Go to Post You are beautiful. - Joe Johnson [more]
Unread 25-04-2007, 10:00
rswsmay's Avatar
rswsmay rswsmay is offline
AKA: Robert
FRC #1177 (Mecha-Jags)
rswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the rough
Re: [FVC]: Longer competitions
If the direction that FVC has taken holds true (FLL based) then I do not see multiple day tournaments as being a viable option to address the issues raised. I attended 3 FVC State tournaments this year and while they each had their own style and flavor, the common issue I saw was “allotment of time”. Each tournament had between 29 and 33 teams that participated. They each had 2 fields and ran between 4-6 qualifying matches. For the Georgia tournament that held 6 matches it made for a very long day for teams, volunteers and the hosting venue….. almost 12 hours. This was in addition to other observations and/or problems that I believe can easily be addressed. My opinion is that 4 qualifying matches is a disservice to teams that may have spent significant hours designing, building, practicing and otherwise preparing for a competition like FVC. In Georgia, our current plan is to have tournaments with at least 6 qualifying matches. This may change if the format changes, but for now that is the plan. A bare minimum would be 5 matches but that would be in the rare case where we have too many teams to run more matches, and not enough teams to organize 2 separate tournaments.
With that said, here is my take on this.
  1. Keep qualifying and non-qualifying tournaments to one day. It may be a long day depending on the number of teams, but the one-day formula can work. This may mean that you limit the number of teams to that which can reasonably compete in a single day event.
  2. State tournaments can go to 2 days (or 1-1/2 days) especially if the team count goes above 35 and there are 6+ matches per team.
  3. Although this adds cost and creates the problem of integrating the data from 2 separate scoring tables, we should find a way to run 3-4 fields during a tournament. It would be a plus if this can be done from one scoring system rather than two. This can alleviate the problem felt this year not only by the championship event but also at all FVC tournaments.
  4. At all 3 events that I attended, tournaments each had different flavors of FIRST. Meaning that if someone walked in off the street and saw what was going on, they may not know that it had any thing to do with FIRST. Part of this is probably due to the tight schedule, part due to rookie teams, and part due to the organization of the affiliate partner. People should walk away from the event knowing more than they did when they came in about FIRST and its goals.
  5. This is not an FVC issue directly, but scrimmages should be run in the various regions where tournaments will be held. Not only is that an invaluable tool for what will now be veteran teams, but also rookies who have no idea what FIRST is all about can be introduced to the concept of Gracious professionalism prior to arriving at a hectic tournament.
  6. The championship event…… well goes beyond saying that more qualifying matches are needed. With the program growth in the number of teams from around 150 to 550, a plan needs to be in place to accommodate the number of teams participating while running more than 4 qualifying matches. I believe that for now, 100 FVC teams at the championship is a good number but we need to accommodate them better. Item number 3 above is the obvious first pass solution to this on the competition side. I welcome other suggestions to address this problem.
Just another observation…. I personally do not believe that the FVC program will fit perfectly into the FLL mold for tournament organization. From what can see there could be rapid growth to rival FLL along with the competitive format that FRC enjoys. I think a hybrid format maybe better suited for the program. For instance, this may mean that we keep the local 1-2-3 tier tournament structure at the local level, But at the championship event, there are organized divisions that feed the elimination matches. I am also not entirely fond of teams that did not even make it to the elimination matches in their state tournaments, getting to the championship through a lottery. I would much rather see the runner up alliances from each tournament put into a lottery and given the opportunity to go to the championship. I gotta say that I saw some very good 2nd place alliance teams that would have easily gotten to the quarter or semi-finals in the championship. It’s just too bad that they were left behind because they were not lucky enough.
Knowledge is only strength.... Knowledge and Wisdom, thats true power.
Unread 25-04-2007, 10:21
KathieK's Avatar Unsung FIRST Hero
KathieK KathieK is offline
Sometimes FIRST makes my head hurt!
KathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond repute
Send a message via AIM to KathieK
The comments you've all given have my head spinning as to how to improve ConnVex for next year. I think it would be difficult to find a venue that is inexpensive that has the space required to run multiple fields, but that is a solution for giving teams opportunties for more matches.
Does anyone have ideas about how to make the judging schedule less hectic/stressful?
Would teams be interested in attending Team Socials (if on Friday night or after the event on Saturday)?
I will try and share these ideas with the other Affiliate Partners.
