Go to Post The biggest fallacy in FIRST is the belief we are just a bunch of different teams. We are ONE BIG TEAM with a lot of sub teams for the purpose of competition. - Al Skierkiewicz [more]
View Poll Results: What IDE Do You Use?
MPLAB with Default Code 25 48.08%
MPLAB without Default Code 8 15.38%
Microsoft Robotics Studio 0 0%
VI or VI Clone 4 7.69%
Other (Please Specify) 15 28.85%
Voters: 52. You may not vote on this poll
Unread 26-03-2007, 22:17
Bob22341 Bob22341 is offline
FRC #1870
Bob22341 will become famous soon enough
IDE
Just wondering what IDE other teams are using.
p.s. If you are using MS Robotics Studio, how do you like it?
Unread 26-03-2007, 22:52
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: IDE
I use a combination of FusionEdit and MPLab.
Edit: You forgot EasyC on your poll.
Eric Haskins KC9JVH
Unread 27-03-2007, 13:29
FRC #1870
Re: IDE
Oops, I knew I was forgetting something.
Is there any way to edit a poll? I can't find it.
Unread 27-03-2007, 14:02
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Re: IDE
emacs
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 27-03-2007, 16:14
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: IDE
code::blocks
Unread 27-03-2007, 16:43
thegathering's Avatar
thegathering thegathering is offline
Angry Troll Lurking in the MUD
AKA: Ben
FRC #1885 (Robocats)
thegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to behold
Send a message via AIM to thegathering
Re: IDE
MPLabs for the compiler, often LCC-WIN32 for editing.
*2006 Champion Rookie All Star Award.
*2 x 2006 Regional Rookie All Star Awards.
Unread 30-03-2007, 19:11
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: IDE
Eclipse.
Unread 01-04-2007, 17:02
JonathanLKS JonathanLKS is offline
Code::Blocks
FRC #0610 (The Coyotes)
JonathanLKS will become famous soon enough
Send a message via MSN to JonathanLKS
Re: IDE
Code::Blocks
Unread 01-04-2007, 19:43
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: IDE
We use MPLab with default/Kevin Watson Code, even though it is a horrible IDE. Still, it is faster using MPLab than using a good editor/ide and then using MPLab to compile.
I was thinking about making a compiler script that does the same thing as MPLab, but I'm just too lazy
Unread 01-04-2007, 20:52
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
Re: IDE
That is why you set up your 'good' IDE to use the mcc18 compiler
Unread 02-04-2007, 02:49
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Re: IDE
I need help to setup Code::Blocks with mcc18
-Borna Emami
Team 0x27
Unread 02-04-2007, 18:46
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
Re: IDE
We setup a tree of components and use gmake to tie everything together. We do not use mplab at all, but we do use c18 in command line mode to do the builds.
We don't have a particular GUI, but we use a variety of tools to edit the source.
We can build components individually with their own main() and test functions. Thus we can build a file that only knows how to run the drive train, or we can build a program that only knows how to manipulate the tube lifter.
Most sub projects know only about themselves and some of the central services (ie timers). One sub project pulls in all the others to create the code that runs the complete robot.
We use Subversion for source code control.
This setup is very modular, but we have had a few instances where we needed to be careful of the limited path lenght support in C18.
Unread 16-04-2007, 21:03
Ezbez Ezbez is offline
AKA: Tom Brooks
FRC #0138 (Entropy)
Ezbez is an unknown quantity at this point
Re: IDE
My team is currently using MPLab, but we are not happy with it. We'd love to use another IDE, but I haven't yet found any information on how to use other IDEs. In particular, we would like to use Visual Studios. Code::Blocks or something like that would be fine, too. Where can I find information on using these or other IDEs with MPLab's compiler?
Unread 17-04-2007, 20:22
AKA: Jamie Bliss
Re: IDE
Visual Studio is pretty much out of the question, by most accounts.
Eclipse has several threads (and I'll help you with it).
Most of the other IDEs have threads somewhere, IIRC.
Unread 18-04-2007, 08:35
AKA: Tom Brooks
FRC #0138 (Entropy)
Re: IDE
Thanks for the reply. If Visual Studios is out of the question (I find it odd that it's on this poll if it can't be used), then Code::Blocks would probably be our next choice. We've got rather slow computers, so running Eclipse might be rather demanding for them (TBH, Visual Studios probably would have been, too). I found some information on Code::Block on this forum, but the link to the makefile that the thread used was dead. If I could get some help setting up Code::Blocks, that would be great. I really don't have a clue on where to begin (I have no experience with makefiles, or anything else related to this subject).
Portable IDE Nitinol Programming 14 04-02-2007 03:23
Piklab IDE Adam Y. Programming 0 20-01-2007 16:07
MPLAB IDE rholokleolke Programming 13 08-12-2006 18:32
IDE buss Programming 2 08-01-2005 16:16
Php Ide Raven_Writer Website Design/Showcase 8 22-08-2003 21:35
