Go to Post F.I.R.S.T. Troubleshooting Rule #1 - If you work on software, the problem is always with hardware. If you work with hardware, the problem is always with software ;) - Redneck [more]
Unread 27-04-2007, 12:52
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: pic: FVC 2013 Gear shifter
Thanks for posting this. I came up with a 10" wide version of this for a single side and couldn't figure out how to get it down to 9". Going length-wise just might be the key depending on the game and the robot's necessary manipulator clearance. Unfortunately with this design, it's not very plausible to add another 1-2 motors to each side without adding an entire new shifting mechanism.
If I ever get my current concept idea done I'll rebuild the old (10") design and show you what I mean -- 3 motors per side and it could push 40lbs of books across my carpet if I pushed down on the back of the bot with my finger for traction. (5:3 High and 1:6 Low)
GitHub
Unread 27-04-2007, 14:25
gdo's Avatar
gdo gdo is offline
Never too much duct-tape ;)
AKA: Patrick
FTC #0001 (Team Unlimited)
gdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to behold
Send a message via AIM to gdo Send a message via MSN to gdo
This design is relatively compact. It is 1" wider than a square robot, and the same length as a square bot.
FTC #1: http://unlimited.syraweb.org
Got any question for me; AIM, MSN or PM me
[FVC]: [FVC]: [FVC]: [FVC]: [FVC]: Vex Slider Parts Thiele FIRST Tech Challenge 1 06-04-2007 10:00
pic: 1732's 2 servo shifter John Wanninger Extra Discussion 1 04-03-2007 23:27
pic: team 1029 shifter bjimster1 Robot Showcase 4 21-02-2006 10:23
pic: AM shifter mount close up falconmaster Extra Discussion 2 18-01-2006 19:27
pic: Vex 2 Speed Mesh Shifter Matt Krass Extra Discussion 11 17-10-2005 20:58
