my harddrive and it still comes up with the same message, the files on the disk used to work, but then they started saying read only
im so lost
Unread 07-04-2007, 22:59
MrForbes's Avatar
AKA: Jim
Re: read only?
maybe right click on a file, then click "properties", then find the "read only" box and uncheck it
Unread 08-04-2007, 00:35
FRC #1098
Re: read only?
i tried, only the box is not checked
hmmmm
Unread 12-04-2007, 04:15
TetraBot's Avatar
TetraBot TetraBot is offline
Webmaster / V.P. / Chief Designer
FRC #1516
TetraBot is an unknown quantity at this point
Re: read only?
If your saving files onto a folder, you may want to check and see if you have the ability to change files saved within the folder. You may be trying to acheive the impossible.
If that's the case, try saving the file onto the desktop and then opening it. You should be able to work with your program that way.
Also check to see if your easyC/mpLab license hasn't expired. That could also be causing a problem. Other than that, I don't know what else to say.
Come visit me at tetrabot.com.
Awards
- 2005 SJ Rookie Inspiration Award
- 2005 SJ Highest Rookie Seed
- 2007 SJ Regional Winner
Unread 12-04-2007, 08:10
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: read only?
Are you sure you copied them and didnt just make a short cut?
Unread 13-04-2007, 00:40
TetraBot's Avatar
FRC #1516
Re: read only?
Another Thing,
If you are trying to use a school computer, you may be locked out of certain directories for security reasons, and hence, you aren't able to make changes or save anything onto that directory.
Try creating a folder on the desktop, or some other directory where you have permissions to write to and save your work.
Let me know if this helps.
Awards
Unread 13-04-2007, 17:47
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: read only?
save it to the computer first and then try to open it.
vivek
Answers Only Jeff_Rice Games/Trivia 4 29-12-2004 22:00
My ONLY complaint archiver 1999 7 23-06-2002 22:21
Only 50 days.. archiver 2000 3 23-06-2002 22:11
only 37 days Jgreenwd1 Off-Season Events 0 11-04-2002 09:35
'read' posts that arent read mike o'leary CD Forum Support 4 10-06-2001 11:29
