Go to Post Based on my experience coaching basketball and robotics, there is no doubt in my mind that if a sports coach receives $x then a robotics coach should, too. - dtengineering [more]
Unread 22-04-2007, 17:08
Aren_Hill's Avatar
Build Nifty Things
pic: stangs swerve module
Unread 22-04-2007, 17:09
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: stangs swerve module
It's Delrin.
It's a pretty cool little piece of plastic.
It's milled on both sides so that the profile mates with the frame mounted plate, and the opposite side mates with the plate attached to the bottom of the module.
2001-2004: Team 100
2006-Present: Team 254
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Raul told us it was a custom machined delrin/acetal ring.
Edit: Aww, too slow today I suppose...
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 22-04-2007, 17:21
Aren_Hill's Avatar
Build Nifty Things
thank you very much
i want to see one of you two 254/968 do a swerve drive because you practically make anything you do art (such as 1.3lb apiece gearboxes) and a swerve drive would be plain amazing.
A guy who likes robots.
Unread 22-04-2007, 22:53
Aren,
We learned early on, that the crab modules (which are fully modular for ease of repair) need some additional bearing help at the bottom of the module. The delrin ring provides that bearing surface and is somewhat self lubricating. Any forces that would be transferred through the module top bearing are actually shunted by this bearing right to the base of the robot frame. By keeping the bottom movement to a minumum, the surface of the drive wheel stays flat on the floor and side forces do not cause the upper bearing to bind as the module is rotated during pushing from other robots.
Note: As photographed the module is upside down. As such, the bearing ring and plate are laying on the table. During operation both the ring and plate would be mounted in the same plane as(and mating with) the round base of the module.
Unread 22-04-2007, 23:57
Aren_Hill's Avatar
Build Nifty Things
Al on our swerve drive this year at the bottom of each module we had a disc and then 4 1"diameter plastic rollers which were kind of a pain and something i'm looking on improving next year. could you explain how you machine the delrin? rotary table? lathe?
Unread 23-04-2007, 07:58
Aren,
I am on the electrical team so I am not sure. I believe they were cut on a CNC end mill. If you did not get a close look, they are a "Z" in cross section but the vertical and horizontal elements are at right angles to each other. I will check with Raul and find out for sure which method was used.
Unread 23-04-2007, 08:12
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
That looks awesome Wildstangs robots continually inspire my team to try new and diffrent ideas and do a first rate job when maufacturing. We used a similar idea for our arm turret this year to reduce the friction of a regular lazy susan design when rotatation our arm. Many people ask us what the "pink stuff" is on our robot, it's oil impregnated uhmw a type of plastic very similiar to delrin it's useful for making light weight bushings. Anyway I didn't know if the delrin was impreganted with oil or not just throwing an idea out there for next year.
-Drew
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Unread 23-04-2007, 08:15
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Yes, they are cut in a CNC mill out of a .375 inch think plate of Delrin.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Swerve Module Question adlai Technical Discussion 8 03-04-2007 21:20
pic: Vex Swerve v3 JVN Extra Discussion 22 08-09-2006 17:28
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
pic: Swerve! =Martin=Taylor= Extra Discussion 15 07-07-2006 01:58
Cyber Stangs VEX team in the newspaper! crazykid234 FIRST In the News... 2 14-02-2006 19:03
