Re: 56mm Banebot problems @ Championship
If you can do it with a simple spur or sprocket reduction, or by using an Andymark product, avoid the banebots.
I guess you can say they are reliable enough. But the huge variances among them, and the fact that the AM products I've used have far fewer failures (if any), convince me to avoid them. Really, it's a matter of doing something possibly more easily at first, at the risk of having to completely overhaul it later. |
| Banebot 56mm transmissions are Available | Teched3 | General Forum | 9 | 04-04-2007 16:23 |
| Redrilling 56mm Banebot Carrier Plates | Teched3 | Technical Discussion | 2 | 04-04-2007 15:43 |
| Banebot 56mm gearbox - double D - RELOADED | Joe Johnson | Motors | 82 | 09-02-2007 14:07 |
| Banebot 56mm gearbox - double D related | Joe Johnson | Motors | 78 | 31-01-2007 23:55 |
| Attempting to Cut BaneBot 56mm Shaft | edthegeek | Motors | 6 | 15-01-2007 08:51 |
