Go to Post There's no problem another CIM motor wouldn't fix! - Tom Bottiglieri [more]
Unread 16-04-2007, 20:37
BBnum3's Avatar
BBnum3 BBnum3 is offline
Ridiculously proud of MN First
AKA: Nat Thompson
FRC #1816 (The Green Machine)
BBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to behold
Send a message via AIM to BBnum3
Has this ever happened before?
I've been seeing a lot of heated discussion on these forums lately, so I thought I'd lighten it up a little bit with this amusing story from the Newton Finals.
Our team has two ramps, and when lifted they are pretty much even with the top level of electronics, as seen here. The main breaker switch is very close to the edge of the ramps.
We had no problems with this setup until the second match of the Newton Finals. Team 1592 and their big wheels drove up our ramps at the end of the match. There was one unfortunate side-effect: They turned us off! Their robot drove on the main breaker switch and we lost power, but as intended, the pneumatics kept on lifting. The IFI rep at the field found it very amusing and said he had never seen it before. It was a funny end to a great day of matches on Newton.
Founding member of Team 1816.
Unread 16-04-2007, 20:43
teenmisfit's Avatar
teenmisfit teenmisfit is offline
AKA: John Willis
FRC #0501 (PowerKnights)
Team Role: Driver
teenmisfit has a spectacular aura aboutteenmisfit has a spectacular aura about
Re: Has this ever happened before?
haha wow thats sweet luck
[*IMG]http://img.photobucket.com/albums/v437/daunte2moss07/FIRST/newtonuserbar.jpg[/IMG*]
Unread 16-04-2007, 21:03
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
In 2005, we managed to turn ourself off at a scrimmage when the gripper on our arm flipped backwards and hit our main breaker.
Unread 16-04-2007, 21:12
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
The only ways I've ever accidentally turned off my robot is by blowing the 120A breaker. Whoops.
Unread 16-04-2007, 21:13
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
And the best part is that you guys still lifted the ramps. That is amazing! Good job with that!
I win! XD
Unread 16-04-2007, 21:23
flightofone flightofone is offline
AKA: John Clayton
FRC #2104 (Colonel Robotics)
flightofone is just really niceflightofone is just really niceflightofone is just really niceflightofone is just really niceflightofone is just really nice
Send a message via AIM to flightofone
At the Boston regional, my daughter's team 1100 swapped in a fresh battery for one match, but ran the battery cable over the forklift mechanism. They drove out, grabbed a tube, raised the forklift and unplugged themselves. It runs in the family - at the UTC regional our team 2104 ran the battery cable over our pneumatic ramp deployment arms. Luckily gravity and springs take over once the piston pushed out the ramps, and unplugged us.
There's a fine line between fishing and just standing on the shore like an idiot. - Stephen Wright
________________________________________
2007 UTC Regional - Finalists (thanks 25 & 176)
Unread 16-04-2007, 21:31
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Our team has a pin mechanism that releases our ramps. This is pulled by a spinning cable with the pin attached. When the motor is turned on, the pin pulls, and spins around.
We had not tried our ramps using some new code I wrote until our first match at our first regional. When the driver deployed the ramp, the bot shut off. We were very confused as to why this happened.
After further inspection, we realized that this pin mechanism was placed directly over our 120A breaker. The pin actually shut the bot off (a self 'destruct' bot!)... The solution was to change the code to make the pin go the other way
Jacob
Unread 16-04-2007, 21:48
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Way way back when alliances were really new, you had to lift kick balls into a trough made of steel tube. So we had a multi-jointed arm and were trying out a chassis made of bent sheet, so it was mostly flat on top. The arm sort of folded up and part rested on top of the robot. Unfortunately we rushed out one round and our battery cable was up there as well. So the match starts, we start to deploy our arm, and about 2 seconds later, we're sitting there, having disconnected our own battery.
Unread 16-04-2007, 23:49
L.A. 2005: three robots on one side, three on the other. Well, that's how it started, but one robot was just slightly out of the size box and wasn't allowed to get back in. This left a high stacking bot and a low under-goal bot. The under-goal robot went out and tried to spill a tetra under a goal--and died. They'd hit their main breaker. The remaining robot lost the match. (Two of the robots on that alliance went on to win the regional.)
Unread 16-04-2007, 23:52
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Several times (twice at St. Louis and once at Midwest) our radio cable was unintentionally placed in range of our drive system's module rotation chain. We powered on for a few seconds, and then the modules rotated and the chain ate the radio cable, killing us for the match. Very frustrating!
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 16-04-2007, 23:57
FixToTheMax's Avatar
FixToTheMax FixToTheMax is offline
Robot Rock
AKA: Zachary Diaz
FRC #0004 (Team ELEMENT)
FixToTheMax is an unknown quantity at this point
Send a message via AIM to FixToTheMax
I can't remember who it was, but while I was in our Pit during the Championship, a mentor from some team mentioned unlucky happenings with game pieces. He said how in 2005, their arm and no mechanism for securely locking the tetra in place, and it slid all the way down their arm into their electronics board. Fortunately, no victors were cracked or broken. Unfortunately, one of the 4 points of the tetra landed right on the off button for their 'bot, and they turned themselves off. We both had a quick laugh about it, seemed pretty unfortunate, but all in good humor.
Unread 17-04-2007, 00:00
CraigHickman
Posts: n/a
We sent a battery flying about 25 feet.... We had forgotten to tighten the velcro strap on the battery, and went into a high speed spin, and launched the battery. This was last year, in Aim High. It was actually quite impressive...
Unread 17-04-2007, 00:10
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Impressive or Deadly?
Knowing the older Exide batteries that weigh more than this year's MK's....
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 17-04-2007, 01:28
Eldarion's Avatar
And contain highly corrosive gel in a brittle plastic case....
-- Thomas Paine
-- Anonymous
Unread 17-04-2007, 05:13
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
I am proud to announance that this is the first year we have NOT thrown a battery off the bot. So much for Team 237 Traditions
Has anyone thought of this college course before? Alex Cormier College & University Education 8 15-08-2006 09:53
what is the wierdest thing that has ever happened to you? BurntTurkey29 Games/Trivia 2 19-02-2006 17:05
Has anybody ever seen this article? Alex Cormier Chit-Chat 0 03-02-2004 22:42
Has this ever happened to you? Alaina Chit-Chat 12 30-03-2003 22:50
Ever seen this serial port problem before??? Aidan F. Browne Programming 5 05-02-2003 12:03