Check out my 2016 Conference presentation, Dumpster Diving: How to Get Stuff for Your Team for Free or at Little Cost
www.usfirst.org | www.nefirst.org | www.firstnemo.org
Helping mentors since 2004
Unread 25-04-2007, 11:01
Billfred's Avatar
Billfred Billfred is offline
I haven't judged since the Orangeburg pilot last year, but I actually think the two-day format would be helpful here. I personally felt like I didn't get enough chance to get a feel for what designs were working on the field (important for the Create award of that year, roughly equivalent to the Innovate award now), or to catch any in-the-trenches events (which might have Amaze award implications). It's unfortunate that the judges can't be everywhere at the same time, but it's just the nature of the one-day format.
The Create award was especially hard to judge that year, as we all had seen different robots in the rooms (and there were some great Half-Pipe Hustle robots in that group, none of whom we'd seen on the field). We solved that by sending me out with my digital camera to get shots of the shortlist teams--I'd highly recommend some means of doing this at an event (perhaps during inspection). In the absence of some visual flair (see also: Simbotics, Vexy Things, Checkmate), they all start to run together after a while!
This would be a little more radical, but what about having teams submit a short version of the key information before the competition for the judges to read? Give teams two pages, send the PDF to FIRST, and make sure the judges receive this far enough ahead to get an initial feel for the teams.
Unread 25-04-2007, 13:33
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Originally Posted by rswsmay View Post
  • Although this adds cost and creates the problem of integrating the data from 2 separate scoring tables, we should find a way to run 3-4 fields during a tournament. It would be a plus if this can be done from one scoring system rather than two. This can alleviate the problem felt this year not only by the championship event but also at all FVC tournaments.
You are the second person in as many days to express a wish list for the "scoring" software. Writing some new scoring software is not trivial (not a one-night job); but it is not hard either.
Using Java's Swing GUI I can take requirements from users (like you or Kathie K, or Skimoose, or...) cook something up this summer, run it through a few iterations of feedback and-field testing, and have it available by Sept. I am sure other folks can too.
At the end the source code would available for further refinement or customization by any local league or by a fresh set of eyes who could improve it for next season...
  • It could use two computers on a network if "integrating data from two fields" is needed.
  • It can use one computer into which someone types data from more than one field (sort of like putting the info into a single spreadhseet like this one(http://www.vexforum.com/gallery/show...467&catid=11)).
  • It can be connected to a computer kiosk equipped with a mouse and printer that teams use to print the match schedules, match results, lists of any team's opponents and allies, thumbnails of all the event participants, ....
  • It can be designed to drive one output screen, two, three or whatever with different windows on each.
  • It can do whatever our imaginations and time permit.
If an adequately large handful of the FVC movers and shakers want to create a list of requirements (features desired, inputs, output and output formats, and deployment configurations); then I am willing to write the code or share writing code that I would integrate.
There are two caveats
  1. I would not want to invest the time necessary to do this, see it get used in a couple of scrimmages; and then see it fall by the wayside because it has no path to becoming "official". I think "we" would want FIRST, or at least a decent fraction of the FVC APs, to say that they are willing to pick up a good result and adopt it for sanctioned events. For me, at least, doing this will be an exciting, rewarding and satisfying project; but only if it gets used for more than just my local Potomac Vex League scrimmages....
  2. If this proposed Java code had to send on/off signals to the current field controller, I would want someone else to supply a field controller software API that could be invoked by the Java code. My desire would be to separate scoring (all entered manually) and tracking match info from the simple but different job of controlling the field.
Who thinks this would be a fun off-season project that would be a great gift to the community? If I get enough positive feedback we can spin off a new thread and get down to business.....
Blake
PS: If whomever wrote the current code (I think someone at Wildstang might be the author(s)) is seeing this, maybe they feel the same way, and would enjoy converting it into a collection of open source Java that can be continually improved through contributions from the community?
Unread 25-04-2007, 13:36
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
I'm puzzled - Aren't school (K-12, community colleges, university campuses and their satellite campuses) gymnasiums inexpensive and plenty big enough?
Maybe I think they are cheap because local schools have been willing to donate custodial services...?
Blake
Unread 25-04-2007, 13:57
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
This comment by me has little to do with rwsmay's specific quote above; but is a more general one to folks discussing FVC.
Saying FVC is/isn't, should/shouldn't, can/can't follow an "FLL model" appears to be a convenient shorthand for many folks; but as someone not familiar with FLL, I don't see much value in the comparision.
