pic: Cooney 269's Worm Crab Gearbox Interior
Re: pic: Cooney 269's Worm Crab Gearbox Interior
How did this design work out for your team? Do you have any close up videos of it functioning? I've always been a bit interested in worm gear designs.
that looks like a really cool idea!
It worked wonderfully for us this year and we are already looking foward to improving it over the summer and seeing if it may just be applicable for next year's game.
Here are some videos of our drive in action. Prototype (1st ever run): http://youtube.com/watch?v=rfAdy3tUx2s Some footage of our first run at Wisconsin (broken arm, defense only): http://thebluealliance.net/tbatv/match.php?matchid=628 A run at Toronto: http://thebluealliance.net/tbatv/match.php?matchid=3587 |
How many degrees can those wheels turn (from the videos, it looks like it never made a full 360)? Also, is there something like a limit switch keeping it from making a full turn, or are the drivers just very careful?
The design looks awesome, by the way. |
#7
This is very true, and a lot of people seem to think that these AndyMark wheels are equivalent to the old Skyway kit wheels. In practice,the difference between AndyMark Kit wheels and most high traction wheels is so small that driving makes a much, much bigger difference in defensive maneuvers and keeping from being defended. The only reasons I can see for using other wheels are for differences in size, and drive method. (Although I am aware of two materials that can be put on wheels to get a coeff. of friction of about 1.6, but both are a touch pricey, and one seems rather hard to put on a wheel)
#9
Actually we even added Armoral to the wheels to make them slicker, so they actually acted more like the skyway wheels. We were having turning problems so we decided that mobility would be more important.
The gearboxes turn 90 degrees in both directions, similar to Beatty's 2006 robot, I believe. We looked into a 360 gearbox but it would have required the rotation to be at the top of the motor due to the offset motor placement. |
#10
The problem with Worm drive on the main wheels is that Worm drive is very ineffecient. What this means is that it draws a lot of battery power to drive the wheels. Last year team 772 . used a worm and wheel and at the start of a match could drive up last years ramp- ( the ball shooter ramp) . but at the end of the match after they run the battery down for 2 mins. could not.
Worm and wheel is good for high reduction ratios and if the worm pitch is choosen properly- self locking. - that a bout it.- they are generally high is sliding friction and cannot coast. If you want a "coastable" robot - do not use it. In a nut shell- don't waste your time.- if it was good all the good teams would be using it.! |
#11
The major problem I see with a worm gear on the main drive wheel is that for the wheels to "lock" and not move, inwards or outwards pressure is directly put onto the motor shaft. There are ways around it (shaft collars is the first thing that comes to mind), but it definitely could wear a motor down over the course of the 30-50 matches your robot has a potential to compete in if it's not accounted for.
Other than that it's a very nice simple design, especially for a defense+ramp robot this year. |
#12
We have never used a worm/worm gear combination for a drive but we have used it at the elbow of an arm. We needed to maintain a high level of efficiency and went with a 4-lead worm. I would worry less about the efficiency and more about sheering teeth in a pushing match. You may find that the wheels slip before the teeth fail but it can happen. Trust me! We experienced it at IRI in 2005. ![]() Great looking drive Cooney! I was impressed with the prototype video when I saw it a couple months ago. Very smooth! Sean |
| FRC 269 Worm Crab 2007 Video | Ricky Q. | Robot Showcase | 3 | 02-21-2007 08:59 PM |
| pic: 269's Underwater Robot | AndyB | Extra Discussion | 9 | 10-07-2006 06:19 PM |
| pic: 269's Westin Battery Farm | Ricky Q. | Extra Discussion | 4 | 05-02-2006 07:16 AM |
| pic: Team 269's 2006 Robot - Annie Oakley | Ricky Q. | Robot Showcase | 3 | 02-21-2006 04:30 PM |
| Worm Gear Gearbox | dddriveman | Technical Discussion | 38 | 01-07-2005 02:43 PM |
