Go to Post And the only thing that can really measure that is when you look a kid in the eye, say "We've got a problem..." and you see them smiling, "Bring it on." - dtengineering [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 13-04-2007, 19:30
ThomasP's Avatar
ThomasP ThomasP is offline
FRC #1255 (Blarglefish)
ThomasP is just really niceThomasP is just really niceThomasP is just really niceThomasP is just really nice
Send a message via AIM to ThomasP
Easiest way to block spam
Our guestbook has been attacked by spam bots quite a bit recently and I finally got around to stopping the spam with a neat little trick from the ASP.NET AJAX Control Toolkit that real users won't even notice (as long as they have Javascript enabled...)
PHP Code:
<?PHP
if($_POST['Bot'] == "Yes")
        echo
'You're a botStop messing with my form!'
    else if($_POST['
Bot'] == "No")
        echo '
Hi ' . $_POST['name'] . '!'
<form action="test.php" method="POST">
Name: <input type="text" name="name">
<input type="hidden" id="Bot" name="Bot" value="Yes">
<script type="text/javascript" language="javascript">
document.getElementById('
Bot').value = "No"
</script>
<input type="submit">
</form>
A lot of spam bots don't execute javascript so you are safe from them. For people that disable javascript, you can modify the above code to do something like...
PHP Code:
<?PHP
if($_POST['Bot'] == "Yes") {
I'm not sure if you're a bot or not... what is five plus eight?<br />
<input type="text" name="HumanTest">
<input type="hidden" name="name" value="<? echo $_POST['name'?>">
} else if($_POST['Bot'] == "No" || $_POST['HumanTest'] == "13" || $_POST['HumanTest'] = "thirteen") {
        echo
'Hi ' $_POST['name'] . '!'
} else {
document.getElementById('Bot').value = "No"
</script>
</form>
And that will allow regular people that have javascript enabled to not be bothered by proving they're human while also allowing for the occasional user that disables it.
Disclaimer: It has been a while since I've wrote any PHP so I can't guarantee any of that PHP code will work.
Unread 13-04-2007, 22:31
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Easiest way to block spam
The code looks good so far, but I found an error in the second block of code. The changes I made are added in red:
    } else if($_POST['Bot'] == "No" || $_POST['HumanTest'] == "13" || strtolower($_POST['HumanTest'] == "thirteen")) {
        echo 'Hi ' . $_POST['name'] . '!'
    } else {
This change fixes the single equals sign operator error, as well as added in a strtolower() command, so that if the user inputs Thirteen or tHirTeeN you know they still had the right answer.
Art Dutra IV
世上无难事,只怕有心人.
Unread 14-04-2007, 03:22
ThomasP's Avatar
    } else {
Thanks artdutra, I've been doing too much with VB.NET and SQL at work lately, I kept starting to type "OR" instead of "||" also but managed to catch all of those mistakes.
I was thinking about the spam blocking code a minute ago and think there may actually be a better way to do the thing...
PHP Code:
<html>
<body>
<?PHP
if((strtolower($_POST['Bot']) != "thirteen" && $_POST['Bot'] != "13"))
        echo
"You're a bot! Stop messing with my form!";
    else
        echo
'Hi ' $_POST['name'] . '!';
document.write('<input type="hidden" id="Bot" name="Bot" value="Yes">');
document.getElementById('Bot').value = "13";
</script>
<noscript>
  What is eight plus five? <input type="text" id="Bot" name="Bot" />
</noscript>
</form>
</body>
</html>
I also caught another error when I actually tested that before posting... I had used apostrophes in my PHP strings and had one in "You're", switched that string to quotation marks.
Cheapest and easiest way to slow down a motor sanddrag Technical Discussion 41 21-12-2005 07:26
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Wicked Easy Way To Block Pop-up Adds! MattK Website Design/Showcase 18 17-02-2003 20:33
Anyone knowwhere to buy maxi block distribution block? BrianB Kit & Additional Hardware 0 23-01-2003 12:46
Any way to block out certain forums? Ken Leung CD Forum Support 5 02-09-2002 22:07
