Go to Post Teams need to make 'don't be a jerk' a part of their culture, and that culture needs to be explained to the parents who travel with you - Libby K [more]
Unread 18-04-2007, 21:58
Alpha 997 Alpha 997 is offline
AKA: Yi Li
FRC #0997 (Spartans)
Team Role: Operator
Alpha 997 will become famous soon enough
The best multi-speed transmission
AndyMark's transmission is alright, but I've seen many that are just as good and much lighter. What do you guys think is the best multi-speed transmission that are also light and durable?
Ohhh... The EXIT sign is green so that robots can get out during a fire.
2007-Archimedes semi-finalist
2007-Davis Sacramento Regional champion
2007-Pacific Northwest Regional champion
2005-Archimedes semi-finalist
2005-Archimedes second seed
Unread 18-04-2007, 22:04
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: The best multi-speed transmission
you're own custom gear box. whatever your heart desires and your machining capabilities. you can build the best one ever. It doesn't matter who's is best. I see if you made one and it works on the bot and is effective you have reached your goal.
other then that general stuff, i do love the orginal 33 4 speed auto which 1126 has adapted for the last 3 years.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 18-04-2007, 22:10
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
The 254/968 transmission was quite impressive this year, weighing in at a shocking 1.3 lb.s. It was obviously lighter than virtually any other shifting transmission (and most single speed) in FIRST, could take input from 1 or 2 small CIM motors, and worked without a hitch.
The AndyMark's are fantastic for their reliability, ease of assembly, flexibility (can take 1 or 2 small CIMs, Large CIM, or even a FP through an AM planetary), low weight and cost, and durability. They have several areas teams can lighten them even more will little trouble (namely the cluster gears and mounting plates).
Unread 18-04-2007, 22:17
AKA: Yi Li
Team Role: Operator
Yeah. But building our own gear box won't be easy. We don't have enough machines to make a transmission. The best thing we got is a mil. I’m trying to build or own drive train and wondering which transmission is the best to use. I’m looking for a light weight, multi-speed one. 254’s transmission was impressive I wonder where they got them from.
Unread 18-04-2007, 22:20
AKA: Yi Li
Team Role: Operator
Could you guys be so kind as to show me photos and purchase information to the transmission that you think is great?
Unread 18-04-2007, 22:24
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Dewalt transmissions are an awesome choice. Under 100 dollars for a three speed shift on the fly transmission; you really can't beat that anywhere else.
Joe P.'s White paper should explain everything you need to know.
Joel J's Avatar
Joel J Joel J is offline
do you..
254/968's are great. Looked at them in the pit, and I could barely feel the weight of them. On superficial inspection they also seemed really efficient for a direct drive setup. AM's are good also, just make lighter side plates..
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 18-04-2007, 22:38
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
254's are custom built using some pretty exotic techniques. I could be mistaken but I heard that they are planning on using Andymark gears next year to make them easier to build which will in turn make them heavier. I did look at them in the pits and they were absolutely amazing.
Mentor 2415
Unread 18-04-2007, 22:54
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I had a chance to look at the cheesy poof transmissions in Atlanta, they had a display with all the parts sitting there. The parts look familiar somehow...sort of like the parts in an AM shifter, only lighter. They are beautiful!
I still haven't figured out what the advantages are to having a lightweight drive transmission, though.
Unread 18-04-2007, 22:59
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
More weight to use elsewhere. This year the poofs really didn't need it (weighing in a stunning 86 lb.s before adding the ramps), but many other teams would have like the extra couple pounds to play with.
Unread 18-04-2007, 23:02
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
The removal of weight from any system is an advantage. It gives you the ability to use that weight elsewhere, for another system, or simply as a buffer when you add things you hadn't planned to add. The argument I have heard is, "When you remove 4lbs from the base, you are just gonna end up adding it to the arm!!" Wrong!! You cant have that mentality when you design things... any weight savings from any system is an advantage. Hell, if we wanted to, we could add a 4lb block of lead to the VERY bottom of the robot, below where the CG of all the material that we removed was. Thats a pretty obvious advantage right there, and we havent changed the weight of any other system on the robot. Also, the removal of weight from rotating parts increases efficiency and acceleration. Just like lighter weight flywheels help your engine rev faster, lighter gears enable your motors to start and stop more quickly.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 18-04-2007, 23:03
MrForbes's Avatar
AKA: Jim
I can understand making a manipulator transmission as light as possible. The problem I see with a light drive transmission, is that the saved weight might be put higher up on the robot...resulting in a tippy bot.
Wheels, frame, and drivetrain is where you want the weight to be.
Unread 18-04-2007, 23:05
AKA: Yi Li
Team Role: Operator
Yep. Exactly.
MrForbes's Avatar
AKA: Jim
I agree! but having that weight already committed to the drive base forces the rest of the robot to be as light as possible.
Unread 18-04-2007, 23:07
Guy Chriqui Guy Chriqui is offline
AKA: Guy Chriqui
FRC #0004 (Element)
Guy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really nice
I think that the best multi-speed up to this point in terms of sheer engineering is that 254/968 gearbox they have been flaunting around at all the regionals my team has attended. The gears are astonishingly light. 1.3 lbs a gearbox made my jaw drop the first time I had the whole thing handed to me. It really is hard to argue against the sheer awesomeness that is that gearbox, really makes me want to one-up them and make something 1.299 lbs!
-Guy
team4element
Possible to do multi-speed transmission with v-belt? Squirrelrock Motors 15 13-12-2005 14:44
Multi-Speed motor Questions Burg Robotics Education and Curriculum 2 23-12-2004 15:54
The perfect 2 speed Transmission..... features... Salik Syed Technical Discussion 28 20-10-2004 11:44
White Paper Discuss: 222's 3 Speed Shift-On-The-Fly Transmission CD47-Bot Extra Discussion 4 14-07-2004 15:43
Multi-Motor/Transmission justification Gui Cavalcanti Technical Discussion 2 22-02-2004 17:15
