Go to Post We might not be as good as 217, or the other traditional "powerhouse" teams... but we are better because of them. Jason - dtengineering [more]
Unread 10-04-2007, 13:46
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
Join timing belts
My team is competing in another competition and we are building a timing belt tread system. Now our problem is the belt did not come closed in a band but open in a strip. Now we cut them to the length needed but what would be the best way to join the two ends.
Unread 10-04-2007, 14:22
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Join timing belts
Maybe the place you got the belt from has some type of connecting part? If you give us a bit more info about the belt, ie. manufacturer and part number, we might be able to provide more help.
Unread 10-04-2007, 16:12
les chortos les chortos is offline
FRC #0773
les chortos is an unknown quantity at this point
Look at buying the timting belt in a complete loop already.- I know we have an industrial belt and conveyor belt supplier in our town and they will volcanize belts together any length you need and and any width. You may need to ask them if they can take "rough top" conveyor belting and put on a "toothed" base - so you can drive it with a timing belt pulley. I saw some robots at GTR with this system. seemed ok.--
good luck.- tracks are a tough cookie to bake.
Unread 10-04-2007, 17:19
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Maybe you'll want to try using a bigger belt size and adding a tensioner to keep it tensioned properly (you can even make the tensioner adjustable!). Timing belts typically don't have lacing options like Conveyor Belts do because they are typically used in high RPM situations, but there are probably some options out there, but I'd doubt how reliable they'll be.
As far as most robots that use treads, BRECOflex is undoubtedly the most popular choice for robots using treads to drive, Superflex Blue is one I'd recommend. Most teams go with Roughtop/Wedgetop Conveyor Belt Tread from McMaster-Carr when putting tread on their wheels. BRECOflex has a document on treads for robots on their site, here.
Unread 10-04-2007, 17:24
GMAdan's Avatar
thank you for the ideas, we brought the belts from Mc Master.
Unread 19-04-2007, 16:03
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
theres this new glue called "the last glue"....i dunno where you can buy it, because we got ours at the boat show...anyways, this stuff is good enough to glue car belts back together to use...
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
Conveyor belts Max Lobovsky Technical Discussion 4 12-01-2006 19:32
Timing belts pros and cons!!!! archiver 2001 3 24-06-2002 00:33
Dual Sided Timing Belts Lachuck894 Technical Discussion 9 14-01-2002 10:10
Belts, Timing Belts, and Automobiles. Anton Abaya Technical Discussion 5 09-01-2002 19:21
