Go to Post Okay, who's willing to admit they treat their robot as a pet? - Bill Moore [more]
Unread 18-04-2007, 09:50
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
How to use code::blocks with mcc18
I have seen alot of questions on how to use code::blocks so i decided to post a tutorial on how to set it up (no makefiles )..
In the attachment (i only have winrar so i cant zip it).. youll find 4 files..
First merge the registry file (mcc18.reg) into the registry, just double click it to merge. then move the other 3 files into:
CodeBlocks\share\CodeBlocks\templates
Now when you open code::block make a new project and you should see IFI make a new project with that and then add all the .c and .h you do not need to include the linker or library.. now choose which RC you are compiling for in the drop-down box and hit re-build all.. that is important you must hit re-build everytime you want to compile new code..
Hope that helps some people..
Code::Blocks IDE interface (Tutorial/Makefile) Cjmovie Programming 8 25-01-2008 02:18
Variadic functions with mcc18 schroedinbug Programming 4 19-02-2007 00:51
Known Bug With mcc18 and Wine 0.9.22 ScottWalls Programming 1 05-11-2006 15:03
Bot blocks field with arm in LZ - Penalties? Swampdude Rules/Strategy 8 02-03-2005 15:00
How many RC5-72 blocks have you completed? Billfred Chit-Chat 0 19-08-2004 13:18
