Go to Post All this is sounding like gobbly-de-gook but it is important to understand this gobbly-de-gook. - ebarker [more]
Unread 03-04-2007, 09:51
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Linux and Ubuntu...
Ok, When I usually set up a debian install on a computer, the setup program prompts me for a Root users password, Then I can log onto root for administrative tasks and avoid Typing Sudo Into the Terminal all of the time.
I decided to see What all the hubub with Ubuntu 7 was, and installed it on a computer at my house. It never prompted me for a root pass, and even when I define one in the terminal window... The log-on screen says I cannot log on as admin Through the main logon window.
Thusly, I cannot install Wine or Any programs that don't have Package installers because I don't have privelages to modify anything in /usr/.
Any Idea on how to fix this?
Unread 03-04-2007, 10:08
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Linux and Ubuntu...
sudo still works in Ubuntu, it just uses your user password. The root account is disabled.
Unread 03-04-2007, 10:20
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
Yes, it is... I am just wondering if there is any way to enable it so I don't have to use Sudo, and can maybe do some administration with the GUI.
Or maybe a more long lasting command than sudo, that I maybe don't know ?
Unread 03-04-2007, 12:42
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
su - root
http://www.mikesorrenti.com/
Unread 03-04-2007, 23:15
CraigHickman
Posts: n/a
It's a little off topic, but I'm sure you'll find it quite a stress reliever whenever you get aggravated about something on Ubuntu... type into the terminal:
"apt-get moo"
I'm sure it will make you smile.
Unread 05-04-2007, 20:24
gobeavs's Avatar
gobeavs gobeavs is offline
linux advocate
AKA: Ross
None #1425 (Wilsonville Robotics)
gobeavs will become famous soon enoughgobeavs will become famous soon enough
Send a message via AIM to gobeavs
"sudo passwd root" then follow the instructions and you should have "su" available to you.
"Never in the face of human conflict has so much been owed by so many to so few."
- Winston Churchill on the RAF in WWII
Unread 07-04-2007, 23:29
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
you should be able to use sudo su to get as root in the shell, however if you go in and modify the users you can enable the root account and make it so that you can log in from the GUI at least in 6.10 I don't know about the new 7 version of ubuntu
KK4KQO
http://voltair.us
Unread 08-04-2007, 13:54
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
If you want a root console, try sudo -i and enter your user password
If you really want to enable root, you can enable the root account by setting a password with
sudo passwd root
Then go to System -> Administration -> Login window
Go to the security tab and check:
allow local system administrator login
BTW, the disabled root account actually has a purpose. It is supposed to make your computer less vulnerable to attacks from the outside and the inside (hmm, i wonder what this command does ...)
also, everything can be achieved by using sudo
Unread 26-05-2007, 21:46
cmptrgy412 cmptrgy412 is offline
Robohawks Programmer
AKA: Jacob G
FRC #1985 (Robohawks)
cmptrgy412 is an unknown quantity at this point
I'm not logged into linux right now, and a bit too lazy at the moment, but if you want to actually log in as root, somewhere in the properties, it has the option to allow root login... I'll look that up in a while and edit this post.
[edit]
Yeah, it's under login window preferences.
System->Administration->Login Window
Click the security tab.
Click checkbox in allow local system administrator login.
Now you can login as root.
Just remember, you shouldn't use root as your default user and in fact should use sudo for installing packages, but this is just for reference.
[/edit]
easyC PRO on Ubuntu Linux MattD Programming 5 10-04-2007 19:31
Ubuntu Linux... JoeXIII'007 Chit-Chat 3 13-01-2007 18:52
Linux and the New R/C and Strange ideas... Venkatesh Programming 7 28-10-2003 23:54
Linux And Windows XP Raven_Writer Chit-Chat 4 06-08-2003 18:53
