Re: pic: Track System
670 was being pushed around left and right though, at SVR, Davis, and ATL.
I've thought about tank tread -- and while it is cool looking and works well, our team went with 4-wheel tank-style drive and haven't lost a pushing match once (well, maybe once to 1662...) |
All hail the tank track! The tank track is the coolest drive train set up out there. (just look at the M4 Sherman)
But, its not cost effective, and they can be a bit slow and hard to turn. Just look at some of the new Military APCs that use a wheel system rather than tracks. |
For these tracks, they turn just as good as a 6 wheel, and for a full drive system, only cost $1200.
$1200? Maybe you just didn't elaborate, but that's illegal. There's a maximum price per component of $400. In addition there is now a rule that says entire subassemblies cannot be purchased from a vendor. Given that the above is true, even if you split the system into two sides, you're looking at $600 per component, and you still have a complete subassembly, which clearly doesn't work with the 2007 rules. I was under the impression teams using the tracks were all sponsored by Outback Manufacturing, not paying for the tracks. Could someone clear that up? |
The tracks cost $300 a piece (2x=$600), and the material is cost covered by the team ($600), while Sam does the machining for them. Since you are not purchasing a finished assembly, rather the costs associated with the manufacturing, they do not fall under the same rule.
$1200 seems a bit ridiculous for a drivetrain. Does that include transmissions, because I guess that would make it a little more comparable to a wheeled drivetrain.
#7
We're talking about two different rules. You're talking about manufacturing costs. I'm talking about the fact that you cannot buy a completed subassembly under the 2007 robot rules, which is exactly what these tracks are. |
#8
#9
Both. The center pulley is lowered about a tenth of an inch. I also watched these, got a chance to play with them, have the CAD, and have done massive research on them.
#11
I think that the center roller should be set lower. The little difference it had pretty much didn't matter on carpet when 100 lbs of robot is pushing down on it.
#12
So you guys think that if AndyMark sold their transmissions unassembled and billed you for the parts individually that they could be selling them for more than $400? Not quite.
No matter how you try to justify it, $600 worth of parts that are meant to be assembled together is the same as a $600 part... I don't see where the argument is. |
#14
If they were to be sold as is, I think they should be illegal. |
#15
| pic: Track drive gear-box | sam shawe | Extra Discussion | 5 | 05-12-2006 15:01 |
| pic: Dual track, Maximum grip | falconmaster | Robot Showcase | 5 | 01-02-2006 16:21 |
| Track System Help Needed | archiver | 2000 | 0 | 24-06-2002 00:15 |
| Quad- 1/2 track drive system | Ben Mitchell | Technical Discussion | 24 | 30-01-2002 11:55 |
