Go to Post A HUMAN PLAYER is not a ROBOT. - cgmv123 [more]
Unread 18-04-2007, 14:39
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Chain Strength Formula
Originally Posted by Temper Metal View Post
I have a chain and need to know how strong it is. I just don't know how to check without loading 100+pounds onto it. For those with a machinary handbook the W is .735 in., the L is .668 in., The P is1.322 in.
I do not know wwhere to begin with this problem. I tried several handbooks and none of them had the right size. Anyone that knows anything of help please let me know. I can use the formula myself if you just don't have time to solve it. I am hoping that the FIRST community can help me as this is a big project for me.
You are going to have to provide a little more information. Just the size of the chain is insufficient - what material is it made from (plastic? aluminum? steel? and what alloy?) and what is the condition of the chain (pristine fresh-from-the-manufacturer, or covered with corrosion after being buried under a tractor for 10 years)? Is it single- or double-course (or triple-course)? Are the side plates on each link pressed into place, or welded? Has the chain been significantly stressed before? Etc.
All of these factors, and many others, will contribute to the overall strength rating of the chain. If this is just a length of chain that you had on hand, and you don't know the history of it's use (or abuse), then it may be impossible to accurately predict the actual strength of the chain. The only reliable way to determine it will be to use a short length of the chain and conduct a destructive loading test to see when the chain actually fails.
-dave
Need Help: Formula Needed Wilson Motors 21 30-12-2005 18:09
Help: a good, free formula writing software. suneel112 IT / Communications 4 13-08-2004 21:06
PSI formula for pneumatic pistons Ryan Pneumatics 10 13-01-2004 12:56
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
