Go to Post ...Al Skierk, uh, Skierwike, uh, you know who I mean - Gary Dillard [more]
Unread 22-04-2007, 16:13
CraigHickman
Posts: n/a
pic: Coaxial Crab
Unread 22-04-2007, 16:14
AdamHeard's Avatar
Lead Mentor
Re: pic: Coaxial Crab
That's pretty amazing.
How hard would it be to change the gearbox? Is there a reason it's not a shifter?
What needs to be CNCd?
Unread 22-04-2007, 16:15
Aren_Hill's Avatar
Build Nifty Things
i was wondering, why don't you support the bottom of the module at all? a. you wouldn't need the two .5"thick plates and b. it'd probably be even lighter. but its only 40 lbs right now which is more than i can say for our 60lb one (it'll be lighter next year)
one last question how many swerve drives do you currently have designed?
A guy who likes robots.
Unread 22-04-2007, 16:18
CraigHickman
Posts: n/a
A shifter is easily possible, I just haven't added one in. In order to change a gearbox, you only need to undo 4 bolts. In order to save weight and structure, the gearbox bolts also mount the modules.
The only CNC necessary parts are the side plates of the actual modules.
It's actually a single block, not two plates. I just chopped the middle out to save weight. We've built a crab with a mounting system just like this, and never had any issues.
I think I'm up to like 8 different ones designed... this is by far the lightest and best.
Unread 22-04-2007, 16:21
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
2001-2004: Team 100
2006-Present: Team 254
Unread 22-04-2007, 16:24
CraigHickman
Posts: n/a
Originally Posted by Cory View Post
What can I say? I'm obsessed... and my team still won't let me build one of these...
Unread 22-04-2007, 16:25
Cory's Avatar
AKA: Cory McBride
Sorry, that was just a placeholder for CD-Media apparently not allowing you to delete your own posts. Not a question of why
2001-2004: Team 100
Unread 23-04-2007, 08:54
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Your CAD work still amazes me. Eight different designs?? What's next?!? Keep up the good work, and maybe you can bring one of those digital files to life one day!
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 23-04-2007, 17:38
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
jesus christ we are twins I swear to god. I have pretty much the EXACT same design. wow.. yours is much better drawn of course ( I am still learning AutoDesk) But man we think a like for sure.
Unread 12-11-2007, 21:16
FRC1710's Avatar
FRC1710 FRC1710 is offline
FRC #1710
FRC1710 is an unknown quantity at this point
Our team is interested in doing a Crab drive similar to yours this year. We were wondering if by any chance you could send us those files for us to look at them.
Thanks,
Miriah Team 1710
email (miriah27@sbcglobal.net)
Unread 13-11-2007, 12:54
AdamC's Avatar
AdamC AdamC is offline
Lathemeister
AKA: Batman
FRC #0395 (2Train Robotics)
AdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of light
Send a message via AIM to AdamC
Wow! That's epic. I like your mounting system. How do you plan to tension your chains, though? Are you going to try the Robonauts free-floating sprockets, or will you try some sort of spring-loaded idler?
"The glass is neither half-full or half-empty. It is twice as large as it needs to be."
"Any job worth doing is a job worth dying for."
Unread 13-11-2007, 16:13
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
this is like my FTC bot this year except only 2 'swerves' so really its only half that
and unfortunatly it cant go 8fps, maybe about 2fps
Unread 13-11-2007, 16:16
AdamHeard's Avatar
Lead Mentor
There looks to be a plastic rod near the globe motor, that would probably tension the steering chain. I can't see anything in the picture to tension the drive chain though. It's entirely possible he designed the distance to be exact so that no tensioner is needed.
Unread 13-11-2007, 17:34
CraigHickman
Posts: n/a
Hah. I did the math for one of those once, and I'm never doing it again. Besides, chain stresses. Especially under high stress apps like this.
The tensioning method is the Delrin rods, like AdamHeard said. They're off center, kinda CAM ish. One will be a through bolt, to act as a pivot point. The CAM would be rotated to hold the chain tense, then a second hole would be drilled to lock it in place. If the chain stretches to an unhappy amount over time, a new piece of delrin (which is surprisingly cheap...) would be drilled and attached.
Thanks,
Miriah Team 1710
I'm sorry, but I don't really hand out CAD to something this complex. It's a much better process if teams learn how to design themselves. However, I'd love to answer any questions you folks might have. Feel free to shoot me PMs whenever you'd like, and I'll work to get back to you as soon as possible.
I'm glad people still like my designs!
Unread 15-11-2007, 16:44
FRC1710's Avatar
FRC #1710
Sorry, We don't need CAD help that is not one of our weakness's. We are just having trouble with the drive assembly for our swerve prototype. Some shop drawings would be nice at least, someone with inventor knowledge like yourself should be able to whip a few of those up in minutes with auto-dimension. Let me know what you can do to help!
-Spenser
FRC1710
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
pic: Coaxial crab CD47-Bot Extra Discussion 9 08-02-2004 20:08
pic: Coaxial Lego doubble-wishbone crab CD47-Bot Robot Showcase 7 10-12-2003 12:10
pic: Coaxial Lego Crab drive CD47-Bot Robot Showcase 11 04-11-2003 14:45
pic: poor mans Lego Coaxial crab CD47-Bot Robot Showcase 8 23-10-2003 22:00
