Go to Post As Frank said, when an FRC team hurts, we all hurt. - Hallry [more]
Unread 30-04-2007, 07:47
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: Robot chassis shape
We did some... http://www.chiefdelphi.com/forums/sh...53194&p=569665
Coming up with the load cases was the hard part. We just ended up using a relative comparison. Now that I'm aware of the IRI definition for high speed ramming I've got something solid to work from.
Mark
Brick walls are for other people. - Randy Pausch
Unread 30-04-2007, 08:12
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Not so much this year, but last year when we were really having a tough time with weight I ran stress analysis on most everything (especially parts in the shooter itself) as well as the drivetrain (except for the wheels... something i would later regret! ) to see where weight could be taken out...
result: a very lightweight and cool looking frame, plus a shooter assembly total weight of 20lbs
the stress analysis is also a great way to learn the limits of materials you use everyday; like plate aluminum, UHMW, etc. I ended up making the track guides for our '06 bot out of UHMW thanks to the ability to rapidly prototype in the ANSYS stress analysis system... cool stuff.
on the ultimate shape, it seems that for manipulators the triangle always looks to be the best shape ( 2005 bot ) since it allows for the longest arm. Other than our '05 bot we've always had a rectangular frame, boring I know, but easy to work on and build. Thanks to bumpers, one interesting frame option that really helps out in the pits is cantalievered wheels ( example ). bumpers also make it a little more feasable to use a welded frame since you don't have to worry about shock loading on welds as much, so we tried our first welded frame this year ( near complete 2007 bot ).
Still, for our team at least, it seems that rectangular frames for most everything but for heavy lifting the sheet metal triangle works best.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Robot Size and Shape: What's Best? SSMike Technical Discussion 14 03-02-2007 13:39
Guess the shape Cyberguy34000 Chit-Chat 1 21-04-2006 22:59
NASA tests shape-shifting robot pyramid for nanotech swarms Alan Anderson NASA Discussion 3 31-03-2005 14:41
pic: Fiberglass robot chassis falconmaster Robot Showcase 13 08-02-2005 23:42
Best Body shape? dddriveman Technical Discussion 34 06-11-2003 16:13
