Go to Post Are you prepared to be a team member? - JaneYoung [more]
Unread 20-04-2007, 19:20
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
Re: Need help from turret experts
Make sure your gears are strong, especially if your turret is going to take a lot of abuse. At one regional, we stripped off eight teeth on a fourteen tooth gear.
Titanium?
Unread 20-04-2007, 19:31
You can read about a lot of great turret designs in FIRST Robots: Behind the Design. Not only are the descriptions more in depth then you would normally find in a chiefdelphi discussion, there are a lot of great pictures as well.
Unread 20-04-2007, 21:10
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
696 did a nice one in 06. Won them the Innovation in Control Award. Here's a pic. http://www.chiefdelphi.com/media/photos/23631. It was comprised of 4 rings. Inner and outer, and then an upper and lower of each. Each ring had a 45 degree chamfer milled around it. When placed together, inner, outer, upper, and lower, these chamfers would form a diamond shape. In this groove rode alternating steel and delrin balls. This groove gave us 4 points of contact on the balls, so that the turret could be loaded in any direction (axial, radial) and still rotate buttery smooth. It's large diameter made it quite stable.
Unread 21-04-2007, 02:41
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Especially check out 111's turret design. I've read that write up at least 4 times and my mouth keeps watering.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 21-04-2007, 02:51
pstrapp's Avatar
pstrapp pstrapp is offline
FRC #2016 (MuMuPsi)
pstrapp will become famous soon enoughpstrapp will become famous soon enough
I would suggest checking out 75's Turret
http://www.roboraiders.com/showcase/...turret_idw.PNG
http://www.roboraiders.com/showcase/?page=assy&type=sub
Unread 24-04-2007, 18:09
Alpha 997 Alpha 997 is offline
AKA: Yi Li
FRC #0997 (Spartans)
Team Role: Operator
Alpha 997 will become famous soon enough
Originally Posted by pstrapp View Post
Wow that's insanely complicated.
Ohhh... The EXIT sign is green so that robots can get out during a fire.
2007-Archimedes semi-finalist
2007-Davis Sacramento Regional champion
2007-Pacific Northwest Regional champion
2005-Archimedes semi-finalist
2005-Archimedes second seed
Unread 25-04-2007, 07:34
jcatt's Avatar
jcatt jcatt is offline
AKA: Jonathan Catt
FRC #1902 (Exploading Bacon and FRC #1251 TechTigers)
jcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of light
In our design this year we used Ultra-High Molecular Weight Polyethylene (UHMW) Disk sandwiched between two 3X3 aluminium box, with a sproket welded to the box and a bolt going tru all to keep it centered. The UHMW provided a very low amount of friction, making it very easy to turn. I will post a pic later to show it a bit more clearly
Jonathan Catt
Co-Owner and Systems Architect of ColorScene Inc.
Co-Sponsor of The RoboShow: Orlando
FRC 1251 Alumni
FRC 1902 Mentor
Unread 25-04-2007, 13:14
UCGL_Guy's Avatar
UCGL_Guy UCGL_Guy is offline
AKA: Ken YorK
None #0476 (Wildcats)
UCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to all
Send a message via AIM to UCGL_Guy
For my money if 12" is large enough - order the $28 lazy susan from McMaster Carr. We used them on the last three years machines and they take a lot of abuse before giving out. for $28 you can't make one any cheaper any better.
Ken York
Mentor/Coach Team 476 Ponca City OK
An ignorant person is one who doesn't know what you have just found out.
Will Rogers
Unread 25-04-2007, 19:16
Dick Linn's Avatar
no team (Synergy)
I remember years ago checking out some of the stores in Chinatown in NY. One place had this great ball-bearing turntable in the section that sold dishes and restaurant supplies. It was an aluminum bearing housing for a lazy-susan thing meant for a dining table. It was about 2 ft. in diameter and looked to be quite well made. I don't recall the price, but it was certainly reasonable compared to milling something from plate. maybe $50. That grocery store is still there, on Pell St, 1/2 way between Doyers and Bowery, on the south side of the street. Second floor has all kinds of interesting stuff. Think out of the box.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 25-04-2007, 19:30
Cowmankoza's Avatar
Cowmankoza Cowmankoza is offline
KoZa
AKA: Matthew Koza
FRC #1251 (The Tech Tigers)
Team Role: Operator
Cowmankoza has a spectacular aura aboutCowmankoza has a spectacular aura about
Send a message via AIM to Cowmankoza
Personally I've never been a fan of lazy suzan's, usually they tend to become extremely hard to turn when an off centered load is placed on them
Team 1251 The Techtigers
2008 UCF Regional Champs thanks to 233 and 86
2008 UCF Regional GM Industrial Design Award
2007 Palmetto Regional finalists thanks to 1626 and 1758
2007 Palmetto Regional Motorola Quality Award
2007 UCF Regional Champs thanks to 1270 and 86
2007 UCF Regional GM Industrial Design Award
2006 Palmetto Regional Champs thanks to 11 and 247
2006 UCF Regional Semifinalist thanks to 86 and 710
2005 Palmetto Regional finalist thanks to 25 and 301
2005 Palmetto Regional Xerox Creativity Award
2005 UCF Regional finalists thanks to 845 and 1270
2005 UCF Regional Judges Award
2004 UCF Regional Rookie All-star Award (The real winner)
Unread 25-04-2007, 21:50
Sam N.'s Avatar
Sam N. Sam N. is offline
FRC #1351 (TKO)
Sam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to behold
Send a message via AIM to Sam N.
