Go to Post At IRI you have 72 of the best teams in the country. It could literally be held in a cornfield in the middle of Indiana and nobody would care, because the competition is simply that good. - Cory [more]
Unread 18-04-2007, 15:01
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: Chain Strength Formula
Originally Posted by Temper Metal View Post
I have a chain and need to know how strong it is. I just don't know how to check without loading 100+pounds onto it. For those with a machinary handbook the W is .735 in., the L is .668 in., The P is1.322 in.
I do not know wwhere to begin with this problem. I tried several handbooks and none of them had the right size. Anyone that knows anything of help please let me know. I can use the formula myself if you just don't have time to solve it. I am hoping that the FIRST community can help me as this is a big project for me.
Based upon your description, assuming it is actually a standard ANSI roller chain, it sounds like a #100 (1.25" pitch, .75" wide, link plates thickness of .156"). That's a bit beefy for a bot. If this assumption is true then the following exerpt from the Machinery Handbook (26th Ed, p2424) applies:
Minimum Ultimate Tensile Strength: For single-strand chain, equal to or greater than 12,500 × (pitch in inches)2 pounds. The minimum tensile strength or breaking strength of a multiple-strand chain is equal to that of a single-strand chain multiplied by the number of strands. Minimum ultimate tensile strength is indicative only of the tensile strength quality of the chain, not the maximum load that can be applied.
Soooooo..... 19.5 kip per strand
yowza
'course Dave's test is the only way to know for sure.
Mark
Mark
Brick walls are for other people. - Randy Pausch
Need Help: Formula Needed Wilson Motors 21 30-12-2005 18:09
Help: a good, free formula writing software. suneel112 IT / Communications 4 13-08-2004 21:06
PSI formula for pneumatic pistons Ryan Pneumatics 10 13-01-2004 12:56
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
