Go to Post Im very proud of my kids, and my whole team, the passion and emotion here is what FIRST is all about :) - Kims Robot [more]
Unread 29-04-2007, 11:55
team 1094's Avatar
team 1094 team 1094 is offline
FRC #1094
team 1094 is an unknown quantity at this point
need ideas for light weight materials
i need ideas for a light weight materials for controller backpack that would be used for a demos.
[color="red"]if you cant take the HEAT stay out of the workshop
Unread 29-04-2007, 12:03
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: need ideas for light weight materials
Are you looking to make some sort of control board that one can wear to drive your robot(s)?
The first thing that comes to mind would be a marching drum harness. Something like this. I don't know what they make these out of or how much they weigh, but drumline members use these constantly throughout the season, they must not be too heavy.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 29-04-2007, 12:23
Rich Ross Rich Ross is offline
Let's get Desperate!!!
AKA: 830 Alumni
FRC #1504 (The Desperate Penguins)
Rich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond repute
Send a message via AIM to Rich Ross
if you design your control board right and are nice, the marching band might even let you borrow one for a few days. Results, of course, may vary.
1504, finalists WMR and judges award GLR
Let's get Desperate.
Unread 29-04-2007, 12:28
Billfred's Avatar
Billfred Billfred is offline
When 1293 pressed Ockham into parade service, we poked two holes in the control board and stuck a rope through them. The board was constrained rotationally by the gut of the driver. (We would usually lock the arm in the up position with visegrips or something similar, leaving the driver just to drive.)
Unread 29-04-2007, 13:25
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
If you are going for the drum harness method I would use a snare/tenor harness(both have "J" hooks on them) and find a way to put eye-bolts near the shoulder rests for straps down to the far side of the control board.
Unread 29-04-2007, 14:50
team 1094's Avatar
FRC #1094
no, im looking to make one that is portable and is light weight to wear on my back. the only thing you would see is the controller and the anitenia and the eletronics would be hidden in teh back-pack.
Unread 29-04-2007, 15:01
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
One light weight material that has recently caught my eye is Garolite, as G-10 and G-9 have strength equal to 6061 aluminum. Or if that seems too expensive, good quality plywood will work very well.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 29-04-2007, 18:13
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
What you might want if you are considering a marching band harness is specifically a tenor harness. You can easily modify your current operator's console to fit it very easily, as you will only need to mount your operator's console to the part that the tenors mount onto.
Here are some good reliable ones that Yamaha sells. These are not specifically tenor harnesses but you can navigate and find them. Link.
I recommend These are what our drumline uses.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 29-04-2007, 18:27
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
Maybe if you describe exactly what you want to make, we can be a little more helpful. Is the controller a joystick? an Xbox controller? something else? Are you looking for materials to strap something to you, or are you looking for something more along the lines of materials for a board to bolt the electronics to that can slip into an already made backpack?
Alumna of 555 Mentor of 3940
Volunteering since 2004: Say hi to me at events!
Applications Engineer
AndyMark, Inc.
Unread 29-04-2007, 21:51
AdamHeard's Avatar
Lead Mentor
I tested this and it works; A large enough cigar box can hold an OI, chicklet and a vex battery. This can easily fit in a standard backpack with an antenna. Then you use an xbox controller to drive.
Unread 30-04-2007, 07:49
team 1094's Avatar
FRC #1094
its a joystick with a couple of switches. im looking for materials to strap the electronics to that woiuld then slip into a backpack.
Unread 30-04-2007, 07:55
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
If you don't like using premade stuff and you really want to make something yourself, you can always bend something up out of 1/16" or 1/8" (overkill) lexan and use it for your electronics.
Have to say the cigar box sounds a lot better though! much more james bondish...
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 04-05-2007, 07:50
team 1094's Avatar
FRC #1094
Lightbulb Re: need ideas for light weight materials
-q
ok, thanks for the idea.
Unread 04-05-2007, 09:34
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
You could just buy one of these, they are made to be used with IFI radio equipment for battlebot applications.
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
New FIRST team in need of materials/donations/loans Bob Steele General Forum 15 23-10-2006 17:09
where can i get strong light materials???? SCYTE16 General Forum 10 12-11-2004 07:57
Light Weight Transmission thoughtful Technical Discussion 1 07-04-2004 01:30
Weight of Beacon Light Neill Means Technical Discussion 2 01-02-2002 10:56
