Go to Post If winning that individual match is more important to you than being there in the first place, then I believe you've got your priorities in the wrong spot. - Tom Bottiglieri [more]
Unread 18-04-2007, 23:17
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: The best multi-speed transmission
Originally Posted by squirrel View Post
I can understand making a manipulator transmission as light as possible. The problem I see with a light drive transmission, is that the saved weight might be put higher up on the robot...resulting in a tippy bot.
Wheels, frame, and drivetrain is where you want the weight to be.
Agreed... however, I would much rather cut a chunk of my 10 lb lead block off than have to drill a bunch of holes in the rest of the robot because we forgot to put on the LED, the team numbers, or the PVC flagpole mount... you get my point.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Possible to do multi-speed transmission with v-belt? Squirrelrock Motors 15 13-12-2005 14:44
Multi-Speed motor Questions Burg Robotics Education and Curriculum 2 23-12-2004 15:54
The perfect 2 speed Transmission..... features... Salik Syed Technical Discussion 28 20-10-2004 11:44
White Paper Discuss: 222's 3 Speed Shift-On-The-Fly Transmission CD47-Bot Extra Discussion 4 14-07-2004 15:43
Multi-Motor/Transmission justification Gui Cavalcanti Technical Discussion 2 22-02-2004 17:15
