Go to Post Swisscheeseafy - Cutting holes in the robot to decrease weight - alithanar8 [more]
Unread 10-04-2007, 13:16
haroony341's Avatar
haroony341 haroony341 is offline
FRC #0341 (Wissahickon HS & NMTCC) FRC#2234 (The Episcopal Academy)
haroony341 is an unknown quantity at this point
Send a message via AIM to haroony341
AM servo delayed or no shifting
working with a rookie team this year, we decided to go with the Gen 2 AM 2 speed servo shifters. 2 years prior while working with 341, i worked with the pneumatic shifters but because of weight, 2234 wasnt able to have a pneumatic system. during the build season we were able to get the servos working but had trouble on our last day of testing before ship. the right side's servo didnt seem to be powerful enough to shift. it can be seen struggling. at chesapeake, our first regional, i switched out the servo. but it still need help. using a 2 stick tank drive, we had to shake the joystick to help the servo shift up. we added grease, it got a little better but still have delay issues. there is about a 2-5 second shifting delay of both gearboxes. we also have issues where it will shift when we are tethered but doesnt always work through a radio connection when we are on the field. does anyone have any suggestions we can try when we get to atlanta? could it be a programming problem?
thanks in advance
Drexel University Class of 2009 -- Computer Engineering
Team 341 Miss Daisy // Wissahickon High School @ NMTCC
http://www.team341.com
Team 2234 // The Episcopal Academy http://www.ea1785.org/robotics
Unread 10-04-2007, 13:25
Hieb Hieb is offline
Hieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to behold
Re: AM servo delayed or no shifting
It could be a programming problem, although without seeing the code I couldn't really say for sure. One thing to check is the charge on your backup battery. The servos are powered by the backup battery, so when it is run down they don't shift well. From 2014s experience, the AM servo shifters worked great with no noticable delay in the shift. And if it does turn out to be the state of the backup battery, consider the charging circuit from IFI--that way you make sure you are running off of a full charge when you need to shift.
Unread 10-04-2007, 13:28
haroony341's Avatar
generally how long does a backup battery last? we waont be able to make the circuit in time, also, what is the best method of charging the batteries? i know you can just leave them on the charger for an extended period of time.
Unread 10-04-2007, 13:31
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
If it's not software or the backup battery...
Don't use heavy grease on the shifting dog gear. Use a lighter, thinner lubricant, like WD-40 or a 3-in-1 oil.
Good luck,
Andy B.
Unread 10-04-2007, 13:39
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
From what I read the charger that came with the kits this year is just as likely to ruin your backup battery as it is to charge it. Buy a good quality battery charger and some extra backup batteries.
Unread 10-04-2007, 13:41
If you're using the camera, not very long. Using this year's yellow battery, we'd get less than a half hour of total time before the camera got flaky, and the servos lost strength shortly afterward.
Do not leave them on the "charger" supplied in the 2007 Kit of Parts! It is certain to overcharge them, and likely to damage them. The best method is to use a true charger designed for a 7.2v NiCd battery pack, like the ones supplied in 2006 and 2005.
We use the IFI-approved (but not IFI-supported) on-board charging circuit. It's very liberating to not have to worry about charging the backup battery. This is likely to be especially important at the Championship, as the RC will stay running on backup power for quite some time after the main breaker is switched off following a match, and the long walk back from the field means the pit crew won't be able to notice it and shut it the rest of the way down quickly.
Unread 10-04-2007, 13:42
Mark Pierce Mark Pierce is offline
FRC #0085 (B. O. B.)
Mark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant future
generally how long does a backup battery last? ... what is the best method of charging the batteries?
The useful charge on a backup battery varies a lot based on usage. we're not using a camera or servos this year and we could run all weekend on a single charge, last year's lasted about two or three matches, (a servo and a camera).