Saying things should work like FLL, but not exactly like it, carries a ton of baggage that sows confusion when the differences aren't all explicitly described as part of the statement's context.
Also, things like needing a multi-tiered tournament structure once the number of teams rises much beyond the current FRC numbers is hardly something the phrase "like FLL" expresses uniquely or clearly. Instead the need is just common sense; and, at least in my mind, it as much like US professional and amatuer football, baseball, swimming, soccer, beauty pagents and all other big competitions; as it is like FLL.
So, am I saying the work that has gone into making FLL a success should be thrown out and ignored? No! Please don't take that away from this suggestion.
Am I saying that a growing organization needs to avoid falling into a habit of speaking in shorthand that everyone thinks means the same thing to all people in the organization - but probably doesn't....? Yes.
Am I saying that a growing organization needs to use ordinary terminology to discuss ordinary concepts (so that all readers who are considering joining or contributing don't have to climb the learning curve of learning to decode cryptic references to other programs). Yes.
The bottom-line hint here is that folks involved with FVC who are also familiar with FLL will find a broader and more receptive audience for their suggestions, and be more clear about what they mean, if they are able to expresss those suggestions without using the "like FLL" phrase.
Blake
Unread 25-04-2007, 15:22
Blake
Custodians and other employees that may be "required" for an event can add dramatically to the cost factor. Electricians, building managers, safety personnel, etc. come to mind. Maybe a high school gym is large enough, I haven't laid it out to see.
Unread 25-04-2007, 15:42
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Even though many have stated that they would be against a two-day FVC competition, I still stand behind the idea*. To understand truly how the competition would work, you need to understand the FRC BattleCry@WPI off-season competition.
On Friday, matches start after normal school hours. The pits officially open at 4pm, and there are usually 2-3 hours of first practice rounds, and then qualification rounds. This way, teams do not have to miss school on Friday if they want to attend the competition. (Our FRC team goes to school on Friday as normal, and immediately the school day is over our team meets, packs up the robot and tools, and we drive off for the competition.) Teams are not required to attend Friday, and their rankings will not suffer negatively in any way from not attending on Friday. Basically, Friday (competition-wise) is just a bonus day.
Usually on Friday at BattleCry@WPI, they usually have a whole assortment of activities ranging from a BBQ, to ice cream socials, to movies, to bowling, to CRUD, to games based off of FIRST trivia. For teams who do attend on Friday, the atmosphere on that day is more of a "let's have fun!" attitude. And the amount of fun activities they plan is unrivaled at many other competitions, including some FRC Regionals!
For Friday night, there are hotels right near the WPI campus, as well as dorm rooms offered for cheap rates to teams attending the competition. (The competition is held in mid/late June, so their school year is over.) But if your team is less than 2 hours away and doesn't want to pay for hotels/rooms, then driving home for Friday night from the competition isn't out of the question.
On Saturday, the competition is played out as a normal competition would.
*But realistically, this idea of a multiple-day competition for FVC would not work everywhere in the country. The areas where is would be most successful are in areas with a high "density" of FVC teams, where teams could still reasonably commute for Friday's activities after school, as well as Saturday's, without needing a hotel room. Thus, costs would stay cheap and the program would still stay accessible, but now with the added "bonus day" of Friday.
New England is one such area where I can see a competition like this working, as we have a large number of FIRST (FRC, FVC, and FLL) teams all in a very small area, so for teams looking to save money by commuting this idea would be feasible. (FRC-team wise, there are over a dozen within 20-30 minutes of my house, including three in towns adjacent to mine.)
But in other areas of the country where the mileage between FVC teams can number quite high, then a multiple-day competition might not be as feasible.
Blake
ConnVex was held on a university campus, but there are a lot more issues (including capital to fund the event) that go into planning a FVC competition than just picking a gymnasium. With many of the things we needed to address, a university campus was identified as being better suited to host a competition than a high school.
Art Dutra IV
世上无难事,只怕有心人.
Unread 25-04-2007, 18:20
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
In some places I suppose unions and what-not do create some red tape and expenses.
Here in Virginia, I know one middle school just paid for custodial and any similar services as a way to repay Lockheed Martin and other sponsors for many years of stong support of the school. This was for a PVL scrimmage.