1351 made a turret both this year and last year.
Note: I will use "turret" and "turntable" to describe the same thing
The turret on our robot for the 2006 competition was of much use. The ramp in 2006 was slippery and narrow. It was quite dangerous to move around up there because the robot might get stuck or even tip over.
We would get up onto our opponent's ramp and not even worry about robot positioning because we have a turret to compensate for any misalignment of the chassis. It worked very well and was very useful.
This year, we designed a turret at the base of an arm that was supposed to be comprised of two 5.5 foot articulated sections. I'm not entirely sure what we called it but we modled the turret around how a car wheel is attached to a drive shaft.
In my opinion it was the most useless thing ever. We never got our arm to work to "requirements documents" specifications. The arm turned out much shorter and lighter. Still, it was a very slow device. The chassis could realign itself faster than the turret to move.
Now an example of a good turret would be team 692. They also had a turret but instead of mounting their entire arm on it like we did, they integrated their turning system at the very top of their arm. That way the thing didn't have to be strong enough to carry the weight of an 11 foot flailing arm. Instead it worked fast and smooth because it wasn't bearing too much weight.
The moral of the story is: only use a turret if you need to achieve some sort of movement and/or orientation that your chassis can not. Don't throw one on for the heck of it and unless your team is incredibly beastly, completely ignore the words "cool factor". Coolness does not outweigh functionality.
Hope this helps,
Sam
Unread 25-04-2007, 22:16
AKA: Yi Li
Team Role: Operator
Smile Re: Need help from turret experts
Hope this helps,
Sam
Thank you for the great advise.
Unread 25-04-2007, 23:15
Scott Morgan Scott Morgan is offline
None #1138
Scott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura about
probably my favorite robot this year
But for turrets I'm interested in Bishop-Wiscarver's rotary systems, I was impressed by their display at nationals
Unread 26-04-2007, 11:35
pklevann pklevann is offline
Game Objective Guru
AKA: Paul Klevann
#0279 (Tech Fusion)
pklevann is an unknown quantity at this point
Here are some pictures from our 2001 robot. We made a sandwich of three aluminum plates, the base, the rotation ring, top plate or gear plate. The base had a 1/4" groove milled in at a specific diameter (20+ inches, it was 6 years ago). The rotation ring had a groove machined in the bottom at the same diameter as the base and a groove in the top machined at a slightly smaller diameter if I remember correctly. The top plate had a groove machined at the same diameter as the top groove in the rotation ring. The grooves were only 0.060" or 0.090" deep. We filled these grooves with 1/4" ball bearings. The rotation plate had the old window motor attached to it. I had measured the gear on the window motor and then in cad created an internal spur gear that was the size we wanted. We slapped the plate on the cnc and let it cut the teeth for the top plate. To check our position we created a lexan gear that attached to a pot located on the rotation plate. The whole system was very smooth, stable, easy to control. On last years robot (2006) we made a similar turret with a few modifications and improvements. I can't find any pictures of that one yet, but if I do I will post them. Last year we had the pleasure of watching our robot tip over going up the ramp and having the "Head" break off, sending ball bearing flying all over the field. Zip ties make horrible bearings, but they do keep you in the game.
ID:	5489  Click image for larger version
Name:	turret drive_smaller.jpg
ID:	5490  Click image for larger version
2005 National Championship Xerox Creativity Award
2005 Buckeye Regional Champions (Thanks 67 & 274!)
2005 Buckey Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 Great Lakes Regional Xerox Creativity Award
2005 Great Lakes Regional Safety Award
Unread 28-04-2007, 22:13
AKA: Yi Li
Team Role: Operator
Thank you the posts. These are great help.
Need Help Making Part from Spec Goaliexam Inventor 10 26-07-2006 11:34
need a general opinion from all you experts... archiver 2001 3 23-06-2002 23:09
Need Help, from Mentors for Research Steve Shade General Forum 1 25-02-2002 15:49
I need Help from you all. nick reynolds Chit-Chat 18 02-11-2001 23:39
