Go to Post FIRST is an addiction but at least it is one of the healthiest addictions you can have (if you wear your safety goggles!). - Pavan Dave [more]
Unread 24-04-2007, 18:45
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
Calculating relays.
I have to build a solenoid for tech, how would one go about doing the calculations, google is either useless or I'm not using correct keywords
Unread 24-04-2007, 19:04
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: Calculating relays.
Can you elaborate a little? What calculations are you trying to do? Power requirements? # of wraps?
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 24-04-2007, 20:26
DonRotolo's Avatar
Back to humble
FRC #0832
Some key factors are the magnetic pull required and the voltage available.
The current in the wire multiplied by the number of turns, and the core size and material, determines the magnetic pull. But, the bigger the current, the bigger the wire must be and so you can't fit as many turns. The number of turns and the wore size determines the bulk resistance of the coil, and so you need a certain voltage to maintain a certain current flow.
Maxwell's equations explain it, but without some college level math under your belt, they won't help much.
So, what kind of pull, what is the power source, any size limitations, etc.. and we;ll get you through it.
Google "electromagnet"
Don
Unread 24-04-2007, 22:23
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
Hey Guys, The solenoid needs to trip at 5 volts. I need to find out how many turns of wire i need. What is the general formula for that is what I need to know.
Thanks
Calculating Camera Distance Inoperational Programming 6 04-02-2007 23:48
calculating distance sur2124 Programming 10 15-03-2006 18:36
Calculating Angle to fire at Issues Programming 56 09-02-2006 10:01
Calculating Wheel Size phrontist Technical Discussion 15 07-09-2004 18:55
