#8
Re: 56mm Banebot problems @ Championship
Whether or not you experienced problems, the banebots have been proven unreliable.
If I were designing a single speed drivetrain to run off of one, or two small CIMs I would use the AndyMark single speed gearbox. Not only is it cheaper (when running two CIMs), it is lighter and much more versatile. It can run a Big CIM without any modifactions and with a little ingenuity, it can be modified to run 3 or 4 of the following motors; Big CIM, small CIM and fischer price in the AM planetary. For $98 and 2.91 lbs, I don't understand why ANYONE would choose the banebots over the AM planetary. |
| Banebot 56mm transmissions are Available | Teched3 | General Forum | 9 | 04-04-2007 16:23 |
| Redrilling 56mm Banebot Carrier Plates | Teched3 | Technical Discussion | 2 | 04-04-2007 15:43 |
| Banebot 56mm gearbox - double D - RELOADED | Joe Johnson | Motors | 82 | 09-02-2007 14:07 |
| Banebot 56mm gearbox - double D related | Joe Johnson | Motors | 78 | 31-01-2007 23:55 |
| Attempting to Cut BaneBot 56mm Shaft | edthegeek | Motors | 6 | 15-01-2007 08:51 |
