Go to Post Life? What's a life? I mean, outside of [I]FIRST[/I], that is. - Blue_Mist [more]
Unread 16-04-2007, 18:09
Darkforces's Avatar
Darkforces Darkforces is offline
Froforces
AKA: Taylor Burch
FRC #1875 (Autonomato Atonamatons)
Darkforces will become famous soon enoughDarkforces will become famous soon enough
Send a message via AIM to Darkforces
Re: Mechanical Vs Electrical
I do a little of every thing but id have to say that Computer/virtual wins, cant build the robot without the design and cant wire without the schematics, jk we all need each other to get the job done so its all good.
Unread 16-04-2007, 19:21
Jay Shah's Avatar
Jay Shah Jay Shah is offline
FRC #0610 (Crescent Robotics)
Jay Shah is a jewel in the roughJay Shah is a jewel in the roughJay Shah is a jewel in the roughJay Shah is a jewel in the rough
This is how it works on team 610:
Mechanical is defined as fabrication, design (excluding cad) and assembly.
Electrical is defined as sensor work, wiring, IFI component placement and integration with mechanical stuff (such as if there is a turret, the electrical people have to work to make sure there is slack in the wires and also that it's not going to get tangled with other robots)
Mechanical basically always has more say than electrical. Generally the electrical system is based around the mechanical system (which is designed with little electrical consideration)
So far it has worked reasonably well; however we always run into the issue near the end of season were the electrical is running behind because the mechanical is running behind. The end result: our programmers suffer.
2004: GTR, Arizona (electrical/fabrication)
2005: GTR, Sacramento (electrical/programming/pneumatics)
2006: GTR, WAT, Champs (team leader)
2007: GTR, WAT, BAE (mentor)
Class of 2011, Mechatronics Engineering, University of Waterloo
Class of 2006, Crescent School
(formerly known as 'ChayChay' on these forums)
Unread 29-04-2007, 22:05
I.U.man_22 I.U.man_22 is offline
AKA: phillip
FRC #2360 (POWER Storm 2360)
I.U.man_22 will become famous soon enough
Send a message via AIM to I.U.man_22
We have more mechanical people on our team than we do on electrical. I myself is on the mechanical part. There is about four or five on electronics but 10 or more on mechanical.
Unread 29-04-2007, 22:46
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Our Electrical team is 2 or 3 people.
Our Mechanical team is 10 or so.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 29-04-2007, 22:52
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Electrical all the way baby!
On our team I guess two thirds of the team is mechanical and one third is electrical. But that could be because we have it set up in that kind of fashion. We have three subgroups and 1 sub-subgroup. The three subgroups would be upper body, base, and controls, and the 1 sub-subgroup was programming which falls under controls. With this past year aside, we have always had more mechanical guys than electrical guys, just because it seems that there is a lot more freedom in mechanical as to how you can design parts and work with the robot.
The exception to this freedom lies this year, as the controls and programming divisions were officially split. This made controls smaller than it usually always is and on top of that this year, we decided to use Pro/E and Inventor to our max, and created a bunch of interesting mounting plates for both our brain and compressor. I am one of the ones on our team that sometimes utilizes a program that makes PCBs so on top of getting some creativity designing mechanical parts and laying out our brain on CAD, I get to design my own boards and stuff which gives me some space and creativity of my own on the electrical side.
I think that controls is near the same every year. Sure you have twists and turns, but the focus is the same every year and you are just improving yourself. With mechanical aspects you are redesigning the way things are done because every years game is different.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 29-04-2007, 22:58
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
The Mechanical Team has to be bigger, because they work for the first 5-1/2 weeks building.
The electrical and programming group only as the robot for a few days, so they can have a much smaller group.
i always assumed that was why the electrical and programming teams just wanted the robot for a few days, right at the end......
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 29-04-2007, 23:02
Brian J. R.'s Avatar
Brian J. R. Brian J. R. is offline
Pit Chief
AKA: Brian Richards
FRC #1983 (Skunkworks)
Brian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to behold
Send a message via AIM to Brian J. R. Send a message via Yahoo to Brian J. R.
Our team is fairly small with 18 people. Most do multiple jobs, such as Graphics and Mechanic. We have 6 mechanical, 2 electricians (one of which is vice pit chief) 2 of the mechanics are Graphics, and 2 of the mechanics where on the drive team, the other electrician was the human player. So we have 1 pure electrician and 2 pure mechanics, thoes who have no other jobs.
With a new wave of people next year there should be more seperation of sections, but the 3 teams (drive, mechanical, and electrical) should stick very close together.
Unread 29-04-2007, 23:09
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Originally Posted by Budda648 View Post
Holy thread revival, BATMAN!!!! I thought all threads pre-2003 were locked. Wowzers...
Yeah really... I'm surprised no-one else has said anything...
Oh well. Guess it was a good topic
Jacob
FunkyRatDemon's Avatar
FunkyRatDemon FunkyRatDemon is offline
Marketing, PR, Operations, Mascot
AKA: Jake M Masin
FRC #0753 (The High Desert Droids)
FunkyRatDemon will become famous soon enoughFunkyRatDemon will become famous soon enough
Send a message via AIM to FunkyRatDemon
At least you have people which want to do those, we have 3 people on our marketing team, i had to forcefully recruit those 2 (i'm the other)
Our website! www.team753.com
Like tracks? We do! For info on using them go here http://outbackmfg.com/pages/1/index.htm
Attending: NW Pacific and UC David Sacremento Regional
Unread 29-04-2007, 23:32
Pavan Dave's Avatar
Busy in College
Jacob
At least he "searched" before posting! He deserves props for that. Isn't that what everybody preaches (myself included)?
Pavan.
1745 - 118 - ΔΕΨ
Unread 29-04-2007, 23:35
AKA: Jacob Komar
Pavan.
Absolutely! I'm not complaining at all. I'm commending what he has done. I'm just saying that I'm surprised that noone else had made any other comments to this effect; The conversation continued as normal.
Jacob
Unread 29-04-2007, 23:56
Rich Ross Rich Ross is offline
Let's get Desperate!!!
AKA: 830 Alumni
FRC #1504 (The Desperate Penguins)
Rich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond repute
Send a message via AIM to Rich Ross
Our electrical team was a small number of students (i want to say 2 or 3, but may have only been one), but in many ways was in the best shape because we had two GM engineers helping with the E board.
Mechanical was a lot larger, but they obviously dealt with a lot of things like electric motors and such.
1504, finalists WMR and judges award GLR
Let's get Desperate.
Unread 30-04-2007, 10:02
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
umm yea i was the only electrical... and pneumatics... and programming... and sometimes the weight hole person.
Unread 30-04-2007, 15:59
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
We had twelve people on the mechanical team this year, though nearly everyone else (myself included) has basic mechanical training and helps out as needed. The electrical team only had four members this year, and two of them are seniors. We hope that when we take on new members this May that some of them will be interested in electronics.
"Mechanical" for us is divided into two categories. We have students who are trained how to use specific machines (mill, welder, lathe, CNC, etc) and those who just know how to use the simpler machines (band saw, drill press, hand drill, grinder, sander, etc). NOBODY uses the table saw without an adult. About half of our mechanical team falls into this "special training" group, and the other half cuts basic parts and assembles the robot.
Where can I learn some mechanical before build season John JediMaster General Forum 7 23-09-2003 20:27
How does your team organize its electrical supplies? Josh Hambright Electrical 8 28-11-2002 13:01
Drill motor copper electrical connector archiver 2001 1 24-06-2002 00:57
Mechanical Engineering archiver 2000 0 24-06-2002 00:04
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
