#16
Re: AM servo delayed or no shifting
We had similar issues - but we found as the gear boxes were shifted more and used more -some of the rough "machining " burrs and such came off and they worked pretty consistant. From what I saw you need about 1-2 hours of driving on the chassis and a lot of up and down shifting to "break them in" - also the battery issue caused us grief. - you definitely need lots of juice if you want them to shift 10-20 times during a match. - we also programmed a slight delay 100 milliseconds 1/10 th second from the time the shift button was pressed to the time the gear would shift. - this would remove the load from the 2 gears in mesh and give the servo an easier - lesser load - to overcome when shifting. Basically if you were in a tough pushing match (low gear) and wanted to shift to high gear- the servos need to over come the gear loads- it would be very hard to do. - but by adding a delay in the motor power- it relieves the gears loads and thien slips into gear smoothly. - try it.- ask your programmer- to add a .100 second delay in power to the drive motors. pwm=127 or "0 rpm" . shift servos- then add power again. it should slip into gear within 1 or 2 eye blinks and go - it will appear to be seamless and not slow you down much- if at all.
good luck! |
#18
hey on the backup battery problem you could consider soldering up the IFI suggested onboard backup battery charger, found on this link.
it charges the backup battery off the main, but has a diode so that if the main is lower then the backup, then the source for the RC's power is the backup battery alone. -q |
#19
Your problem may not have anthing to do with the servo's, Battery, Trans or code. Did you update to the latest master code and have your radio updated. Our team had problems with the ramp deployment trigger and I'm convinced it was the Radio issue. We did not upgrade to the latest master code because of lack of time and went thru the regional with a delay problem with ramp release. You could have a similiar problem.
#20
| Delayed Robot Reactions | =Martin=Taylor= | Programming | 4 | 03-04-2007 04:12 PM |
| Shifting transmissions: servo or pneumatics? | gnirts | Motors | 8 | 01-15-2007 09:52 PM |
| paper: Servo Vs. Pneumatic Shifting | GMAdan | Extra Discussion | 1 | 12-04-2006 11:48 AM |
| FIRSTcast will be delayed | Matt Krass | General Forum | 8 | 09-12-2005 12:07 PM |
| Registration Delayed | David Kelly | General Forum | 35 | 09-22-2001 11:30 PM |
