Go to Post When the world gives you lemons make lemonade serve it at your press conference to expand the program. - Koko Ed [more]
Unread 17-04-2007, 12:35
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: 56mm Banebot problems @ Championship
We had problems with one of our gearboxes, but this was a new gearbox that we had not added washers as spacers. Once we added the washers everything worked again. We started looking for other banebots 56mm and we found that few teams had issues at the championship. Most of the teams in Galileo had working banebots. Most teams never had a problem thoughout the entire FIRST season because they performed preventive maintenance (adding washers, changing the carrier plates).
I was also impressed with the number of teams who used banebots for the arms and joints for many different functions. Banebots has come into the FIRST community in a much different way then many of the accepted FIRST companies . Overall, banebots should continue to provide for the FIRST community for years to come. What FIRST actually puts into the KIT next year, I think it should have some type of shift mechanism, either dewalts, andymark, or banebots (with shifting).
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Banebot 56mm transmissions are Available Teched3 General Forum 9 04-04-2007 16:23
Redrilling 56mm Banebot Carrier Plates Teched3 Technical Discussion 2 04-04-2007 15:43
Banebot 56mm gearbox - double D - RELOADED Joe Johnson Motors 82 09-02-2007 14:07
Banebot 56mm gearbox - double D related Joe Johnson Motors 78 31-01-2007 23:55
Attempting to Cut BaneBot 56mm Shaft edthegeek Motors 6 15-01-2007 08:51
