Go to Post Forum Anonymity = Rampant Exaggeration, if not outright Blatant Lying. - dsm [more]
Unread 23-04-2007, 22:30
AdamHeard's Avatar
Lead Mentor
Designing Anodized Parts
What precautions should be taken or features added to a part that is going to be anodized in comparison to a normal part? Do bearring holes need to be made slightly oversize? what about tapped holes?
Unread 23-04-2007, 22:36
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
Re: Designing Anodized Parts
when a part is anodized the thickness of the finish could be anywhere from 1/32 to 1/16 of an inch, i would suggest sending out a part to the anodizer and measuring it when it comes back
Championship - Delphi "Driving Tomorrows Technology"
Unread 23-04-2007, 22:42
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
30 to 60 thou over?
In our experience it's been more like 2-4 thou over.
2001-2004: Team 100
2006-Present: Team 254
Unread 23-04-2007, 22:46
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
How much time should usually be allowed for anodizing parts?
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 23-04-2007, 22:47
AdamHeard's Avatar
Lead Mentor
Originally Posted by Cory View Post
30 to 60 thou over?
So, how do you compensate for that? Do you make all holes that much larger? or do the anodizers mask them off?
Unread 23-04-2007, 22:49
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
A machinist I know said for a traditional basic anodizing, the dimension added (outside the existing material) is so negligable .0002-.0003" that it doesn't need to be considered for most bearing press fits. If you are getting into hard anodizing, it is possible you could add a thou or two, and then it would need to be considered.
Unread 23-04-2007, 22:51
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Most colored (Type II sulfuric anodize, which is most common) should be anywhere from .0002 to .0008 thick.
Type I anodize (Chromic) is usually only .0001 and typically has no dye added.
Type III (hard anodize) is typically thicker than the above two.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 23-04-2007, 22:52
AdamHeard's Avatar
Lead Mentor
What I'm concerned with are; bearing holes, holes for shear pins and threaded holes.
So, if the anodizing is for cosmetic purposes (Type II- thanks for letting me know Travis), the effect is negligible?
Unread 23-04-2007, 22:54
Engineering Mentor
FRC #0254
Originally Posted by sanddrag View Post
A machinist I know said for a traditional basic anodizing, the dimension added is so negligable .0002-.0003" that it doesn't need to evern be considered for most bearing press fits. If you are getting into hard anodizing, it is possible you could add a thou or two, and then it would need to be considered.
This is usually correct. Dont worry about it at all if you are just doing a regular colored ano. If you are doing a hard anodization, find out exactly which process you are using and contact the people themselves. They will tell you the thickness which will allow you to change your part dimensions accordingly. It should be noted, however, that "thickness" in the anodizing world refers to the total amount of material affected by the process, both penetrating and building. This means an anodize that is .0002 thick penetrates .0001 and builds .0001.
-Travis Covington
Unread 23-04-2007, 22:55
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
So, if the anodizing is for cosmetic purposes (Type I), the effect is negligible?
If your bearing hole is exactly how you want it to be, I would mask it so it does not get anodized.
Don't worry about the threaded holes and the holes for shear pins or roll pins.
Andy B.
Engineering Mentor
FRC #0254
No, Type II is what you want then. Type I is more functional than cosmetic, as it has no dye added.
-Travis Covington
Unread 24-04-2007, 09:15
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
If your so worried about the bearing holes, why not just ream them out when you get the parts back? You cold mask them off or cork them.
-John
Unread 24-04-2007, 10:45
Tim Baird's Avatar
Tim Baird Tim Baird is offline
Design Ninja
FRC #0126 (Gael Force)
Tim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond repute
Send a message via AIM to Tim Baird
In my experience, masking is the best bet if you already have the hole to the exact dimension and location that you want it. You can sometimes mess it up through reaming.
In terms of lead time, if you're friendly with the company and they don't mind working hard for you, it can be done fast. For the central mass teams, Dav-Tech plating in Marlboro is really good. I've dropped stuff off at 8am and picked it up at 4pm. However, a typically company, depending on the color and batch size, will take 2-4 days.
Also, if you're anodizing very small parts, make some spares. Tiny parts are known for getting lost in the tanks.
Tim Baird
FRC Alum and FRC/FLL Volunteer
Project Engineer @ Nypro
History:
Gael Force 126: 1999-2000
WPI 190: 2001-2004
Gael Force 126: 2005-2010
Event Volunteer Only: 2011-Present
Unread 24-04-2007, 13:26
Brandon Holley's Avatar
Brandon Holley Brandon Holley is online now
To really save some time and frustration, especially if you haven't worked with anodize before i'd suggest reaming holes out after you get anodize back. That is IF you are very concerned.
We used A LOT of anodized parts this year on our bot 125 in technicolor
We left our dimensions the same and experienced no real huge problems with items not fitting. If your very concerned i'd go with cutting your holes slightly smaller than your actual dimension and then reaming them out after, it guarantees a correct fit regardless, and no one will see it.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 24-04-2007, 15:25
Cartwright Cartwright is offline
Scouting/Manufacturing
AKA: Jamie
FRC #0234 (Cyber Blue)
Cartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to behold
-John
Yeah...that is what we did, if the holes were too tight.
But anodizing is really great, it makes the overall appearance look way better and more professional. I'm almost positive that it played some small role in the success of numerous robots this year.
pic: Anodized Parts 254/968... ejSabathia Extra Discussion 12 02-02-2007 15:31
Designing a new gearbox, Help GMAdan Technical Discussion 3 19-12-2006 21:01
Designing the Robot Dan Petrovic Team Organization 15 23-09-2006 22:14
pic: Team 229's Anodized IFI Wheels Adrienne E. Extra Discussion 11 23-01-2006 17:55
re designing old mechiniism Andrew Dahl Rules/Strategy 7 13-01-2004 19:35
