| My motors are hot for you! |
Thread Tools |
Rating:
Display Modes |
Re: Help Getting Started with VEX programming.
In easyCPro we made all the features avalible from the FRC library for Vex.
All you have to do is goto Robot controller setup and switch to VEX Features include but are not limited to. - Quad Encoders - Gear Tooth Sensor - CMU Cam - Interrupt Watcher - Analog Devices Gyro 80,150,300 Deg/sec - Accelerometer - 'C' Syntax Editor - Initialize in Competion Templates - Ability to Name Your Ports - Case-Switch Commands (Though this may be added to V2 soon) No extra programming cable is required and you wire the sensors the same as your would on the FRC robot except the camera which I have made a diagram on how to use it. http://www.chiefdelphi.com/forums/sh...ad.php?t=52573 Last edited by Kingofl337 : 16-04-2007 at 09:04. |
| Programming - Getting Started | Mark McLeod | Programming | 80 | 16-04-2008 23:37 |
| Problem getting started with USB 6009 | JimGRobot | LabView and Data Acquisition | 1 | 18-12-2006 09:15 |
| Getting Started with Scripting | LBK Rules | Programming | 2 | 15-01-2005 01:28 |
| Programming and Electronics — Getting Started | Sidney San Martín | Technical Discussion | 7 | 12-01-2005 15:25 |
| Help needed for getting started! | chantilly_team | Programming | 4 | 27-10-2004 08:29 |
