Go to Post The robot is talking to you, you must listen to find out what might be wrong. - Al Skierkiewicz [more]
Unread 29-03-2007, 17:15
HokieTutorunie HokieTutorunie is offline
FRC #1535
HokieTutorunie is an unknown quantity at this point
Making PWM cables?
Is anyone making there own PWM's. We're home working on our practice bot and low and behold we need more pwm's.
I would think that the wire, connectors and crimpers should be available to make custom lengths.
Anyone have a source?
Unread 29-03-2007, 17:34
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Making PWM cables?
Search on PWM & crimper. You will find this thread with the info you seek.
Joe J.
Team #88, TJ2
Unread 29-03-2007, 21:24
I recommend Hansen Hobbies. Their 1x3 housings, pins, and standard pwm wire are a perfect match for the prefabricated cables in the Kit of Parts. I am a very satisfied customer.
Unread 29-03-2007, 22:52
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
For some parts of our robot, we had to use some of our 22 AWG (I belive) wire that extended about 3-4 feet onto our robot, so the standard PWM wire is not as neccessary as it may seem. Blue White and Red or something along the base colors (Blk, white, red) will do.
I reccomend getting spools of wire to be completely honest, because you can make the PWM's the right size and not have to worry about extensions etc.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 07-04-2007, 15:42
Generator of Entropy
FRC #2973 (The Mad Rockers)
Here is another thread with the specific molex connector numbers, and pay attention to Dr. Joe's instructions in that thread.
For wire we used 3-conductor shielded wire; since the signal voltage is so low in the PWM inputs/outputs it is very sensitive to noise from motors and using a shielded cable rather than the IFI PWM cables can make a huge difference for things like yaw rate sensors or accelerometers. It's a little stiffer too and less likely to flop its way into unwanted areas like gearboxes.
Unread 08-04-2007, 10:37
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Why doesn't somebody with all the parts make a step by step white paper already? It would be very interesting to see that, and then it would provide team with one more very very useful resource rather then buy expensive premade cables.
Unread 08-04-2007, 10:43
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
The crimper isn't cheap either.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 08-04-2007, 11:02
Billfred's Avatar
Billfred Billfred is offline
You're right, it isn't cheap. However, most teams would come out even or ahead compared to the IFI price for PWM cables ($19.95 for four) within a season or two. (And they'd have PWM cables to just the length they want!)
Unread 08-04-2007, 11:56
Feisty_one Feisty_one is offline
AKA: Walter Everett
FRC #1758 (Technomancers)
Feisty_one is just really niceFeisty_one is just really niceFeisty_one is just really niceFeisty_one is just really niceFeisty_one is just really nice
This is a pretty good source:
http://www.hansenhobbies.com/product...Connectors.pdf
We use a $15 crimp tool and have had no problems. Use the economy wire though, because the deluxe wire is too fine.
Unread 08-04-2007, 12:29
The deluxe wire also has thicker insulation that doesn't fit the standard connectors well.
custom PWM cables bruss6 Electrical 6 16-02-2007 08:33
PWM Cables Alex Cormier FIRST Tech Challenge 15 13-08-2006 09:48
PWM Cables zachriggle Electrical 3 04-02-2006 13:54
Bad Pwm cables Greg Needel Electrical 7 18-01-2006 23:13
The PWM Cables amateurrobotguy General Forum 1 22-02-2005 17:42
