Go to Post Smart defense doesn't even require your robot to push another. - Cory [more]
Unread 22-04-2007, 23:11
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Question Off-Season Scrimmage arena control
Howdy,
A couple of the teams from Central and South Texas FRC are likely to be demonstrating their robots at a Technology Association trade show this July. What kind of issues do we need to be concerned with when operating with radios in the conference hall? Would we be able to run some Two on Two OR Three on Three scrimmages without any modifications or do we need to rent an arena system from IFI?
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 22-04-2007, 23:22
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Re: Off-Season Scrimmage arena control
The best solution for you is to use a dongle on your OI. You will have to make them, but they are simple to construct.
http://www.ifirobotics.com/docs/comp...guide-reva.pdf
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 22-04-2007, 23:51
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
You can change the radio channel by flipping the highest bit on your team number. That will allow you to change the switches for the radio channel. You'll have to tether everything to put the new team number in the RC, but it will work.
We've run 4 robots before without any dongles .
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 23-04-2007, 00:03
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Heh... I remember in 2005, I think, we tried to do this but none of the engineers could get it to work. I suppose we'd use the 2005 and 2007 robots for demonstrations again, so I'd be interested in a detailed, step-by-step instruction on how to do this. Anyone know where to find instructions or care to describe it via PM for me?
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 23-04-2007, 00:06
Page 17 - http://ifirobotics.com/docs/oi-ref-guide-1-30-07.pdf
Steps for changing channels:
1. Set the MSB of the Team Number Dipswitch to Open. This will set the Team Number greater than 2048.
2. Make sure both units (RC and OI) are set to the same Team Number by tethering.
3. Remove tether after a Link has been established.
4. Set the CHANNEL dipswitch to the desired channel.
5. Press OI RESET on the Operator Interface.
6. Press RESET on the Robot Controller.
7. Note: ROBOT RESET on the Operator Interface will not work for this.
8. After a few seconds, the “Valid RX” LEDs should be flashing on both units, indicating each is transmitting and receiving good data with the correct team number and channel number – a Link has been established.
155, teacher: 2011-
Unread 23-04-2007, 00:14
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Just remember the process changed from 2004 to 2005, but since 2005 I think it has stayed the same. It used to be that you had to go through the comp port to unlock the frequencies/channels. Now you just tether up, change the most sig bit on team number, change the channel, reset and you're good to go just as OGRE mentioned. We did a scrimmage back in '05 had a lot of trouble between old OI's and new OI's. Good Luck and have fun!
West Coast Post-Season Scrimmage rsilverstein Off-Season Events 12 27-03-2007 23:52
437 Showing Off it's Off Season NextPerception Robot Showcase 7 06-02-2007 19:03
Off-Season Projects zdeswarte Off-Season Events 6 23-02-2005 16:31
Off-Season Events Steve-0 General Forum 1 21-04-2004 13:08
Off-Season in Richmond?! Sachiel7 Off-Season Events 17 25-11-2003 00:17
