Go to Post Is there a way to spotlight an entire thread? - ctt956 [more]
  #31   Spotlight this post!
Unread 03-04-2007, 17:48
jmcr8on jmcr8on is offline
AKA: Jim Creighton
FRC #1189 (Gearheads)
jmcr8on is on a distinguished road
Re: 1189 - Human-Bot Arm Control
Originally Posted by WahooWa View Post
That is really cool. Great job guys. We were going with something like that, but decided to switch to a minature model of the arm instead.
http://www.youtube.com/watch?v=7mF8CKpf-80
Part of that is how far we got on the similar design.
Cool Controls 1189.
Yeah...looks good and was working. Why did you switch?
....you have a lot better music! We just have lame background noise in ours.
Team 1189 - Gearheads
  #32   Spotlight this post!
Unread 03-04-2007, 17:50
AKA: Jim Creighton
Originally Posted by vivek16 View Post
could i have this white paper?
i am trying to do an easier way to wire the pots to the OI and your designs would be very helpful.
thanks
Yep...will drop it to your email in your profile. Give me a couple of days if you don't mind....catching up on the other non-FIRST part of life....
  #33   Spotlight this post!
Unread 03-04-2007, 17:58
AKA: Jim Creighton
and also here is a pic of the OI
(removed)
where on here did you wire the pots to? on the ifi site it says that it has 16 analog inputs but i cant see them on here anywhere.
thanks
The 16 analog inputs are on the RC. Section 9 (page 8) talks about those. Here is the RC paper from IFI: http://www.ifirobotics.com/docs/rc-r...-6-13-2006.pdf
Here is a paper from IFI on the OI that will explain the use of each game port pin. From this you can see which are analog and which are digital..and which will light up LEDs. http://www.ifirobotics.com/docs/oi-r...de-1-30-07.pdf
Tables 4.3.1-4.3.4 cover the game ports.
In the paper I send it will have the pin-out assignments we used.
  #34   Spotlight this post!
Unread 03-04-2007, 18:05
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
all right, thank you very much.
"we don't build robots, we build people"
  #35   Spotlight this post!
Unread 03-04-2007, 21:11
vivek16's Avatar
AKA: vivek
by the way, how did you guys decide to do this control system?
im sure some other teams with an arm thought of something like this but was there a person who researched and/or drew up designs to show the team that this was do-able?
  #36   Spotlight this post!
Unread 03-04-2007, 23:11
AKA: Jim Creighton
Well....here's the story:
We had two joy sticks and found it was not very intuitive to control the arm segments, wrist joint, wrist rotation and turret rotation. The team did not have a lot of time to practice.....
At BMR Team 1138 (Eagle Engineering) was in the pit next to us. Their robot did not show up until 4:00 PM on Thursday (it was lost, not shipped, wrong truck, etc.). Their robot (when it did arrive) had a similar (without the turret) arm segments as our bot....and they used a joy stick. But...they showed us this OI with a small segmented wooden arm and pots on plexiglass that was manipulated by their fingers....that they had not yet been able to get to work successfully. On Saturday afternoon they got it to work.....and it was cool.
On the 5.5 hours drive back to Grosse Pointe from BMR I worked out a physical prototype in my head....knowing that most of the arm code was already in place from the PID control and the functions that the programmer had already written (good ol' modular code). During a fix it window we built a simple wooden prototype, attached pots and lots of loose wires back to the OI game port...and duct taped it to my son's (the programmer) arm.
The prototyped proved to be feasible.
In the next fix it window the build team constructed the arm, the wiring was done (good ol' LAN cables and modular connectors)....and it was tested....the pots tweaked...and tested...and tweaked...and tested...and finally passed the tests to be called 'good'.
So..we gained inspiration from Team 1138's concept and took it to the next level.
btw....a thank you email was sent to Team 1138 for their sharing and inspiration. And now... a public note of thanks: Thank You, Team 1138.
  #37   Spotlight this post!
Unread 03-04-2007, 23:24
chaoticprout's Avatar
chaoticprout chaoticprout is offline
can't wait for next years VRC
AKA: Michael Montazeri
FRC #1138 (Eagle Engineering)
chaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant future
Send a message via AIM to chaoticprout Send a message via MSN to chaoticprout
No problem, I'm very happy that control worked out for you guys, we were talking about this at BMR, awesome stuff.
