Go to Post I think Dave has been spending time on icanhascheezburger. Either that or the fumes from his rendering machines have affected the grammar control portion of his brain. - rsisk [more]
Unread 26-01-2007, 14:45
Billfred's Avatar
Billfred Billfred is offline
pic: A little surgery--ready for tread!
Unread 26-01-2007, 14:49
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: pic: A little surgery--ready for tread!
You should vaccuum the dust out of those bearings. We did the same, then trued them on a lathe. If you don't have a lathe available, perhaps a stationary belt sander, or a sanding drum in a drill press, and use a bolt through the wheel bearings to hold them down on the table.
Unread 16-04-2007, 13:43
Billfred's Avatar
I just re-found this picture, and I wanted to make one important note for anyone reading this down the line:
We screwed up (pun very much intended) on these wheels in one important area: we didn't use locknuts on the screws to hold on the sprockets. I remember us adding some Loctite to these nuts, but it apparently didn't hold. The result was us losing five of six screws on the center wheel sprocket, forcing us to miss our next match (which we lost by two).
Moral of the story? Locknuts, and check them each match.
pic: Almost ready for testing Doug G Robot Showcase 4 04-02-2006 18:49
Steve Jobs Undergoes Surgery For Cancer Joe Matt Chit-Chat 2 02-08-2004 12:06
pic: Getting Ready For Comps CD47-Bot Extra Discussion 2 16-02-2004 13:10
Ready for a little Mayhem Todd Derbyshire Off-Season Events 1 27-05-2003 23:25
pic: 111 Ready for a Challenge CD47-Bot Robot Showcase 4 05-03-2003 15:25