We've had good luck using the pre-2007 chargers. If you don't have one available, stop by Team 85's pit in Archimedes. I'm pretty sure we still have two in the tool box (on it's way south already). It's quite easy to monitor the backup battery voltage on the operator interface. We like to see a voltage of 7.8 volts before starting a match.
Unread 10-04-2007, 13:58
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We went through camera battery issues as well.
We had problems with the IFI circuit. We had the program set up to charge when the battery dropped under 7 and to stop when it was over 8.5 (at least I think that was my last code, I'd have to check). It will attempt to charge the main battery with the small one when the main voltage gets low. We actually had many instances where our little cruddy yellow batteries were drained from a full charge by the main battery during testing from the IFI circuit.
Likewise, they don't take much charge to begin with, and the supplied chargers will nuke the battery if you're not carefull.
We ended up removing the charging circuit from the robot in annoyance.
A much better solution, if you can can stand to part with $30, is to go to radio shack and pick up one of the 7.2 hi-amp hour batteries for radio control cars. They come with an auto-sensing charger. Then use the yellow battery for testing, and the hi-amp battery for competition. The charge on one big one easily lasted us an entire day of competition running only the camera.
One other thing. We found that if you push reset on the robot controller after killing main power, it will stop pulling from the backup battery as well.
Unread 10-04-2007, 22:20
foote stepped in
AKA: E. Foote
FRC #0868
We used the AM servo shifting, and didn't have any problems.
When we wrote our code, we didn't bother trying to find the value which made the servo shift left or right... we went with 0 and 255 (if the servo didn't shift immediately, the I in its supposed PID loop would take care of it).
Best of luck!
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 10-04-2007, 23:05
haroony341's Avatar
thanks for all the replies!
is there anything else we can do to help it along mechanically? or should the light grease and making sure the backup battery is good be enough?
also, what could be causing the shifters to work while tethered but not on the field while in play?
Unread 10-04-2007, 23:14
Bharat Nain's Avatar
Our team bought higher quality backup batteries which last longer. There are other threads suggesting different batteries. We use servos for our brakes and they(ifi batteries) wear out after about 4 or 5 matches. Good luck.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 10-04-2007, 23:16
haroony341's Avatar
how long is the recommended charge time? i know you cant leave them on for too long
Unread 10-04-2007, 23:33
I don't know what the recommended charge time is because I do not take care of the backup batteries. However, once the charge of the battery reaches around <7.2v to around 8v you know it is fully charged. Perhaps someone on your team can experiment and find out approximately how long it takes.
-= Bharat Nain =-
Unread 11-04-2007, 00:01
REVving up for a new season
FRC #2848 (All-sparks)
check and see what variables you have assigned before and after auto mode and that they are consistent. Because when the RC changes modes from auto to teleoperated, it will keep the last given assignments. I would just check your code and see if you have anything in the base code that gets re-assigned in the auto mode. A good way to test this would be to run the routine with a dongle in the same order that the field works.
Disable, Auto, Disable, Enable and see how that works when you are tethered.
*excuse the fact that I may have worded things wrong as I am not a software guy. I am re-stating the solution to a problem we experienced this season.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 11-04-2007, 00:25
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Also make sure you have a good electrical circuit, a bad wire could be the root of all this. How did you run the shifters much before you started having problems with them? If you did with no problem, before hand check and make sure everything is symmetrical on each side from a mechanical aspect, you might have a buildup of gunk on the shifter shafts, also check to make sure nothing is inside the dog gear itself. Its more likely that you'll have a mechanical problem here over a programming or electrical issue.
Delayed Robot Reactions =Martin=Taylor= Programming 4 04-03-2007 16:12
Shifting transmissions: servo or pneumatics? gnirts Motors 8 15-01-2007 21:52
paper: Servo Vs. Pneumatic Shifting GMAdan Extra Discussion 1 04-12-2006 11:48
FIRSTcast will be delayed Matt Krass General Forum 8 12-09-2005 12:07
Registration Delayed David Kelly General Forum 35 22-09-2001 23:30
