Go to Post Look past the robot. Look past your team. Science and technolgy are studies worth devoting your life too. - KenWittlief [more]
Unread 22-04-2007, 19:44
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
pic: A drivetrain prototype idea
Unread 22-04-2007, 19:46
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Re: pic: A drivetrain prototype idea
Good design but a few questions.
1.) The electronics look really low to the ground. Are you worried about them hitting when you drive over a bump or such.
2.) what is the ground clearance?
3.) Is there an arm that is going on the other side of the robot, because it seems like the side closest to us is really heave right now (battery, gearbox, motors...)
4.) also how does the chain wrap go for the wheels?
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 22-04-2007, 19:49
GMAdan's Avatar
Well you are right they are really low. Well i might as well say what it is for. I want to make a robo-snow blower. So on the other side the snow blowing stuff will counter weigh. I want to do a gear connection between the wheels, I am still working on the gear sizes and other things.
p.s. I do plan to seal the electronics to keep the snow out. That is one reason for the compactness.
Unread 22-04-2007, 19:51
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Is the center wheel lowered, or are you going for the Team 25 brute force approach?
Unread 22-04-2007, 19:55
GMAdan's Avatar
brute force
Bharat Nain's Avatar
That looks a lot like one of our drive trains so I can tell you that this design should work. Putting stand-offs between two plates is nice because you can take the whole thing apart really quickly and it is fairly light-weight. Are you using chain-drive or gears? Any more info? Look at our drive train designs in the Behind the Design book.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 22-04-2007, 19:57
GMAdan's Avatar
we are going geared. We did looked at your section in the book but we still have some questions and problems we are trying to work out.
Unread 22-04-2007, 20:39
nparikh's Avatar
nparikh nparikh is offline
i heart infrared
AKA: Neil Parikh
FRC #0025 (Raider Robotix)
nparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond repute
Send a message via AIM to nparikh Send a message via MSN to nparikh
Well if you have any questions, please feel free to ask-pm email, etc. We'd be more than happy to help you out if we can.
Doing the right thing is always better than doing the easy thing.
Team 25 Alumnus
Attending: NJ Regional, Boston Regional, the Championship Event
Unread 22-04-2007, 21:45
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
I would consider running treads if you plan on driving around in the snow ..
Also, consider using a EDU RC (or a vex RC) instead of a full sized RC/OI setup. A much cheaper approach, and you can control it using any RC car/plane controller.
Looks cool though ..
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 22-04-2007, 22:59
Cartwright Cartwright is offline
Scouting/Manufacturing
AKA: Jamie
FRC #0234 (Cyber Blue)
Cartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to behold
It looks quite sturdy, but I question its maneuverability. If good turning is important, its seems like you'd need at least a bit of a rock in the middle wheels. The gaps at the corners seem like a bit of a hazard to the electronics. The design itself looks neat and powerful though.
Unread 22-04-2007, 23:06
Noah Kleinberg Noah Kleinberg is offline
FRC #0395 (2TrainRobotics)
Team Role: Driver
Noah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to behold
Send a message via AIM to Noah Kleinberg
Looks like you're getting a very early start on the '08 snow game there, huh?
(I can't help myself)
Unread 22-04-2007, 23:16
nparikh's Avatar
i heart infrared
AKA: Neil Parikh
Not necessarily. If you have sufficient force you can always brute force it and still have pretty good turning.
Team 25 Alumnus
Unread 23-04-2007, 17:32
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Looks pretty low, but overall nice job on the design. That is some incredible CAD work, and I am sure that it took you a long time. I think that it definitely paid off, and the outcome is tremendous. Great job!
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
Unread 23-04-2007, 19:17
AdamHeard's Avatar
Lead Mentor
How are the plates going to be made?
Unless it's lasered/waterjetted/turret punched you can't put sharp corners on the inside of parts.
Unread 23-04-2007, 19:35
GMAdan's Avatar
water jet if this idea ever turns into a real drive train
A new drivetrain Idea? Cody Carey General Forum 55 20-08-2006 12:48
Questions about an Idea for a drivetrain. Radiator251 Technical Discussion 21 29-01-2006 13:11
1541 Prototype Drivetrain bombadier337 Technical Discussion 12 23-01-2006 08:26
Crazy drivetrain idea lukevanoort Technical Discussion 7 26-10-2005 21:19
Image Discuss: Team 773 Drivetrain Prototype CD47-Bot Extra Discussion 5 27-01-2003 18:46
