Go to Post 1. Build a robot. 2. Don’t let it get destroyed. - B-Bot [more]
Unread 07-04-2007, 19:47
CraigHickman
Posts: n/a
pic: Track System
Unread 07-04-2007, 19:53
run the trap!!!
Team Role: Human Player
Re: pic: Track System
Where did you get Inventor versions of the treads?
They were originally designed using solid works, and I haven't been able to do anything with the files.
I don’t know if you’ve thought about this, but I’ve heard that the Outback Treads are completely un-maneuverable in high gear. 997 locked their AM shifters in low gear for this reason. Their robot moved fast enough in low gear!
-Philip J. Fry
Unread 07-04-2007, 20:04
CraigHickman
Posts: n/a
The tracks are undergoing design changes to allow them to turn better all around.
I got the Inventor files through a member of team 997. However, now that I'm learning Solidworks, I kinda want to get them in solidworks so I have real stuff to learn on. Wanna swap?
Unread 07-04-2007, 23:01
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Nice to see this tread system becoming more popular. From what I hear, it's an awesome setup, designed to push! I think our team was planning on getting some for an off-season project, but we'll have to see how it turns out. I can see them becoming a very popular product for FIRST teams.
Unread 07-04-2007, 23:05
FunkyRatDemon's Avatar
FunkyRatDemon FunkyRatDemon is offline
Marketing, PR, Operations, Mascot
AKA: Jake M Masin
FRC #0753 (The High Desert Droids)
FunkyRatDemon will become famous soon enoughFunkyRatDemon will become famous soon enough
Send a message via AIM to FunkyRatDemon
The tracks worked great, I hope that Sam makes your team do awesome!
(670, 997 and 753 fully (ab)used them)
Our website! www.team753.com
Like tracks? We do! For info on using them go here http://outbackmfg.com/pages/1/index.htm
Attending: NW Pacific and UC David Sacremento Regional
Unread 08-04-2007, 03:13
pakratt1991's Avatar
pakratt1991 pakratt1991 is offline
AKA: Tim L.
FRC #0997 (Spartan Robotics)
pakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nice
Send a message via AIM to pakratt1991 Send a message via MSN to pakratt1991 Send a message via Yahoo to pakratt1991
they are going to have different gearboxes and hopefully some other modifications, and Sam from Outback makes them better and better, so hopefully soon with some coordination between teams they will be close to perfect
As for a solid works File...
It's what Sam originally made them in, if you contact him he might be willing to hook you up.
2010 Oregon Autodesk Regional Winner (997, 2130, 1515) (Event Volunteer)
2008 UC Davis Semi-Finalists
2007 Championship Semi-Finalist (494, 254, 997)
2007 Davis Sacramento regional Champs (100, 997, 1458)
2007 PNW regional, Champs (997, 272, 1087)
Unread 16-04-2007, 14:20
RTTComanche17's Avatar
RTTComanche17 RTTComanche17 is offline
12ga Browning
FRC #1662 (Raptor Force Engineering)
RTTComanche17 is on a distinguished road
Beware of (ab)using these track systems. My team (1662) thought about using them but decided against it for a cople of reasons:
1. Track material falls off. Last year we saw 753 at the davis regional and they did very well, bt they (ab)used the eystem so much, tread/track material started to fall off in pieces. This also happened this year where a team on our alliance (dont remember number) left a three inch long by inch and a half wide piece of material on the field.
2. These belts break if (ab)used too much. Just ask 997. In their 6th qualifying match sat. morning at the championships, they were pushed from the side and a belt snapped, leaving one side of the robot disabled. they said it took an hour to change both belts.
3. Teams do not gear them low enough. This year and last year, we have been able to psh or at least stop any robot with tracks. last year we had very low gearing with 4 two inch wide by 8 inch diameter IFI wedgetom traction wheels. We pshed 753 arond no problem. They did have more traction than us, but they were geared so high that they pulled too many volts when they lugged thir cims down low, their robot wold essentially shut down to protect itself, enabling them to be moved across the entire field.
This year we had 6 two inch wide 6 inch diameter IFI wedgetop wheels with a lowered center wheel and a bit higher gearing for mare speed and manuverability. Of the three track systems we encontered this year, we pushed two and stood up the third (they couldnt move us, we couldnt move them).
We love traction wheels We havent benn moved in the last two years!!
A track system cold definately outpush us if you designed them right.
Instead of 5 fps and 15 fps(most teams end up locking them in low gear anyway), try 2 fps and 6-8 fps or 3 fps and 9 fps.
Just tying to provide a little insight, thats all.
What's Your Motivation?
Unread 16-04-2007, 14:37
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I would have to agree that the advantages of a track system just don't outweight there weight penalty as well as complexity, cost, and reliability. A well designed 6 or 8 wheel drivetrain with high traction wheels will perform almost as well in brute strength but be much easier to build, and theoretically less prone to failure. If you break a belt you're completely, however if you break a chain in a wheel based drivetrain you still have partial drive, assuming you have multiple chain runs. Thats just my 2 cents
Mentor 2415
Unread 16-04-2007, 15:06
Alpha 997 Alpha 997 is offline
AKA: Yi Li
FRC #0997 (Spartans)
Team Role: Operator
Alpha 997 will become famous soon enough
Nah. The belts are fine. We made the mistake of trying to move away while being pushed side way. That's what killed the belts. If we just sit there and don't try to move, the belts won't get damaged at all. It didn't take an hour, more like half a hour. And that's because we had to get around our platforms.
Ohhh... The EXIT sign is green so that robots can get out during a fire.
2007-Archimedes semi-finalist
2007-Davis Sacramento Regional champion
2007-Pacific Northwest Regional champion
2005-Archimedes semi-finalist
2005-Archimedes second seed
Unread 16-04-2007, 15:55
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
My team is looking to find a decent drive system that will stay together and work well. Do you recomend this?
Chris
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
Unread 16-04-2007, 17:21
AKA: Sean
I would think that not being able to move when being pushed without snapping a belt would be a serious problem. I know our drivers drive away from people if they are in a pushing match to not lose time. Also snapping those belts and having to replace them costs a pretty good amount of money.
Mentor 2415
Unread 16-04-2007, 20:17
AKA: Tim L.
actually it wasn't that bad, we can move while being pushed from the side with a normal team, but this was against a beefy drive train and the brecoflex belts have a steel whire running in them and rather then jump they snap... while some teams when being pushed from the side move sideways, we do not move at all. just something we have to deal with, next year this wont happen, we are improving the rollers
Unread 16-04-2007, 20:24
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
670 was being pushed around left and right though, at SVR, Davis, and ATL.
I've thought about tank tread -- and while it is cool looking and works well, our team went with 4-wheel tank-style drive and haven't lost a pushing match once (well, maybe once to 1662...)
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 17-04-2007, 00:22
M4 Sherman's Avatar
M4 Sherman M4 Sherman is offline
M4 Sherman is an unknown quantity at this point
All hail the tank track! The tank track is the coolest drive train set up out there. (just look at the M4 Sherman)
But, its not cost effective, and they can be a bit slow and hard to turn. Just look at some of the new Military APCs that use a wheel system rather than tracks.
Unread 17-04-2007, 00:24
CraigHickman
Posts: n/a
For these tracks, they turn just as good as a 6 wheel, and for a full drive system, only cost $1200.
pic: Track drive gear-box sam shawe Extra Discussion 5 05-12-2006 15:01
pic: Dual track, Maximum grip falconmaster Robot Showcase 5 01-02-2006 16:21
Track System Help Needed archiver 2000 0 24-06-2002 00:15
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
