Go to Post Same as regrets in life: Learn from them. This is called "growth". - DonRotolo [more]
Unread 29-04-2007, 07:59
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: Cantilevered drive wheels?
One thing that hasn't come up yet is the loading on the axles. Cantilevered axles have a much higher load bending loads on on them than axless that are supported on both sides. We opted to go with cantilevered shafts for the wider base and ease of maintenance (which proved to to be the right choice for us.) But we looked at the math and planned accordingly when picking shafts - 5/8" Igus shafting.
Despite some of the other problems we had relating to keyways and such, we never bent a shaft.
This spreadsheet should help clarify the math...
Mark
Brick walls are for other people. - Randy Pausch
Unread 29-04-2007, 15:17
dbell dbell is offline
Mentor for team#3937 (Breakaway!)
AKA: David Bell
FRC #1519 (Mechanical Mayhem)
dbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to behold
Thanks for your advice everybody.
If you use cantilevered drive wheels you probably a live axle(right). But how do you attach the wheel to the axle, and have good support? And keep the wheel from falling off?
Unread 29-04-2007, 15:20
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Assuming you have a key or use hex shaft, then transferring rotation to the wheel is done by rotating the shaft, There are two common ways of fastening the wheel to the axle: the first is by attaching a hub with a flange onto the axle, then the wheel is screwed on or off when needed. The second way is to machine an integral hub onto the axle, like this
(Yes, CD members, I know this picture is for a different part of the robot) Then the wheel with a matching hole profile is put on the shaft/hub.
As for keeping the wheel on the hub, you can use retaining rings that clip into a circular groove around the end of the shaft, or screw the wheel onto the hub.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 30-04-2007, 07:27
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Our 2006 shooter bot used cantalievered wheels on our track systems, If any of you remember us having issues with tracks getting walked off if we were being pushed around a turn, we fixed that in the off season.
The fix was, always use two ball bearings, not one, even if the specs say it can take the torsional loads...
Anyhow, yes, cantaliever wheels do take a little more work (we had to design and machine our axles) but they make the robot extremely easy to work on.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 30-04-2007, 10:58
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
We use non-Cantilevered drive wheels because as a defensive robot we expected a lot of torque and shock running through our drive system.
We used pneumatic tires so we did not have to worry that much about tread wear (like those that use roughtop).
___________________
- Tennyson, Ulysses
Drive Train and wheels Evil Asian Technical Discussion 13 09-03-2007 10:23
Extending a cantilevered drive shaft. Madison Technical Discussion 18 04-11-2005 00:27
pic: kiwi drive wheels CD47-Bot Extra Discussion 3 24-08-2004 21:39
Rumor or no--- WPI has 12 drive wheels?!?!?! archiver 2001 12 23-06-2002 23:22
Drive wheels pfortunejr Technical Discussion 2 12-01-2002 12:24
