Re: Did anyone else see it this way?
I was actually more surprised when 1270 was DQ'd for tipping 71 in the semifinal match. I wasn't watching when it happened, but I expected nothing more than a 10 point penalty - but it was just a judgment call on whether or not it was 'excessive' play. (Chris mentioned that he understood it was a DQ for tipping, which would fit for this, but we had a qualifying match in which 217 was tipped and we were only assessed a 10pt penalty, although there was absolutely no hitting high ) - Jeff |
After reading this thread i noticed many people talking about "useing the arm for defense". can someone cite a rule that specifically says that the arm cannot be used for defense? its says another robot, or a tube that another robot posses cannot be grasped, and that an arm cannot be used to push another robot. However, i see no rule (and please correct me if i am wrong) about useing the arm to just get in the way. if other robots cannot make arm to arm contact legally it seems to me that putting your arm where the opposition wants to put thiers is a great and legal defensive manuver.
As far as i can see, from my interp of the rules the "Arm as defense" argument for a penalty seems void. |
<G35> Contact outside of the BUMPER ZONE is generally not acceptable, and the offending ROBOT will be assessed a 10-point penalty, and may be disqualified from the match if the offense is particularly egregious or if it results in substantial damage to another ROBOT. Next year we need to do a better job of getting the GDC to tighten up rules like this. |
-If a ROBOT extends outside of its 28 inch by 38 inch starting footprint, it is responsible for the extension's contact with other ROBOTS and must not use the extension to contact other ROBOTS outside of the BUMPER ZONE. Likewise, other ROBOTS will not be responsible for contact with the extension outside of the BUMPER ZONE. Again, incidental contact will not be penalized. -Extension to extension contact between two ROBOTS with appendages outside the 28- inch by 38-inch starting footprint will generally not be penalized. |
Must not, but incidental will not be penalized. Generaly won't be penalized? |
#7
It is a catch all that should probably be listed as several rules in the future. Personally, I would like it to address the following items: Pushing - Robots are expected to push each other during normal game play. Pushing must occur via robot to robot contact in the bumper zone. Penalties will be assessed for pushing outside the bumper zone. A DQ may be assessed at the discretion of the referee. No fault entanglement - It is expected that robots will occasionally become entangled during normal game play. The entangled parties must attempt to become un-entangled. Penalties/DQ's will only be assessed if one party uses this situation to pull another more than is needed to break the entanglement, creating a risk for tipping or robot damage. At fault entanglement - At the discretion of the referee, teams with robot design features and/or strategies which are considered to present an entanglement risk will be penalized if there is an entanglement during the match. Robot design features that present risk must be modified prior to that robots next match. Pulling - Robots on opposing alliances are not expected to pull each other during normal game play. Some pulling is allowed between robots in a No Fault Entanglement. Outside of this situation, the pulling robot will be assessed and penalty and possibly a DQ. Contact outside the bumper zone - Contact between robots outside the bumper zone is expected during normal game play as robots attempt to score on and defend against each other. However, this contact can easily lead to at fault entanglement, pushing outside the bumper zone and pulling, all of which carry penalties or DQ's. Please design your robots and strategies accordingly. It's certainly not perfect, but it's a start and perhaps a little bit clearer. Please add, subtract and edit with your own thoughts. Last edited by P.J. Baker : 22-04-2007 at 13:31. Reason: Incomplete post |
#8
those had to be the most intentional tippings (107 on 254) I have ever seen. |
#9
I'll go ahead and agree with SF2-3, but it was clearly contact outside of the bumper zone in SF2-2 that caused 254 to tip, whether it was intentional or not. I too was on the sidelines, and it was as clear as day to me. They were 5 feet away from the goal, neither robot anywhere near scoring position, and 107 had their arm straight out parrallel to the floor, extending a solid 18" outward from the front of the robot. It doesn't get any more clear than that. It has nothing to do with it being intentional or not... their arm was pointed straight out, and they proceeded to drive forward playing defense against 254. Clearly a pentalty at the very least, and more appropriately a DQ. The soap video only shows this contact for 1/2 a second or so, but it's there none the less. |
#11
107 was not holding a ringer. 107 was not attempting to pick up a ringer . 107 was using their extended arm to push 254 up high (from the side). 107 was using their extended arm to push outside/above the bumper zone. 254 was in possession of a ringer. 254 was moving towards the rack, presumably to score. Neither 254 nor 107 were actively in the process of attempting to score. http://youtube.com/watch?v=Z2XmhRZmMsM Quote:
In pertaining to this situation, it would be the quotes outlined in <G35>, as 107 is clearly not defending a spider leg (<G36>), interacting with a game piece (<G36> and <G37>), entangling (<G38>), or pinning (<G39>). As 107s sole defensive mean (and sole means of contact with 254 period) at that moment was contact outside the bumper zone, I cannot possibly believe that it would fit the definition of incidental (meaning an subordinate side-effect of another action), and as such, must be penelized (minimum 10 point by the rule, maximum DQ). Last edited by Lil' Lavery : 22-04-2007 at 14:27. |
| Did anyone else notice the field error on Einstein? | Michael Hill | General Forum | 12 | 16-04-2007 15:38 |
| did anyone else have this problem? | NuclearPeanut | FIRST Tech Challenge | 0 | 25-04-2005 14:34 |
| Did anybody else got this e-mail? | Kyle Fenton | General Forum | 9 | 02-10-2002 18:12 |
| Did anyone see the Today Show? | archiver | 2001 | 1 | 23-06-2002 22:43 |
| Did anyone else notice team 121? | CrazyForFirst | Championship Event | 17 | 05-05-2002 23:00 |
