Go to Post know what else would be great? with each new rep point you get 10 airline miles on your Visa or MasterCard - KenWittlief [more]
Unread 28-04-2007, 13:20
dbell dbell is offline
Mentor for team#3937 (Breakaway!)
AKA: David Bell
FRC #1519 (Mechanical Mayhem)
dbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to behold
Cantilevered drive wheels?
I have found that most drivetrains have the drive wheels supported on both sides like the kitbot base. Some however have their drive wheels cantilevered on the outside of their base.
Here are 2 cantilevered bases. (very good robots)
http://www.chiefdelphi.com/media/photos/26944
http://www.chiefdelphi.com/media/photos/25814
Here are 2 non-cantillevered bases.
http://www.chiefdelphi.com/media/photos/28450
http://www.chiefdelphi.com/media/photos/27587
Which do you use? Why?
What are the advantages to each of them?
Unread 28-04-2007, 13:26
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Cantilevered drive wheels?
non-cantilevered wheels are easier to mount (just drill two holes and poke a bolt thru them). They also have an outside frame member that protects the wheels from damage, or from getting flat tubes tangled up on them.
Cantilevered wheels can be easier to work on, since there's no frame member in the way. They also can offer more tipping resistance, as they can be located at the outer edge of the 28" wide robot footprint.
Unread 28-04-2007, 13:44
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
We went with cantilevered mecanum wheels with hex bores. We did this for ease of maintenance on the wheels, so we could easily take them off. We had bumpers (that had abs blocks that slid into the chassis aluminum tubing) around its perimeter to protect the wheels.
We had addition reduction with another gearbox on the output of the banebots planetary. Disassembling this drive to check for maintenance was no problem because everything just slid apart after we loosened some nuts and bolts.
Our team had been sort of scared of cantilevered wheels and the effects it would have on the shaft, chassis, bearings, and such. It turned out working really well.
Below is a render of the drive.
Unread 28-04-2007, 14:21
Guy Chriqui Guy Chriqui is offline
AKA: Guy Chriqui
FRC #0004 (Element)
Guy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really nice
After 4 years of cantilevered wheels I have to say that we haven't had an issue with them yet. They are easy to maintain and totally the best way to show off your rims. Can't forget the fact that if you have hex shafts (i.e. 968/254) changing out a wheel takes about 5 seconds.
-guy
team4element
run the trap!!!
Team Role: Human Player
Originally Posted by Stonefan5271138 View Post
We went with cantilevered mecanum wheels. We did this for ease of maintenance on the wheels, so we could easily take them off.
I've heard 254/968/4 say the same thing - that it helps them replace wheels. But how often do you have to replace your wheels ? Its not a problem I've ever experienced.
I do agree that cantilevered wheels will definitely help with stability. And using bumpers is an easy way to protect the wheels.
-Philip J. Fry
Unread 28-04-2007, 14:28
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Conveyor tread can wear out quickly in competition, and usually the quickest way to swap the tread is to just stick on another wheel with new tread. I know that by the end of our first regional our robot had nearly bald center wheels.
Unread 28-04-2007, 16:01
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
We change the tread on our wheels anywhere between one and three times during a competition, depending on how it's wearing. Being able to swap out every wheel in under a minute is a huge advantage.
2001-2004: Team 100
2006-Present: Team 254
Unread 28-04-2007, 20:48
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
696 has used cantilevered wheels for the past three years. It ends up saving a good deal of space and weight, as well as giving a wider footprint for better stability and turning moment, and it allows the wheels to come off easily for replacing tread. The only downside is if someone pushes a bumper up against your wheels, you might be stuck goin no where. But you can put in gaurds for that if you'd like.
Unread 29-04-2007, 07:50
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Team 47 has had both types of wheel to frame designs.
Both have worked out okay, but we prefer supporting the wheel axle on both sides.
Reasons include -
Loads are supported better.
Wheels and chain are protected better.
Easier to mount bumpers with an outer frame.
Mike
Unread 29-04-2007, 07:59
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
One thing that hasn't come up yet is the loading on the axles. Cantilevered axles have a much higher load bending loads on on them than axless that are supported on both sides. We opted to go with cantilevered shafts for the wider base and ease of maintenance (which proved to to be the right choice for us.) But we looked at the math and planned accordingly when picking shafts - 5/8" Igus shafting.
Despite some of the other problems we had relating to keyways and such, we never bent a shaft.
This spreadsheet should help clarify the math...
Mark
Brick walls are for other people. - Randy Pausch
Unread 29-04-2007, 15:17
AKA: David Bell
Thanks for your advice everybody.
If you use cantilevered drive wheels you probably a live axle(right). But how do you attach the wheel to the axle, and have good support? And keep the wheel from falling off?
Unread 29-04-2007, 15:20
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Assuming you have a key or use hex shaft, then transferring rotation to the wheel is done by rotating the shaft, There are two common ways of fastening the wheel to the axle: the first is by attaching a hub with a flange onto the axle, then the wheel is screwed on or off when needed. The second way is to machine an integral hub onto the axle, like this
(Yes, CD members, I know this picture is for a different part of the robot) Then the wheel with a matching hole profile is put on the shaft/hub.
As for keeping the wheel on the hub, you can use retaining rings that clip into a circular groove around the end of the shaft, or screw the wheel onto the hub.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 30-04-2007, 07:27
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Our 2006 shooter bot used cantalievered wheels on our track systems, If any of you remember us having issues with tracks getting walked off if we were being pushed around a turn, we fixed that in the off season.
The fix was, always use two ball bearings, not one, even if the specs say it can take the torsional loads...
Anyhow, yes, cantaliever wheels do take a little more work (we had to design and machine our axles) but they make the robot extremely easy to work on.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 30-04-2007, 10:58
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
We use non-Cantilevered drive wheels because as a defensive robot we expected a lot of torque and shock running through our drive system.
We used pneumatic tires so we did not have to worry that much about tread wear (like those that use roughtop).
___________________
- Tennyson, Ulysses
Drive Train and wheels Evil Asian Technical Discussion 13 09-03-2007 10:23
Extending a cantilevered drive shaft. Madison Technical Discussion 18 04-11-2005 00:27
pic: kiwi drive wheels CD47-Bot Extra Discussion 3 24-08-2004 21:39
Rumor or no--- WPI has 12 drive wheels?!?!?! archiver 2001 12 23-06-2002 23:22
Drive wheels pfortunejr Technical Discussion 2 12-01-2002 12:24
