Go to Post By the way, if anyone happens to find my dignity lying around anywhere, please let me know. I seem to have lost it completely. - dlavery [more]
Unread 15-04-2007, 00:31
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
15 Pin Steering Wheels/Throttles
Does anyone have links to 15 Pin steering wheels and/or throttles?
We(4 people) have been looking for some all night on froogle and other sites and haven't found many
Unread 15-04-2007, 01:13
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
Re: 15 Pin Steering Wheels/Throttles
Have you thought about building your own?
I don't think it would be that difficult and you could add custom switches and any other features that the COTS models do not have.
You may want to check Ebay (search for Steering Wheel gameport) I have found some steering wheels but no throttles.
Unread 15-04-2007, 02:13
We were given an Xbox steering wheel that had a potentiometer in it. I rewired it to use the 15 pin adaptar, and it has worked nicely since.
Find a working wheel with a pot in it and rewire it to serve your purpouses.
Unread 15-04-2007, 21:10
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Team #1388 has used a Saitek steering wheel that we've found on ebay for the last 3 seasons. They run about $5~$15 new.
Throttles are going to be a little bit harder to find. Another student on our team did find a flight throttle for us in 2005, but I wasn't happy with the way it worked. I would just recommend using a joystick.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 16-04-2007, 01:46
AKA: Dr. Brooks
no team (WRRF)
Search for the Saitek R100 steering wheel on Google.
There are many sources for these steering wheels.
It is no longer made, but there is still some new old stock
out there.
For the "throttle" you still can't beat the CH Products flightstick.
This is no longer available new, but they come up on ebay now
and then. Check ebay every night and place your bid when you see
one.
Euene
Unread 01-07-2007, 00:54
ECarlson's Avatar
ECarlson ECarlson is offline
AKA: Eric Carlson
#0116 (Epsilon Delta)
ECarlson has a spectacular aura aboutECarlson has a spectacular aura about
I don't know where to get one now, but we (Team 116) used one for the 2001 season. It was my own personal steering wheel, which was a Mouse Systems BogeyMan Racing Wheel. Here is a photo of it from a post-season outreach event we did that year with Dean Kamen (and, of course, Dave Lavery) at the U.S. Department of Commerce, and there are a few other angles in the same album:
http://www.invisiblerobot.com/roboti.../p2148842.html
UPDATE: Looks like one is available on eBay at the moment. Link
- Eric
www.InvisibleRobot.com Updated: August 24, 2008
Over 28,000 FRC & FTC Photos , Team 116 OI adapter board info
Unread 14-07-2007, 04:38
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
We (team 1625) bought a saitek X52 joystick with throttle and used that to control the robot. We took it apart and wired all the buttons and switches into a 15pin db15 port to plug into the o/i
works great!
Steering wheel radicalnerd Technical Discussion 30 31-05-2007 00:56
Steering Wheels Chris_Elston Programming 3 17-01-2005 15:31
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
tank steering archiver 2000 10 23-06-2002 22:28
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