2009 Los Angeles Regional - Chairman's Award
2009 Granite State Regional - Engineering Inspiration Award
2007 Los Angeles Regional - Engineering Inspiration Award
2006 Southern California Regional - Regional Champions
  #38   Spotlight this post!
Unread 04-04-2007, 00:46
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Originally Posted by Animus View Post
After autonomous, it took me about fifteen seconds to get myself completely strapped into the hockey pads (donated by one of the team members as an attachment for the arm). I learned to do it on my own so the driver was free to move the bot for the first 10 seconds of the match - I had three or four seconds of lag time between the buzzer to end autonomous and the activation bell. Not that this came down to any sort of precise art.
A note on this for individuals who would like to use this or a similar idea in the future: one team in 2005 (I don't remember which) had an arm mounted controller much like this one. In order to get around "strap-in" time, they simply waited untill the beginning of teleoperated period to plug the arm controller into the OI - it's fine if you are wearing it during autonomous, as long as it is not connected to the OI! Plugging a DB-15 into the OI should take way less time (2-3 seconds total) than putting the assembly on.
Hope this will help people trying to use a control system like this maximize efficiency in the future!
//Dillon Compton
www.metalmoose.com
  #39   Spotlight this post!
Unread 04-04-2007, 11:43
vivek16's Avatar
AKA: vivek
i believe the team you are talking about is team 25. they used an arm similiar to this in '05
  #40   Spotlight this post!
Unread 18-04-2007, 14:47
sporno's Avatar
sporno sporno is offline
AKA: David
FRC #0540 (Talon)
sporno will become famous soon enoughsporno will become famous soon enough
Send a message via AIM to sporno
very coool ... i saw this and it made me raise an eyebrow!
2005 NASA/VCU Quarter-finalist
2006 NASA/VCU regional-Semi-finalist
2006 FIRST Robot Rumble-Quarter-finalist
2006 FIRST Robot Rumble-Most Promosing Rookie Drive team.
2006 Championship-Curie
2007 NASA/VCU- Regional Winner
2007 Championship-Galileo
2007 FIRST Robot Rumble-Semi-finalist
80+ matches on the field
  #41   Spotlight this post!
Unread 18-04-2007, 15:19
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Lightbulb Re: 1189 - Human-Bot Arm Control
Wow, thats awsome, I would love to build one of those. Could I get the so called white paper?
Thanks
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
  #42   Spotlight this post!
Unread 18-04-2007, 17:09
Cartwright Cartwright is offline
Scouting/Manufacturing
AKA: Jamie
FRC #0234 (Cyber Blue)
Cartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to behold
We did a similar thing called "the Backpack" a few years ago; we too were going to do that kind of arm control, but we decided not to later. Yours looks great!
  #43   Spotlight this post!
Unread 19-04-2007, 01:26
AKA: Jim Creighton
In watching the championships...and the speeches/introductions.... There was this interesting human arm control that Dean and his team made for DARPA. 14 degress of freedom..if I remember correctly....
  #44   Spotlight this post!
Unread 19-04-2007, 09:54
mikeleslie mikeleslie is offline
FRC #1189
mikeleslie will become famous soon enough
We takked a lot about whether having on before the match but not plugged in would be acceptable and decisded it wouldn't. It's great to hear that we can wear it and then plug it in after auton.
  #45   Spotlight this post!
Unread 27-04-2007, 21:10
luciaes luciaes is offline
AKA: shawn
FRC #0830 (rat pack)
luciaes is an unknown quantity at this point
830 had a similar arm control system, we had a small miniature arm that controlled our main arm but we didn't get it working till waterloo. but it got us the xerox creativity award at waterloo
Ramp bot vs. Arm bot SSMike Technical Discussion 49 22-01-2007 21:03
Arm Placement on Bot? Po-ser Technical Discussion 7 13-01-2007 15:19
Human Arm based controller Andrew Schuetze Control System 5 09-10-2005 15:05
Slave Control Arm aaronD341 Control System 1 26-04-2005 17:13
2-Segment Arm Control Orborde Programming 1 20-01-2005 01:40
