Go to Post Sustaining an FRC team is really hard! - Jared Russell [more]
Unread 27-04-2007, 11:02
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
Re: Snake Arm Robots
1875 made an amazing attempt this year with an idea one of their students had to do something like this. They found a way to do a version of what you are talking about for super cheap using a boat antenna ($15) some simple CNC'd X brackets to run cables up the antenna with, and mounts at the base. At the Florida Regional they were having problems staying within the starting dimensions (they would bend it around to look almost exactly like a question mark to start with and then it would spring out at the start of the match) as well as controlling it (they had one person controlling the 4 motors himself if I'm not mistaken, so considering they had no sensor feedback it was really, really, really innovative and definitely something I think should be pursued more). For the "complex" movements it achieved (360 degree turret arm that could extend out 8 feet or so from the robot) with such simplicity (4 cables and a boat antenna) it was quite a nice development within FIRST. I know a big issue with it was the spring force of the antenna is what was used to naturally make the arm go back up as the 4 other cables were released, so it was fine to pick up something like a tube, but to pick up a Tetra would probably be impossible (at least with a boat antenna) just since the weight is so massive in comparison to those tubes.
Here are some pre-ship photos of their robot, I wish I had some from the competition, but like I said they did have some problems with it and you can get the basic idea from these... very cool stuff.
http://www.chiefdelphi.com/media/photos/27108
http://www.chiefdelphi.com/media/photos/27096
http://www.chiefdelphi.com/media/photos/27078
Chopsaw? Chopsaw.
Unread 27-04-2007, 11:12
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
But does it recieve HDTV?
Unread 27-04-2007, 12:27
Rich Ross Rich Ross is offline
Let's get Desperate!!!
AKA: 830 Alumni
FRC #1504 (The Desperate Penguins)
Rich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond repute
Send a message via AIM to Rich Ross
Richard, i feel like a "snake arm" is not practical for FRC robots.
1) it doesn't look all that robust to me
2) it looks pretty heavy
3) It is sooooooo slow. This company (OC robotics unless my brain is jumbling things again) builds these things professsionally, and it takes a full minute to look at the underside of a car. Between the way these things are controlled and the way that the motors are mechanically set up, its not that beneficial overall as far as i can see.
1504, finalists WMR and judges award GLR
Let's get Desperate.
Unread 27-04-2007, 12:35
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Are there any videos of one of these flex arms running? Or one of 1875? I've never seen one actually run... but if they are as slow as i've herd I'm unsure how useful they could be.
However... the K-sub-WOW on this type of manipulator is runnin high...
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 27-04-2007, 12:43
Cowmankoza's Avatar
Cowmankoza Cowmankoza is offline
KoZa
AKA: Matthew Koza
FRC #1251 (The Tech Tigers)
Team Role: Operator
Cowmankoza has a spectacular aura aboutCowmankoza has a spectacular aura about
Send a message via AIM to Cowmankoza
I agree on the robustness factor, however I have seen methods in which an air bladder is placed on the "snake arm", the arm is sectioned and in effect limp, but when the air bladder inflates it extends the structure and makes it rigid, im sure that you can have more bladders, say on the side of the arm to give it a side to side motion. Therefore the weight is dropped drastically and as for speed, that is directly related to the volume and pressure of air being put into it.
As for FIRST robots, it seems unpractical to use an air bladder due to the limited volume we can store, as well as the question on wheter or not its legal (I doubt it).
Team 1251 The Techtigers
2008 UCF Regional Champs thanks to 233 and 86
2008 UCF Regional GM Industrial Design Award
2007 Palmetto Regional finalists thanks to 1626 and 1758
2007 Palmetto Regional Motorola Quality Award
2007 UCF Regional Champs thanks to 1270 and 86
2007 UCF Regional GM Industrial Design Award
2006 Palmetto Regional Champs thanks to 11 and 247
2006 UCF Regional Semifinalist thanks to 86 and 710
2005 Palmetto Regional finalist thanks to 25 and 301
2005 Palmetto Regional Xerox Creativity Award
2005 UCF Regional finalists thanks to 845 and 1270
2005 UCF Regional Judges Award
2004 UCF Regional Rookie All-star Award (The real winner)
Snake bots slithering in mechanicalbrain Televised Robotics 4 04-10-2009 11:00
Letting robots on top vs getting on top of robots sanddrag Rules/Strategy 44 09-02-2007 10:50
Are FIRST robots actually robots? EHaskins General Forum 39 14-12-2006 21:40
pic: Arm vs Arm CD47-Bot Extra Discussion 2 13-03-2003 12:37
MY ARM!!! Jeff Rodriguez Chit-Chat 6 18-05-2002 20:24
