Go to Post That box you think you see is only an illusion. - Alan Anderson [more]
Unread 29-04-2007, 00:26
Cartwright Cartwright is offline
Scouting/Manufacturing
AKA: Jamie
FRC #0234 (Cyber Blue)
Cartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to beholdCartwright is a splendid one to behold
Robot chassis shape
I saw an old closed thread about the shape of robots' frames, and I was just wondering what was considered best particularly for robustness. Is a simple rectangular bot good, or a more abnormal looking robot best? Also what are the downsides to each shape.
One of the old posts talked about how the shape shouldn't be designed, but that it should just sort of evolve with you robot's creation. How about it?
There are many robots out there. Which shape is best for robustness, compatability, and effeciency in electrical organization and drive trains?
Unread 29-04-2007, 00:40
Vashts6583's Avatar
Vashts6583 Vashts6583 is offline
The sleepless
AKA: Rob Metzger
FRC #0007 (Team 007)
Vashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to all
Send a message via ICQ to Vashts6583 Send a message via AIM to Vashts6583 Send a message via MSN to Vashts6583 Send a message via Yahoo to Vashts6583
Re: Robot chassis shape
Honestly, it depends on your robots' functionality. The most common top-down shape is rectangular, but if you feel that your robot needs a different shape for your auxiliary to perform better, then by all means, go ahead, as long as you don't sacrifice your machine's stability and structural strength.
2005: Software Assistant
2006: Software Head
2007: President/Driver/Software Head/Temporary Safety Captain
//2005: Chesapeake Regional - Finalist
Life is what you do outside of FIRST. No wonder it's so short.
Unread 29-04-2007, 00:44
Billfred's Avatar
Billfred Billfred is offline
It depends on your desired role.
For offensive robots, 179 in 2005 had it about figured out--it was harder to catch a corner and stay on it. For defensive robots, we (being 1293) learned in 2006 that our ball intake was good for catching the aforementioned corners when we had to play defense.
Unread 29-04-2007, 17:16
IMac's Avatar
IMac IMac is offline
AKA: Ian
FRC #1634 (WIRE)
IMac is an unknown quantity at this point
Send a message via AIM to IMac
Our Vex team tried using a Triangular shape for their robot. While our mentors thought it was a revolutionary concept (being more difficult to block and easier to control), it ended up simply being a hinderance. The team agreed the triangular shape made it harder to center and attach parts.
The odd shape design could potentially be a good idea, but only after it's been worked on extensively. Otherwise it's just for show.
Unread 29-04-2007, 17:20
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
For those of us who have limited experience in FIRST, could you please post links to pictures of what you're discussing?
Much appreciated,
-MT
Hi!
Unread 29-04-2007, 17:44
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
I saw a team in Atlanta this year (can't remember the number, I think in the 900s, but can't recall right now) that I was very impressed with. They started with a rectangular base with rounded edges on the front and back and had two drop down sides that fell so it became a complete, uniform circle at about 3 inches off the ground. All the way around they had rollers so whenever a team tried to play defense on them they still could turn and do things that way without any issues... plus if the other team hit them at any angle but straight on they would "slide" around the robot. The driver said the added maneuverability it gave was amazing, and overall it's a very simple thing to create mechanically. Very, very cool idea and I wish I had a photo or the actual team number that did that. Definitely something to put in the memory banks for future years
Chopsaw? Chopsaw.
Unread 29-04-2007, 17:57
AdamHeard's Avatar
Lead Mentor
I saw that in the pits too... I never got a chance to see it in action though, if anyone finds out the team number. can you link to videos?
Unread 29-04-2007, 19:45
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
That was team 95, the Grasshoppers. They won Xerox Creativity at GSR for that function.
The Blue Alliance has all but one match from GSR (and 95 isn't wasn't in that match).
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 29-04-2007, 19:56
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
We actually based our chassis design this year off that robot. The idea is great, since the chassis can be designed to shrug off hits from anywhere. With this design, at least for us, it was harder for other robots to pin us against the wall or the rack.
Our chassis: http://www.chiefdelphi.com/media/photos/27019
Swamp Thing 2005: http://www.chiefdelphi.com/media/photos/20152
Unread 29-04-2007, 21:11
firebelly's Avatar
firebelly firebelly is offline
The guy with the tail and goggles
AKA: Erin Quillin
FRC #0832 (Chimera)
Team Role: Driver
firebelly will become famous soon enough
Heh heh. Went against this one at nationals. My team was a little worried about it at first, but they turned out not not be a problem since they were coming after us. It was a really cool design, though.
As far as shape is concerned, you also have to keep weight in mind. In 2006, my team designed a great looking, extremely strong frame, but it ended up being super-heavy. *Shivers* so many holes...
~Chillin' like a Quillin
Unread 29-04-2007, 21:34
Herodotus's Avatar
Herodotus Herodotus is offline
Mountain Dew Bandolier Man
AKA: David Resowski
FRC #0910 (Foley Freeze)
Herodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond repute
I know how you feel. On the last day before shipping in 2006 we weighed our robot and found that it was 10 or 15 pounds(I can't remember exactly) overweight. We then spent that day and the next day and took the entire robot apart down to every individual piece of metal, drilled holes or swapped metals(replacing steel axles with aluminum ones for instance). So yeah, don't over design your frame. One thing also to keep in mind is that generally the maximum dimension you can be is a rectangular shape so to make the most of how much room you have a rectangle shape is going to give you the most space.
Unread 29-04-2007, 21:55
firebelly's Avatar
AKA: Erin Quillin
FRC #0832 (Chimera)
Team Role: Driver
Well, while a rectangular shape may give you the most space, you have to ask yourself: do you really need it? I know that my teams robot next year is going to take a very minimalist approach. (I'll be a mentor, but I shall *help* with a iron fist! )
Unread 29-04-2007, 21:58
Herodotus's Avatar
AKA: David Resowski
Well that is what you have to decide before hand. Last year we went with a very boxy approach so we could hold as many balls as possible. This year it would have depended on how you were handling tubes or how your ramps or lifts were shaped. Next year it will be different again and you'll have to think before hand what shape to make the robot.
Unread 29-04-2007, 22:21
AKA: Jamie
We used it this year on our robot, but I was wondering if anybody else used stressed analysis to help design a chassis that could take the blows of defensive competition.
Unread 30-04-2007, 07:47
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
We did some... http://www.chiefdelphi.com/forums/sh...53194&p=569665
Coming up with the load cases was the hard part. We just ended up using a relative comparison. Now that I'm aware of the IRI definition for high speed ramming I've got something solid to work from.
Mark
Brick walls are for other people. - Randy Pausch
Robot Size and Shape: What's Best? SSMike Technical Discussion 14 03-02-2007 13:39
Guess the shape Cyberguy34000 Chit-Chat 1 21-04-2006 22:59
NASA tests shape-shifting robot pyramid for nanotech swarms Alan Anderson NASA Discussion 3 31-03-2005 14:41
pic: Fiberglass robot chassis falconmaster Robot Showcase 13 08-02-2005 23:42
Best Body shape? dddriveman Technical Discussion 34 06-11-2003 16:13