Back in January a local high school did something very similar for a PVL scrimmage. If the custodial services came out of our scrimmage fees, then the services were pretty cheap (fees were $20 and less per robot for about 14 robots). I suspect that the school paid for the services out of the school's budget.
Both of the above used ordinary gymnasiums that had tons of room for a second field, if we had cared to set one up. I don't think that either was required to keep electricians, or fire & resucue services, or... on hand.
Back in December, the Virginia FVC Championship put 29? teams into a large middle school without anyone feeling crowded, and put two fields in the school gym. Contact Virginia's AP, Darlene Panteleo for more info about the expenses and floor plan.
So, I guess regional differences account for part of the expenses and I guess that anyone who hasn't yet; should maybe investigate using a high school, middle school or elementary school for their next FVC event. Find one that has benefited from the community service support of one of your event sponsors and see if you can't get some of the expenses waived.....
Blake
Unread 25-04-2007, 22:38
rswsmay's Avatar
AKA: Robert
Blake,
I am not sure I fully follow exactly what you are trying to say here. For that matter I am not sure if you followed what I was trying to say. My comments are certainly not meant to be cryptic. To lay some background here, probably you and other individuals were unaware that after the pilot season of FVC, FIRST made a decision to have the FVC competitions follow in many regards the FLL tournament structure. I am not familiar with the full workings of FLL either since I came from FRC and now doing FVC also. However, knowing this, I have taken it upon myself to learn more about the FLL program in order to be better informed about what I believe is transferable and what isn’t. A discussion on the organization of FLL tournaments is more than we should get into here. There may be just as many people who have no idea about the organization of FRC if their prior experience has been FLL and FVC. Although I doubt this since Chiefdelphi is definitely centered around FRC, but you never know. For the most part I believe that most people that are reading through this thread has some knowledge about all three programs. If there is something specific that can elaborated on just let us know. Either those more knowledgeable or I can jump in and provide background info.
I have to point out though that I never said there was a need for a “multi-tiered tournament structure once the number of teams rises much beyond the current FRC numbers”. I also didn’t say that “things should work like FLL, but not exactly like it”. Hopefully knowing a bit more about the background of FVC as well as FLL will help you understand the comment. FLL has somewhere around 8000 teams compared to around 1500 FRC teams. If my memory is correct, over the past 3 years FLL has also added close to 500 teams per year. That growth potential definitely exists with FVC. Maybe not to the exact same numbers, but there would definitely be growing pains with those kinds of numbers. To organize, support and run the number of tournaments needed to accommodate that many teams would be a monumental task for FIRST. Now enters the affiliate partners. For the FVC program these partners undertake the organization of local and State tournaments, which may include volunteer recruitment, securing a venue as well and potentially seeking sponsors. Again with numbers like these, its not practical to have the top alliance from every tournament go to the championship. Therefore local tournaments determine which teams go to State tournaments, and the State tournaments determine who goes to the championship. It is entirely possible that if the growth continues there may even be another tier whereby the State tournament qualifies you for some type of Regional tournament. I’m just throwing the regional tournament comment out there because although its not a reality for FVC, it could very well come to that.
So what I am saying is that as much as you would like to have the learning curve shortened by using ordinary terminology, the fact is that this is pretty much ordinary terminology for the majority of posters here. I know I have read many of your posts regarding programming and the use of sensors and most of that ends up going over my head since my background is Mech. Engineering. Nonetheless, I would expect that the majority of posters that read through your posts find them informative, useful and totally appropriate including me at times.
Your point is well taken though… so when appropriate I will refrain from using references to FLL without laying some background.
But I can’t guarantee I’ll always be on my best behavior.
Blake
Unread 25-04-2007, 22:59
rswsmay's Avatar
AKA: Robert
Blake,
The folks here in Georgia have also thought about modifying the scoring software to suit our needs strictly for off season activities. We have been too busy until recently to contact Wildstang and/or Motorola about getting access to the source code to do that.
Also with new games out each year, FIRST usually has new scoring software written that is game specific. I am not sure what to tell you about undertaking something like that. Come September, that reworked code may not be very useful for the newly announced game. There is also the remote possibility that a new game in the future may utilize 3 teams per alliance (hint hint). The current field controls can accomodate up to 6 teams per field.
Blake
Unread 25-04-2007, 23:32
MGoelz's Avatar
MGoelz MGoelz is offline
Miranda: Design and Scouting
FRC #0234 (Cyber Blue)
MGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond repute
Send a message via AIM to MGoelz Send a message via Yahoo to MGoelz
It seems to me that FVC teams had a rough Championship; I couldn't imagine only four matches. I think that even if everyone opts out of lengthening the other competitions, the Championship should still be a little longer.
