Go to Post I think sportsmanship is only one facet of the gp diamond. - Redhead Jokes [more]
Unread 10-04-2007, 00:17
EricH EricH is online now
Re: pic: 25 Base Bot Climbs 1089
Originally Posted by Arefin Bari View Post
6wd isn't a problem for team 1345. I just would like to know how to turn on dime without lowering your middle wheel. Thank you for your offer and I will definitely like to look into the chassis you guys designed this year. =)
What about a slightly (just slightly) larger center wheel? That would slightly lower the center (less than a lower hole), but could be compensated for. Then again, you would run into issues with the wheels running different speeds. (Easily solvable, but not pretty if not solved.)
How & where do you build the bot when it snows and your robo-base (school) is closed? Elgin Clock General Forum 28 03-03-2008 00:12
pic: 1089 and 237 Battle It Out BandChick Extra Discussion 4 22-05-2006 23:29
pic: Team 1089 BandChick Extra Discussion 3 03-05-2005 01:36
pic: Rachel climbs a tree... 1018 Bob Steele Robot Showcase 8 23-02-2005 09:51
Segway climbs a mountain Katie Reynolds Dean Kamen's Inventions 1 28-08-2003 13:41