Especially with VEX being in only its 2nd official year, teams need more time to gain more experience. I participated in VEX during the pilot season and we went to St. Louis. I think, at the time, that was one of the nearest competitions. I think we just need to let it grow a bit, expand competition sites, and see where it goes from there. Most of it is going to depend on participation, and what seems to fit well with this program.
"The ideal engineer is a composite ... He is not a scientist, he is not a mathematician, he is not a sociologist or a writer; but he may use the knowledge and techniques of any or all of these disciplines in solving engineering problems."
— N. W. Dougherty
Unread 26-04-2007, 01:23
ManicMechanic ManicMechanic is offline
AKA: Yolande
VRC #0438 (Metal Gear)
ManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond repute
Originally Posted by Rich Kressly View Post
If I had to take an educated guess now, I'd be putting my energy into how to improve on the one-day format.
One way to make room for more matches is to interleave the interviews with matches. I've attached a spreadsheet that shows how a tournament of 24 teams (one field), 6 matches can be run with interviews conducted simultaneously with the first 2 matches. I'm sorry to say that it makes interviews even more stressful, but it does shorten the day. Perhaps some interviews could be spread into Round 3.
One feature of the match set-up is that any given team sees no repeat alliance partners and no repeat opponents (to my knowledge) across matches. This is one improvement that I feel would help the match-ups to be more even, lessening the need for more matches, as our team faced the same opponent 3 times at regionals and the same opponent twice in Atlanta.
The algorithm used to satisfy this condition is based on modular arithmetic. Basically, Round 1 moves from one slot number to the next in increments of 1, Round 2 uses increments of 2, Round 3 uses increments of 4, then inc 5, inc 7, and inc 11. If you have more or less than 24 teams, you can still increment by these values but lengthen or shorten the team list. If you have a number of teams close to a multiple of 24, (48, 72, 96), just change "n" from 1 to 25, 49, or 95 and repeat the blocks. Also, to shorten the day, one or 2 matches could be eliminated.
Unread 26-04-2007, 08:47
rswsmay's Avatar
AKA: Robert
Funny you should mention that particular method for conducting interviews during matches. We considered this early on in the planning of our tournament and came to the same conclusion. That it is a good idea but....
Interleaving the interviews with the matches did not seem like a good option for us because the scoring software generates the match schedule which may conflict with the interview schedule. We generated the interview schedule a couple of days in advance and e-mailed it to teams so they would have advanced notice of when they should be ready. We purposefully pushed some teams toward the end of the interview time period because some were traveling from out of State that morning. There was also the issue of no-show teams to the competition. When that happened and it did at 2 of the 3 state tournaments I attended, a new match schedule had to be generated which again threw off the time slots for teams to compete.
This issue of teams meeting each other multiple times during the matches is one that I saw repeatedly at all the events I attended. This is a "must have" needed improvement on the software. If we could have figured out a way to manually schedule the matches ourselves and then work the interviews around them (or vice versa) we would have been ahead of the game.
Hey.... what do you know!
Did we just come up with another suggested improvement on the scoring software? To be able to manually schedule teams into certain matches in order to facilitate the interviews or at least avoid the same teams matching up repeatedly.
Unread 26-04-2007, 10:21
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
You need to bring this issue up with the people running the events you attended. The organizers of the event control the amount of duplication seen by teams when they generate the schedule by choosing the "minimum match spacing" (which is the minimum number of matches a team has in between matches they are scheduled to play in). When this number is set too high, duplication will occur (due to basic math constraints). This is documented in the manual.
On photographs and FVC competitions... Billfred FIRST Tech Challenge 57 17-04-2007 16:39
[FVC]: [FVC]: [FVC]: [FVC]: [FVC]: Vex Slider Parts Thiele FIRST Tech Challenge 1 06-04-2007 10:00
[FVC]: FVC Off-season events, summer camps, workshops KathieK FIRST Tech Challenge 1 03-04-2007 22:56
[FVC]: Rhode Island FVC Championship Tournament KathieK FIRST Tech Challenge 0 03-03-2007 17:59
[FVC]: Rhode Island FVC program in Servo Magazine KathieK FIRST Tech Challenge 0 03-03-2007 17:55
